me_saket
Samsung Corby Speed CDMA Launched
Create a new profile and give some name.
I have created a new profile and have entered the following details.
Home URL - Http://wap.rworld.co.in (default)
PPP Digit - #777
PPP Username - 10 digit cell No.
PPP Password - 10 digit cell no.
PPP Auth Type - None
Proxy - Disable
DNS1 - wapgw.ricinfo.com
DNS2 - Empty
I'm still not able to connect to internet. Kindly help as it causing huge discomfort using this handset.
Try this.
Home URL - www.google.com
PPP Digit - #777
Proxy - Disable
DNS1 - Empty
DNS2 - Empty
If this does not work, then create a similar one, But do not select anything in PPP Auth Type. (It should not be None. Default is blank.)
hi i wish to buy corby speed HOWEVER if some user can clarify
1... can i install 3 party mobile applications on it
specific
icici bank ibank mobile application
and mobile trading software from edellweis (a popular brokerage firm)(JUST AN EXAMPLE)
the reason i am shifting is that stock exchanges have allowed firms to offer stock trading from mobile phone and they have started launching applications for same
2 any other cdma handset that runs internet and MEETS above requirements BUDGET 10K ?
THANKS
VIKRAM
Still not working. I've tried creating various profiles with all suggested settings but of not avail. I'm trying to install Snaptu and while opening it says 'Please be patient while testing your connection for the first time...' and the status remains so forever... :-(
Same is case with Operamini browser...
Even the basic sites like gmail / google open at a tortoise pace....so frustrating and irritating...
I even called up customer care..but as always they weren't of any help whatsoever...as per their observations, everything is OK...whereas as per my experience, nothing is OK... :-(
Try this.
PPP Digit - #777
Proxy - Disable
DNS1 - Empty
DNS2 - Empty
dose any body any idea of its Exchange Active Synce option in menu.
how to configure it....?
