gsmsikar
A3 Lephone Trisim (2gsm + Cdma) Multimedia Mobile Phone
A3 LePhone TriSim (2GSM + CDMA) Multimedia Mobile Phone
General Features :
2GSM+1CDMA Tri-sim tri-standby mobile
Bluetooth
camera 1.3mega
MP3 and MP4 players
FM radio
Display: 2.0 inch TFT touch screen
Operation frequency: quad-band 850/900/1800/1900mHz
2GSM-1CDMA mobile 3-sim card tri-standby phone is good for your business and good for your life.
Frequency: quad-band GSM850/GSM900/DCS1800/PCS1900 and CDMA 800mhz3 SIM car 3 standby, 2 GSM + 1 CDMA
Display: 2.0' TFT
Dual camera,
Multimedia format: MP3?MP4?3GP?MID?WAV?AAC
bluetooth function
FM radio function
GPRS function
Dimension: 106 x 45.5 x 15 mm
Battery capacity: 850mAh
Talking time: 300 minutes
Standby time: 150 hours
200 SMS, support MMS (GSM) and WAP (GSM)
500 phone books
Video recorder
USB connetor
External memory
Swing change music; Swing change wall picture
3D sound stereo speaker
Support multiple languages
anyone used this ?
how it is ?
it is available in the indian market for Rs 3500 only.
Battery capacity : 850mAh for a tri-SIM phone :rofl_200: ???? A MAD JOKE...How much talk time :Contento: .... Half an hour :'( , while say travelling in train??? (Since you said good for Business... Business men travel a lot, U know..)
You are absoulty right... :Contento::Contento::Contento:
I am using this. Phone is good, I brought it for 3100 from Mumbai. Using for last one month. Battery is long lasting, Not even a single day.
I cant understand... Battery lasting not even a single day, can be considered as LONG LASTING????
May be you tried to say "Battery is NOT long lasting, Not even a single day", right.... I guess so
Whether this thing, at least has "Airplane Mode" or "Multimedia mode" (all 3 SIM's network reception turned off) to save battery power while travelling???
Edited by kanagadeepan
Sorry Boss, Just forgot to add "NOT" in this "Battery is NOT long lasting",
But go for A1 Lephone, NOT A3,
A1 is better than A3.
A1 lephone is noway better than A3 Le phone, there is no major difference except looks .User interface is very bad A1 has VGA (or 1.3mp not remembered exactly) camera and with 800mah battery.with 3sims working simultaneously I dont think it gives more than 45mins talktime and standby time of 6-9hours.
But battery model is BL 5c of nokia.using nokia original BL 5C battery might give 1.5hrs of talk time
Hi Friend, I am planning to buy the phone, can u give some more info on it. How is the camera dude ? whts the battery model used in A3 ? Also whts the max capacity of external memory card we can use & the type ? How is the signal strength, I mean voice clarity etc. Also did u got 2 batteries with the phone for Rs. 3100 ?
Thanks..
How is UI and body compare to Nokia ?
Hi Friend, I have purchased this handset, i have forgot my power on password, how do i reset it, tried all combination...had given it to one of my friends and he has tried changing and misplaced. Pls help in resetting the phone
Rgds
Ramesh Madhavan
You need data cable and software to read the code !
No other way out.
I came to know from local mobile shop that these LePhones don't have Legal IMEIs and especially NO ESN associated with them... Is it TRUE :Ohhhh:
Yes its true !!!! What more you can expect from china craps. :Confuso: :Confuso:
Well, This phone does have valid IMEI no. for all sims e.g. 2GSM and 1CDMA. What is bad in this phone is that battery life is pathetic. I changed mine with a Nokia battery still no good. Camera is just VGA. So no good at all. Sound is good. All in all, not satisfied.
Hi I have recently purchased this phone ...
Anybody knows what is the default security code on this phone ...
I have tried 0000, 1111, 6666, 666666, 9999, 12345 etc, but nothing works.
Hi I am using A1 for last 6 months. Bought it for 3400 and using original Nokia BL 5c battery. The interface and features are good. All the sim works perfectly. The only problem is battery backup. Even with original battery the standby time is around 6 hrs and talk time is hardly 30 min.
Certainly not a good phone for a person with travelling profile. I am not using it now and kept it home for wife since my job involves lot of travelling.
That s what happen to china Cr@p !!! :wacko:
dude try 1122 or 1100, few chinese make phones have this as their default code.
try switching off the screensaver, motion sensor, etc. Also select appropriate sim selection (for e.g. if you are just using a CDMA card in it, select 'ONLY CDMA')
I have used this phone for a week, with the battery that comes along (not Nokia) having only 1 CDMA card inserted & believe me it gave me almost a day's backup.
Edited by krishin.rajani
Oh no! I am late, I just bought the handset today. It is in box and still yet to use it.
i used it for sometime (before it got lost). wanted mainly cdma/
battery life is absolutely worthless even with original bl5c. now using separately cdma (samsung b559, amazing battery life)and gsm (htc). imei is not original but some old dead mobile.
