freakbaba 0 Report post Posted October 18, 2009 Hello...I recently took a new reliance gsm...how to activate gprs on it. I have sent a message "all" to 55100...been more than 2 days...still no reply from reliance. Is there any other way to do it ? I am using Nokia - e-71. Any help is much appreciated. Thanks! Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted October 18, 2009 Usually settings come in automatically; Have you tried reading this topic and doing settings accordingly - http://www.rimweb.in/forums/index.php?showtopic=17427 Share this post Link to post Share on other sites
freakbaba 0 Report post Posted October 18, 2009 Usually settings come in automatically; Have you tried reading this topic and doing settings accordingly - http://www.rimweb.in/forums/index.php?showtopic=17427 no i have not. are the settings mentioned there the proper way to do it ? also that post is around 10 months old...is that still the best way 2 be done ? Share this post Link to post Share on other sites
konquerror 21 Report post Posted October 18, 2009 Yes...these settings are still valid...try them once... Share this post Link to post Share on other sites
freakbaba 0 Report post Posted October 18, 2009 Yes...these settings are still valid...try them once... tried...didn't work ! :-( Share this post Link to post Share on other sites
konquerror 21 Report post Posted October 18, 2009 Yes...these settings are still valid...try them once... tried...didn't work ! :-( Your GPRS should be activated for these setting to work...try sending ALL to 55100 once again... Share this post Link to post Share on other sites
freakbaba 0 Report post Posted October 19, 2009 Yes...these settings are still valid...try them once... tried...didn't work ! :-( Your GPRS should be activated for these setting to work...try sending ALL to 55100 once again... if i had GPRS why would i need those manual settings. infact why would i even need to create this thread. the whole point is that GPRS is not getting activated at my end ! Share this post Link to post Share on other sites
Greens 21 Report post Posted October 19, 2009 Yes...these settings are still valid...try them once... tried...didn't work ! :-( Your GPRS should be activated for these setting to work...try sending ALL to 55100 once again... if i had GPRS why would i need those manual settings. infact why would i even need to create this thread. the whole point is that GPRS is not getting activated at my end ! Call up *222 & get connected to GPRS Department, and tell them nothing worked. They will send you a text for setting with pin. Share this post Link to post Share on other sites
HetalDP 947 Report post Posted October 21, 2009 *222 is a Nursery class first you have to Teach you Share this post Link to post Share on other sites
freakbaba 0 Report post Posted October 21, 2009 *222 is a Nursery class first you have to Teach you after much haggling...customer care have sent the settings. it works now. thank u all for your inputs too. Share this post Link to post Share on other sites
HetalDP 947 Report post Posted October 21, 2009 Does all Software Works like IM, Skype, email etc etc. if yes Please Share me the Settings I can advice how to extract settings from Phone Share this post Link to post Share on other sites
