ACS 130 Report post Posted January 28, 2010 The other difference here in bangalore is that maybe we dont have a proper well known 'Market' as such, like Lamington Road in Mumbai or Nehru place in Delhi.. Any member in bangalore can help recommend for future purchases ? Share this post Link to post Share on other sites
csmart 472 Report post Posted January 28, 2010 The other difference here in bangalore is that maybe we dont have a proper well known 'Market' as such, like Lamington Road in Mumbai or Nehru place in Delhi.. Any member in bangalore can help recommend for future purchases ? try to find dealer or reseller. you will get better rate for laptop/notebooks from them rather than croma. also you can try with PC assembler if you know. Share this post Link to post Share on other sites
prafull4u 24 Report post Posted January 28, 2010 (edited) The other difference here in bangalore is that maybe we dont have a proper well known 'Market' as such, like Lamington Road in Mumbai or Nehru place in Delhi.. Any member in bangalore can help recommend for future purchases ? You can check with SP road in bangalore, you will definitely get a better rate. you will be able to save at least 1.5-2K for a laptop It is located near "MARKET" as it is locally called Edited January 28, 2010 by prafull4u Share this post Link to post Share on other sites
coolboyashok 23 Report post Posted July 26, 2010 Hi Guys, I want to purchase one netbook. My requirements are: Primary requirement : 1. Good Processor. 2. Maximum battery backup. Optional requirements: 1. Webcam with mic. 2. Good screen. I can spend around 22k-23k. Please advice ! Thanks Share this post Link to post Share on other sites
haappy 1 Report post Posted November 15, 2010 Hi, I want to buy netbook of any brand but need some mandatory Hardware Features. screen resolution should be 1366x768 HDMI Port Chicklet Keyboard (Like Sony Vaio) Ram Should be DDR3 Wi-Fi N Series I cant find these all features in any netbook of any brand. So pls if u find any netbook these Available in India with Bill and Warrenty have all features. pls help me to find. Share this post Link to post Share on other sites
sgiitk 32 Report post Posted November 16, 2010 (edited) I am getting the Lenovo S10-3s 59-041927 (hopefully today. Has 1GB (expandable to 2GB) DDR 3 RAM and Atom N475. Also, Win 7 Starter!. Just launched, at Rs. 21k. Edited November 16, 2010 by sgiitk Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted November 16, 2010 (edited) I was thinking of buying a Netbook for my kids, but instead went in for the Toshiba full fledged laptop with dvd drive, 2gb ram, 250gb hdd, chicklet type keyboard with separate numeric keypad, at the price of a netbook at 22K... and I am totally satisfied with that decision; The laptop is running absolutely smoothly on Windows 7 Ultimate and giving full all round pleasure... do keep this option open for netbook users if u can do with about 4 hour battery life... Edited November 16, 2010 by dkaile Share this post Link to post Share on other sites
csmart 472 Report post Posted November 16, 2010 its bettr to go for toshiba laptop instead of 21k netbook.. if u only want small screen size. Share this post Link to post Share on other sites
sgiitk 32 Report post Posted November 16, 2010 I also held the view that a notebook gave you far more bang for the buck. However, if size is a criterion then ... Also, the apparent rarity of small (12-13") Notebooks at decent prices, without DVD's pushes you in that direction. I have an Acer 3801T bought last year and am quite happy with it. Only I had a battery change under warranty, so did a couple of colleagues who bought the same. My daughter-in-law had two battery changes within the one year. So I will be reluctant about Acer for the moment. Share this post Link to post Share on other sites
