hitman
Gprs Settings For Samsung Blackjack2
I have samsung blackjack2 i.e SGH-i617 ..
Its a windows based phone but its not a touchscreen phone .. The OS is windows mobile 6.1
I have tried entering the settings given in this thread ..
Reliance GSM Net and Reliance GSM NetConnect settings work fine ... cos there is no proxy setting involved .. But is costs too much .. 60paise per min ..
Since I have setup my email on my cell so it keep checking every 20 mins .. so I have to stop the connection everytime ..
So can anyone help me with "Reliance GSM WAP Setting" .. It costs 10paise per 10kb .. So I guess it is a better option ..
There r 2 options in my cell .. GPRS and Proxy ..
So in GPRS section I enter the settings
Description: Mobile World
Connect To: in this options r Secure Wap,Wap, Work, Internet (so i select internet)
Access Point: rcomwap
Username : blank
Password : blank
Authentication Type : PAP
Primary DNS : blank
Secondary DNS : blank
IP address : blank
But when I goto Proxy settings there r following options which I have enter .. so can anyone pls tell me wht all to enter in tht ..
Description:
Connect From: in this options r Secure Wap,Wap, Work, Internet
Proxy (name:port):
Type: in this options r HTTP,Wap,Sock4, Sock5
Username:
password:
I have prepaid connection .. Also is there any plan for GPRS "Reliance GSM Net and Reliance GSM NetConnect" which provides like xx amount of data transfer or unlimted transfer..
Edited by hitman
I think you won't be able to fetch your mail in Pocket Outlook using Reliance WAP.
Why is tht so? can't we open sites using wap?
If we can then I suppose we can use outlook to fetch emails also .. Isn't it?
In wap, you can open sites but can't fetch mails using pocket outlook...it's my personal experience...i think in wap...they block all ports except 80 and 443...
k .. thx for the info ..
Is there any Gprs plan available with prepaid?
