rohitgaur 78 Report post Posted January 27, 2010 Dear All Whenevr I press Call Log button on the screen of my Palm, it hard resets, what can be the problem... Share this post Link to post Share on other sites
Harshal 11 Report post Posted January 27, 2010 Have you tried using Treo Call Log Tool to see if it can access the call log? If so you might try to delete some records. Also try using MyCallLog. Share this post Link to post Share on other sites
aviator 3 Report post Posted January 28, 2010 I myself m using 755P and have noticed that Palm behave eraatically once its phone memory is loaded. As the age of ur palm increases, the problem deepens. Try removing some of the data (in my case deleting my msgs{which were around 2200} worked. Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted January 29, 2010 As the age of ur palm increases, the problem deepens thats why now they have scrapped palm os completely try reloading a firmware may be Share this post Link to post Share on other sites
rohitgaur 78 Report post Posted January 29, 2010 The Biggest trouble is, that since I moved to Vista from XP, I am not able to sync my phone as well. i e it even does not show that it is connected vide that LED or USB Icon... Sadikkkkk.... Need the Pixi fast bro.... The times up on this one I guess.... Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted January 29, 2010 Vista drivers are separate for treo 755p; I hd posted link long time back somewhere... Share this post Link to post Share on other sites
rohitgaur 78 Report post Posted January 29, 2010 (edited) thx dhiraj.... i wasnt aware.. will search for them now EDIT: Found the Treocalllogtool TCLT....while searching for drivers,installed via Bluetooth and Used it to export and nPurge previous call log.. Now it is working as smooth as a Merc Edited January 29, 2010 by rohitgaur Share this post Link to post Share on other sites
