ketandjain
Unlocked Bb 9630 On Reliance Gsm
I recently purchased an unlocked verizon bb 9630 runnining os v.4.7.1.61. And I want to use it on Reliance GSM service.
I checked the unlock status by going to Options>Advanced Options>SIM Card> M E P D. It showed the following:
SIM Card: Security Disabled
ID: <19 digit number>
Personalisation:
SIM Disabled
Network Inactive
Network Subset Disabled
Service Provider Disabled
Corpoate Disabled
I got the bb plan activated. My voice and sms service is working fine. However the edge is coming as "edge" and not "EDGE". The Host Routing Table is all empty and "Register Now" does no good. The double arrowed symbol near network bars is coming now and then.
The technical team has taken my BB Pin, IMEI#, IMSI_S#, and made me hard boot like 3875 times. They are still not able to get the bloody edge capitalized. My phone shows "Activation Required". And dialing *228, comes with a reply asking me to add area code before the number.
Please help me because the reliance technical team has no clue what to do and all they say is we are not able to locate your phone.
Thanks & Best Regards,
Ketan Jain
Edited by ketandjain
Change MCC to 404
Home SID to 14655
and BB Reg ID to 14655
u can call me if u not able to change as its lil tricky..
though this are settings for CDMA but Mobile Country code is required for servers to find it..
mail or call me@sadikk.com or 09819515198
Mr. Jain ... you are advised to edit your post and black out all sensitive information such as your ES* and such. Provide this to trusted people such as our bro above through PM only.
Edited by shubhanyu
The suggestions didnt help.
Would debranding make any diff? How about loading relaince provided os for the handset?
Ketan
You could try that and report... Or, you could do the whole debranding process once again...
from the settings that u have posted its for cdma
from what i know they wont have any impact on ur gsm part
if u getting edge in small letters that means ur bb is trying to connect to bb servers but not established connection with servers
once its fully connected to servers edge would become EDGE
also if ur bb services are not activated u could see only gprs/edge
so first check with reliance dept if they have added ur 9630 pin to their database and started ur bb service , unless they add ur pin to their databse u cannot use BIS
if they added pin to their database and u still cant access service then some issue with handset
in that case try loading diff bb os on ur 9630 and see ( for shich u have to debrand first )
remember one thing for BIS the most imp thing is ur PIN , that has to be in the respective carrier's databse
