konquerror 21 Report post Posted September 30, 2009 Hi All, I have got LGRD3500 Reliance CDMA set which is RUIM based. I want to know the MIN number associated with my MDN. Is there any way to find out? I know that for Nokia devices, you have to press *3001#12345# and go to NAM programming to see your MIN...but what for RUIM based LG phone? PS: I need this parameter to program my number to Blackberry Curve 8330. Is there any other way to activate my current number on Blackberry Curve 8330? I have retrived SPC using UniCDMA and loaded Reliance PRL using QPST. Please help me out. Share this post Link to post Share on other sites
kshah 452 Report post Posted September 30, 2009 If you have micro USB cable, connect 3500 to QPST and can find out MIN. U can use CDMA workshop / UniCDMA too. 1 Share this post Link to post Share on other sites
Sadikk 301 Report post Posted September 30, 2009 for ESN and MIN all u need is great old Unicdma.. and BINGO... 1 Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted September 30, 2009 yes just connect ur handset to qpst , unicdma , will show u esn and min 1 Share this post Link to post Share on other sites
konquerror 21 Report post Posted September 30, 2009 Thanks a lot for your replies...I got Nokia CA 101 cable and installed the USB modem driver from http://www.rcom.co.in/webapp/Communications/rcom/Rm/handsets_lg_3500.jsp But the problem is that when I connect my phone, my computer doesn't recognizes it. I have tried a lot. Is there any other way to get MIN? Share this post Link to post Share on other sites
konquerror 21 Report post Posted September 30, 2009 Thanks a lot for your replies...I got Nokia CA 101 cable and installed the USB modem driver from http://www.rcom.co.i...ets_lg_3500.jsp But the problem is that when I connect my phone, my computer doesn't recognizes it. I have tried a lot. Is there any other way to get MIN? Well problem resolved...the problem was with data cable...pin configuration was wrong...being an Electrical Engineering...I suspected this first.... Got my MIN and ESN. Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted September 30, 2009 use these drivers just connect to pc and in device manager see the com port to which ur lg phone is connected LGUSBModemDriver_WHQL_Eng_Ver_4.8.1.exe 1 Share this post Link to post Share on other sites
konquerror 21 Report post Posted October 1, 2009 use these drivers just connect to pc and in device manager see the com port to which ur lg phone is connected Thank You Sir, It worked finally...problem was with data cable Share this post Link to post Share on other sites
