::Hitesh::
Worlds Largest Plasma Tv
This is Panasonic 103inch Plasma TV,
I have just finished installation of the same,
It is in Chennai Central Railway Station (OLD HALL)
Any more information req ?
feel free to post here.
Attaching a Pic
How much did it cost for them?
:previous:
It is brought by my company,
It cost 24Lakhs + 2Lakhs for fabrication and other hardware.
26 Lakhs
And that must be consuming about 2kw r8?
Almost !
1800watt for plasma + 50Watt for other hardware
so you can say approx 2Kw
Already 30KVa ka bill bhar rahe hai !
Electricity bill dekh ke to lagane wali hai bhai !
:previous:
Hi!!!!
I thought the plasma / LCD at the Chennai Airport was larger than the one at the railway station...Correct me if wrong...
:signthankspin:
Edited by KumaarShah
:previous:
after installation of this at railway station,
we are equal,
Only posted here becoz i am technical head behind this.
Edited by hitesh123
:previous:
we are equal,
Just curious, y u did not go to LCD panels, is it because of brightness/availability?
@Rakesh
LCD Vs Plasma
is very old war, and Plasma always wins,
There are lot of points for debts, separate topic can be open here,
I am going to do that right now.
Hitesh
:previous:
we are equal,
Rakesh i can answer that one for you, LCD panels at 100" size are not available in India, the cost for the same would be higher than 36 lakhs
