SumitVerma 187 Report post Posted January 29, 2010 I have this issue from the very first day I activated this phone on Tata Indicom. I am able to send txts from this phone to others but when I receive txts on this phone, This is what I get- " Sorry! The Application Messages (process com.android.mms) has stopped unexpectedly. Please Try Again " And " Sorry! The process com.android.phone has stopped unexpectedly. Please Try Again Later " I tried rooting the phone and I am now on MODACO rom but no good.. same thing happens everytime. Please Gurus help me out with this issue! Share this post Link to post Share on other sites
phonegeek 588 Report post Posted January 29, 2010 Have you tried doing fix_permissions in terminal ? 1 Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted January 29, 2010 Have you tried doing fix_permissions in terminal ? Sir I am new to android and have no idea about anything... I have a bit knowledge about WM but I am a newbie to Android.. please can you explain me what is to be done? Share this post Link to post Share on other sites
phonegeek 588 Report post Posted January 29, 2010 Go to Terminal on your handset, then type su, then it will show #, thn type fix_permissions. It will run some process, reboot and check. 1 Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted January 29, 2010 this should solve the issue do the backup of ur device ( not nandroid one) the go to settings--security--format ur device it should get over the error 1 Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted January 29, 2010 this should solve the issue do the backup of ur device ( not nandroid one) the go to settings--security--format ur device it should get over the error Sirs tried both of what you said... still all in vain! what to do next? please help me out of this issue.. Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted January 29, 2010 (edited) As you must have done OTA activation on Tata, somehow I feel the sms service centre no. has not been properly configured; you made need to search that setting and configure that... It is a backend problem and 99% it should be improper activation problem... You could try somethings but i'm afraid you dont mess something else up... take the help of some techie to check that setting in epst... also, I would suggest you download and flash modaco 1.3 rom (the one based on 1.56 kernel) and do a clean wipe of your device and then do a fresh install from sd card... Edited January 29, 2010 by dkaile 1 Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted January 29, 2010 As you must have done OTA activation on Tata, somehow I feel the sms service centre no. has not been properly configured; you made need to search that setting and configure that... It is a backend problem and 99% it should be improper activation problem... You could try somethings but i'm afraid you dont mess something else up... take the help of some techie to check that setting in epst... also, I would suggest you download and flash modaco 1.3 rom (the one based on 1.56 kernel) and do a clean wipe of your device and then do a fresh install from sd card... I got it from Sadikk Bhai. He Changed the MEID to ESN so that i could easily activate it with postpaid tata Number. Sirs, Please help me out with this issue if you could! If there is some issue with the service center no. would I be able to send messages? whereas I am able to send txts! Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted January 29, 2010 I am currently on MODACO 2.2 i was facing the problem before and now... there is no difference whatever I do. Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted January 29, 2010 These are my EPST Settings! EDVANCED: P_REV- IS-2000 (6) SCM- 42 SLOT MODE- ENABLE SLOT CYCLE INDEX- 2 MCC- 404 MNC- 00 MSID- ************ ACCOLC- 4 VOCODER- ENABLE HOME ORIG- EVRC ROAM ORIG- VOICE 13K LBS PDE IP- 0.0.0.0 LBS PDE PORT- 0 HOME SYS REGISTRATION- ENABLE FORIGN SID REGISTRATION- ENABLE DDTM- DISABLE HOME SID/NID#1- 14846/65535 PROFILE: ACTIVE PROFILE- 1 USER NAME- (BLANK) SPI MN-HA- 4D2 REVERSE TUNNEL PREFERRED- ENABLE HOME IP ADDRESS- 0.0.0.0 PRIMARY HOME AGENT- 0.0.0.0 SECOND HOME AGENT- 0.0.0.0 HA SHARED SECRET- ******** AAA SHARED SECRET- ******** DSA SERVER URL- HTTPS://DSA.SPCSDNS.NET:443/DSA/ Hope this helps you is understanding the issue! Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted January 30, 2010 change roam orig to evrc; disable foreign sid (it might be latching on to reliance); and try... 1 Share this post Link to post Share on other sites
kshah 452 Report post Posted January 30, 2010 (edited) Could be ROM problem . Also there is no Message cen tre concept in CDMA. In CDMA messages are sent over paging channel and authentication is done using MIN and ESN. In India tata and reliance uses EVRC. Also if in tata ensure that you have entered all SID / NID pairs and has right PRL. Tata is not as tolerant as reliance. Reliance provisioning settings are very simple and its more fault tolerant. Edited January 30, 2010 by kshah Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted January 30, 2010 Could be ROM problem . Also there is no Message cen tre concept in CDMA. In CDMA messages are sent over paging channel and authentication is done using MIN and ESN. In India tata and reliance uses EVRC. Also if in tata ensure that you have entered all SID / NID pairs and has right PRL. Tata is not as tolerant as reliance. Reliance provisioning settings are very simple and its more fault tolerant. But I can only see 1 SID/NID and not like WM where we have 5-6 entries! And right PRL? How can I Check the PRL? Sadik Bhai gave it to me with all the settings done. Now How can I check whether the PRL is good or not? Share this post Link to post Share on other sites
HetalDP 947 Report post Posted January 30, 2010 Very Very Sorry to Reply Late and not replying in PM Mr Verma But i think Just Root it / Load Modacom 2.2 / Clean Wipe it and try again ROM is Located here http://www.romraid.com/paul/hero/2.2-update-heroc-modacocustomrom-core-signed.zip Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted January 30, 2010 Very Very Sorry to Reply Late and not replying in PM Mr Verma But i think Just Root it / Load Modacom 2.2 / Clean Wipe it and try again ROM is Located here http://www.romraid.com/paul/hero/2.2-update-heroc-modacocustomrom-core-signed.zip Sir Please dont make me feel bad saying sorries.. I can understand one can get busy at times.. But As I have already mentioned I have rooted the phone and its running on MODACO 2.2 but I am still facing the same issue. Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted January 30, 2010 well from what i know this is not related to your programming coz if ur programming was incorrect u wudn be able to use it on tata the problem basically lies with the rom i have read several people on net reported this issue while using modaco rom so i would advise u to load some other rom ( non modaco ) and see also wipe ur device before installing a rom and dont do a backup ...start fresh Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted January 30, 2010 also u can do one thing use log collector when u get this error run log collector ( if u dont have get from market ) it will give clear picture u r not the only one there are many people who have faced this issue on several android handsets seems there is a bug with android messaging database Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted January 30, 2010 well from what i know this is not related to your programming coz if ur programming was incorrect u wudn be able to use it on tata the problem basically lies with the rom i have read several people on net reported this issue while using modaco rom so i would advise u to load some other rom ( non modaco ) and see also wipe ur device before installing a rom and dont do a backup ...start fresh I was facing this problem in the stock ROM aswell so I asked HP sir to help me out so after he guiding me I went on modaco rom! and if I run log collector after I press the force close button will I still be able to collect the data? Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted January 30, 2010 This is what I have got from Log Collector! I have replaced the mobile no. with 11 stars (*) Log Collector version: 1.1.0 Device model: HERO200 Firmware version: 1.5 Kernel version: 2.6.27-mck-1.2 root@vmware-karmic-x64 ) #2 PREEMPT Tue Jan 26 08:27:24 GMT 2010 Build number: 1.56.651.2 01-31 03:08:48.526 I/ActivityManager( 103): Starting activity: Intent { comp={com.android.mms/com.android.mms.ui.ComposeMessageActivity} (has extras) } 01-31 03:08:48.556 E/all message( 1124): search URI = content://contacts/contacts/phones/simple_match/*********** 01-31 03:08:48.716 D/dalvikvm( 1124): GC freed 2847 objects / 653688 bytes in 136ms 01-31 03:08:48.746 W/ResourceType( 1124): Invalid package identifier when getting bag for resource number 0x7f0a0015 01-31 03:08:48.866 V/MessageTextEditor( 1124): Nli: -1 01-31 03:08:48.946 D/ComposeMessageActivity( 1124): -----------------mMessageUri:null 01-31 03:08:48.956 V/MmsProvider( 1109): Query uri=content://mms/drafts, match=6 01-31 03:08:48.956 D/Jerry ( 1124): do cancel in Conversation 01-31 03:08:48.976 D/ComposeMessageActivity( 1124): Activity is not resumed, sleep 0.5 second and then start async query. 01-31 03:08:48.976 D/PhoneWindow( 1124): DebugMonitor class=com.android.mms.ui.ConversationList focus=false 01-31 03:08:48.976 D/ComposeMessageActivity( 1124): -----------------onQueryComplete 01-31 03:08:49.076 D/PhoneWindow( 1124): DebugMonitor class=com.android.mms.ui.ComposeMessageActivity focus=true 01-31 03:08:49.216 I/ActivityManager( 103): Displayed activity com.android.mms/.ui.ComposeMessageActivity: 689 ms 01-31 03:08:49.336 I/all message( 1124): ========mdata.mName: *********** 01-31 03:08:49.336 I/all message( 1124): ========mdata.mPersonId: -1 01-31 03:08:50.056 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:08:50.196 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:08:50.296 I/HTCIMEService( 626): [onCreateInputView] 01-31 03:08:50.346 W/Resources( 626): Converting to string: TypedValue{t=0x12/d=0x0 a=2 r=0x7f09017a} 01-31 03:08:50.346 W/Resources( 626): Converting to string: TypedValue{t=0x12/d=0x0 a=2 r=0x7f09017b} 01-31 03:08:50.476 I/RRRLOG ( 626): mLandHintTextView - android.widget.TextView@4352c500 01-31 03:08:51.876 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:08:52.036 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:08:52.396 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:08:52.596 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:08:53.776 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:08:53.906 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:08:54.116 I/AlertDialog( 1124): [onCreate] auto launch SIP. 01-31 03:08:54.196 D/dalvikvm( 626): GC freed 3070 objects / 185368 bytes in 263ms 01-31 03:08:54.256 D/PhoneWindow( 1124): DebugMonitor class=android.app.ProgressDialog focus=true 01-31 03:08:54.336 D/ComposeMessageActivity( 1124): Email by thread:null 01-31 03:08:54.336 D/ComposeMessageActivity( 1124): Before Send Address:*********** Send Message Body: Hello 01-31 03:08:54.456 D/PhoneWindow( 1124): DebugMonitor class=com.android.mms.ui.ComposeMessageActivity focus=false 01-31 03:08:54.556 D/dalvikvm( 296): GC freed 188 objects / 25968 bytes in 217ms 01-31 03:08:54.666 D/SmsProvider( 1109): insert url=content://sms/outbox, match=8 01-31 03:08:54.876 D/SmsMessageSender( 1124): Send Message To:*********** Body[Hello] 01-31 03:08:54.906 D/MessageListAdapter( 1124): onContentChanged, do async requery 01-31 03:08:54.916 D/MessageListAdapter( 1124): onContentChanged, the previous requery is still running, don't do async requery 01-31 03:08:55.086 D/MessageListAdapter( 1124): onQueryComplete, isRequeryNeeded = true, call onContentChanged() to start async requery. 01-31 03:08:55.086 D/MessageListAdapter( 1124): onContentChanged, do async requery 01-31 03:08:55.476 D/MmsSmsProvider( 1109): ids: 1 01-31 03:08:55.476 D/MmsSmsProvider( 1109): address: *********** 01-31 03:08:55.476 D/MmsSmsProvider( 1109): recipientIds: 1 01-31 03:08:55.476 D/MmsSmsProvider( 1109): recipientAddress: *********** 01-31 03:08:55.806 D/PhoneWindow( 1124): DebugMonitor class=com.android.mms.ui.ComposeMessageActivity focus=true 01-31 03:08:55.856 W/InputManagerService( 103): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@438372b8 01-31 03:08:56.056 I/CalendarPovider( 391): updateCalendarNameByLocale 01-31 03:08:56.056 I/CalendarProvider( 391): update locale:USA 01-31 03:08:56.056 I/CalendarProvider( 391): Locale doesn't change, so return it 01-31 03:08:56.116 D/StatusBar( 103): updateResources 01-31 03:08:56.286 I/HTCIMEService( 626): [onAppMessage]: action=inputRemainCount, data=Bundle[mParcelledData.dataSize=92] 01-31 03:08:57.276 D/SmsReceiver( 1124): ReceiveSmsTask 01-31 03:08:57.336 D/IQSystem( 87): CIQ-106(1831): bad data on master/slave bridge 01-31 03:08:57.366 D/IQSystem( 87): CIQ-106(1456): P2P_RESYNC_ACK: 8 01-31 03:08:57.366 D/IQSystem( 87): CIQ-106(1456): P2P_RESYNC_ACK: 7 01-31 03:08:57.366 D/IQSystem( 87): CIQ-106(1456): P2P_RESYNC_ACK: 6 01-31 03:08:57.366 D/IQSystem( 87): CIQ-106(1456): P2P_RESYNC_ACK: 5 01-31 03:08:57.366 D/IQSystem( 87): CIQ-106(1456): P2P_RESYNC_ACK: 4 01-31 03:08:57.366 D/IQSystem( 87): CIQ-106(1456): P2P_RESYNC_ACK: 3 01-31 03:08:57.366 D/IQSystem( 87): CIQ-106(1456): P2P_RESYNC_ACK: 2 01-31 03:08:57.366 D/IQSystem( 87): CIQ-106(1456): P2P_RESYNC_ACK: 1 01-31 03:08:57.366 D/IQSystem( 87): CIQ-106(1456): P2P_RESYNC_ACK: 0 01-31 03:08:57.376 D/MessageListAdapter( 1124): onContentChanged, do async requery 01-31 03:08:57.586 V/MmsProvider( 1109): Query uri=content://mms/outbox, match=8 01-31 03:08:57.616 D/MessageListAdapter( 1124): onContentChanged, do async requery 01-31 03:08:57.866 D/SmsSent ( 1124): sending broadcast to DM Receiver -1 01-31 03:08:57.886 I/ActivityManager( 103): Stopping service: com.android.mms/.transaction.SmsReceiverService 01-31 03:08:57.906 D/SmsSent ( 1109): DMCmdBroadcastReceiver received Message sent action 01-31 03:08:58.136 I/WindowManager( 103): onOrientationChanged, rotation changed to 0 01-31 03:08:58.366 D/dalvikvm( 103): GC freed 9033 objects / 442800 bytes in 235ms 01-31 03:08:58.566 I/CalendarProvider( 391): updateCalendarNameByLocale 01-31 03:08:58.566 I/CalendarProvider( 391): update locale:USA 01-31 03:08:58.566 I/CalendarProvider( 391): Locale doesn't change, so return it 01-31 03:08:58.586 D/StatusBar( 103): updateResources 01-31 03:08:59.848 D/KeyInputQueue( 103): DebugMonitor keycode=4 value=1 01-31 03:08:59.856 W/KeyCharacterMap( 1124): Bad keycharmap - filesize=32 01-31 03:09:00.026 D/KeyInputQueue( 103): DebugMonitor keycode=4 value=0 01-31 03:09:00.066 D/ConversationList( 1124): onResume Start 01-31 03:09:00.066 D/ConversationList( 1124): handle message MSG_RUN_AFTER_ONRESUME Start 01-31 03:09:00.096 D/ConversationList( 1124): onResume End 01-31 03:09:00.136 D/PhoneWindow( 1124): DebugMonitor class=com.android.mms.ui.ConversationList focus=true 01-31 03:09:00.216 D/ConversationListAdapter( 1124): startAsyncQuery 01-31 03:09:00.216 D/ConversationList( 1124): handle message MSG_RUN_AFTER_ONRESUME End 01-31 03:09:00.216 D/Jerry ( 1124): do cancel in Conversation 01-31 03:09:00.276 D/ConversationListAdapter( 1124): onQueryComplete, the async query uses 61 miniseconds 01-31 03:09:00.286 D/PhoneWindow( 1124): DebugMonitor class=com.android.mms.ui.ComposeMessageActivity focus=false 01-31 03:09:01.126 D/dalvikvm( 103): GC freed 3591 objects / 148000 bytes in 221ms 01-31 03:09:01.126 D/KeyInputQueue( 103): DebugMonitor keycode=4 value=1 01-31 03:09:01.166 I/WindowManager( 103): Screen status=true, current orientation=1, SensorEnabled=true 01-31 03:09:01.166 I/WindowManager( 103): needSensorRunningLp, mCurrentAppOrientation =1 01-31 03:09:01.166 I/WindowManager( 103): needSensorRunningLp, SCREEN_ORIENTATION_PORTRAIT 01-31 03:09:01.166 D/Sensors ( 103): close_akm, fd=93 01-31 03:09:01.166 D/Sensors ( 103): sensors=00000000, real=00000000 01-31 03:09:01.206 D/Sensors ( 103): using /dev/input/event5 (name=compass) 01-31 03:09:01.206 D/KeyInputQueue( 103): DebugMonitor keycode=4 value=0 01-31 03:09:01.246 I/WindowManager( 103): Disabling listeners 01-31 03:09:01.246 D/PhoneWindow( 1124): DebugMonitor class=com.android.mms.ui.ConversationList focus=false 01-31 03:09:01.286 D/Rosie ( 151): onResume() [setBackgroundTrafficLight()] : diff - 25 01-31 03:09:01.286 D/Rosie ( 151): onResume() [onRestoreInstanceState] : diff - 25 01-31 03:09:01.296 D/Rosie ( 151): onResume() [finished] : diff - 29 01-31 03:09:01.416 D/PhoneWindow( 151): DebugMonitor class=com.htc.launcher.Launcher focus=true 01-31 03:09:01.546 D/AK8973 ( 85): Compass CLOSE 01-31 03:09:02.586 D/WeatherClockWidget( 151): MSG_REFETCH_CACHEDATA 01-31 03:09:02.596 D/WeatherClockWidget( 151): Query Weather data by Latitude: 28.895950, Longitude: 76.612297 01-31 03:09:02.596 W/WeatherUtil( 151): schedule DCS task, mixed quest code 01-31 03:09:02.596 D/WeatherUtil( 151): DCS service connected, schedule task mixed quest code of AccuWeather and Geocode together 01-31 03:09:02.596 D/WeatherUtil( 151): Download weather data under ROAMING 01-31 03:09:02.596 I/DCS ( 183): [DCS] Schedule, key[android.app.ApplicationContext10078] componentCode[DCSWeatherService] period[10800000] cache[10800000] params[1] roaming[1] 01-31 03:09:07.666 D/dalvikvm( 845): GC freed 4896 objects / 285944 bytes in 162ms 01-31 03:09:11.366 V/DCS ( 183): [DCS] bind component DCSWeatherService for android.app.ApplicationContext10078, system result: true 01-31 03:09:11.416 I/ActivityManager( 103): Stopping service: com.htc.dcs.service.weather/.WeatherService 01-31 03:09:11.426 V/DCS ( 183): [DCS] unbind component DCSWeatherService for android.app.ApplicationContext10078 01-31 03:09:11.426 I/DCS ( 183): [Fetcher_DCSWeatherService_android.app.ApplicationContext10078_1129735968] Execute client callback-function: android.app.ApplicationContext10078 01-31 03:09:11.436 D/WeatherUtil( 151): receive DCS service callback result 01-31 03:09:11.436 D/WeatherClockWidget( 151): Check code from result from DCS: 1 01-31 03:09:16.406 D/dalvikvm( 1430): GC freed 686 objects / 59328 bytes in 98ms 01-31 03:09:17.538 D/IQClient( 88): Receive a battery uevent... 01-31 03:09:17.538 D/IQClient( 88): battEventhandler...Uevent[change@/devices/platform/rs30100001:00000000/power_supply/battery] 01-31 03:09:17.538 D/IQClient( 88): update-Last: level=89, chargesource=0 01-31 03:09:17.538 D/IQClient( 88): update-Cur : level=88, chargesource=0 01-31 03:09:17.566 D/KeyguardUpdateMonitor( 103): receive ACTION_BATTERY_CHANGED 01-31 03:09:17.626 D/UsbConnectedReceiver( 346): ACTION_BATTERY_CHANGED 01-31 03:09:17.626 D/UsbConnectedReceiver( 346): unplugged = 0 01-31 03:09:17.636 D/UsbConnectedReceiver( 346): USB Disconnected. 01-31 03:09:19.656 D/UsbConnectedReceiver( 346): Catch USB Disconnect Event, USB cable does really not exist. 01-31 03:09:19.656 D/UsbConnectedReceiver( 346): ADB Enable = false 01-31 03:09:19.656 D/UsbConnectedReceiver( 346): ADB StartByMe = false 01-31 03:09:19.656 D/UsbConnectedReceiver( 346): Try to stop PSService. 01-31 03:09:22.706 D/dalvikvm( 145): GC freed 198 objects / 7344 bytes in 94ms 01-31 03:09:26.646 D/CDMA ( 1109): update CDMA location information 01-31 03:09:26.706 D/HtcCdmaPowerSave( 1109): get creg_increment: 7 01-31 03:09:26.706 D/HtcCdmaPowerSave( 1109): set creg_increment: 8 01-31 03:09:26.706 D/HtcCdmaPowerSave( 1109): set creg_state: 2 01-31 03:09:26.746 I/HtcLockScreen( 103): -----refreshCarrierInfo plmn=Tata,spn=null, service=4 01-31 03:09:26.746 I/HtcLockScreen( 103): updateStatusViewByPriority 01-31 03:09:26.746 I/HtcLockScreen( 103): updateStatusViewByPriority 01-31 03:09:26.826 I/HtcLockScreen( 103): -----refreshViewsWhetherSimOk -----: READY 01-31 03:09:26.826 I/HtcLockScreen( 103): updateStatusViewByPriority 01-31 03:09:26.826 D/LocationManagerService( 103): Unavailable 01-31 03:09:26.836 D/CDMA ( 1109): send cell location intent 01-31 03:09:26.846 V/AutoSettingReceiver( 143): AutoSettingReceiver onReceive() : android.provider.Telephony.NETWORK_STRINGS_UPDATED 01-31 03:09:26.866 D/LocationManagerService( 103): CDMA Cell latitude: 28.89847222222222 longitude: 76.59645833333333 01-31 03:09:27.106 D/MobileDataStateTracker( 103): Received android.intent.action.ANY_DATA_STATE broadcast - state = DISCONNECTED, unavailable = true, reason = gprsDetachedapn=0, capability=null 01-31 03:09:27.106 D/GpsLocationProvider( 103): state: DISCONNECTED apnName: 0 reason: gprsDetached 01-31 03:09:27.166 D/libgps ( 103): qct_gps_set_apn: 01-31 03:09:27.556 D/CDMA ( 1109): Not in service! Can't update location! 01-31 03:09:27.586 D/HtcCdmaDataControl( 1109): Carrier=3 01-31 03:09:27.586 D/HtcCdmaDataControl( 1109): ERI value=1 01-31 03:09:27.586 D/HtcCdmaDataControl( 1109): ERI data guard=0 01-31 03:09:27.606 D/HtcCdmaDataControl( 1109): PriCtrl=false, PriResult=false, for type=ALLOW_SETUP, ERIid=1->1, ERIguard=0->0, UsrRoamAllow=true, UsrGuard=0, UsrAccept=false, conntd=false 01-31 03:09:27.616 D/HtcCdmaPowerSave( 1109): get creg_increment: 8 01-31 03:09:27.616 D/HtcCdmaPowerSave( 1109): set creg_increment: 9 01-31 03:09:27.616 D/HtcCdmaPowerSave( 1109): set creg_state: 1 01-31 03:09:27.676 I/HtcLockScreen( 103): -----refreshCarrierInfo plmn=Tata,spn=null, service=0 01-31 03:09:27.676 I/HtcLockScreen( 103): updateStatusViewByPriority 01-31 03:09:27.676 I/HtcLockScreen( 103): updateStatusViewByPriority 01-31 03:09:27.676 I/HtcLockScreen( 103): -----refreshViewsWhetherSimOk -----: READY 01-31 03:09:27.676 I/HtcLockScreen( 103): updateStatusViewByPriority 01-31 03:09:27.686 V/AutoSettingReceiver( 143): AutoSettingReceiver onReceive() : android.provider.Telephony.NETWORK_STRINGS_UPDATED 01-31 03:09:27.746 D/HtcCdmaDataControl( 1109): Update conntd=false 01-31 03:09:27.776 D/AutoSettingReceiver( 143): Last MCC = 404, MCC = 404 01-31 03:09:27.786 D/HtcCdmaDataControl( 1109): Disabled by connMgr 01-31 03:09:27.876 D/MobileDataStateTracker( 103): Received android.intent.action.ANY_DATA_STATE broadcast - state = DISCONNECTED, unavailable = false, reason = gprsAttachedapn=0, capability=null 01-31 03:09:27.886 D/GpsLocationProvider( 103): state: DISCONNECTED apnName: 0 reason: gprsAttached 01-31 03:09:27.886 D/libgps ( 103): qct_gps_set_apn: 01-31 03:09:27.906 D/MobileDataStateTracker( 103): Received android.intent.action.ANY_DATA_STATE broadcast - state = DISCONNECTED, unavailable = false, reason = gprsAttachedapn=null, capability=null 01-31 03:09:27.916 D/GpsLocationProvider( 103): state: DISCONNECTED apnName: null reason: gprsAttached 01-31 03:09:27.916 D/libgps ( 103): qct_gps_set_apn: 01-31 03:09:30.006 D/RIL_JAVA( 1109): processUnsolicited ret >0000021002020702C248562200000601FC082200031FFFF001041014AD2003061001310308410801000D01000E0705D490AC445550 01-31 03:09:30.016 D/CDMA ( 1109): New SMS Message Received, cat=4098 01-31 03:09:30.016 D/HtcCdmaSmsDispatcher( 1109): dispatchSmsPdus >> 01-31 03:09:30.016 D/HtcCdmaSmsDispatcher( 1109): dispatchSmsToCIQ() 01-31 03:09:30.016 V/AgentService_J( 145): recieve SMS notify:2 01-31 03:09:30.016 V/AgentService_J( 145): +dSmsNotify:2 01-31 03:09:30.016 V/AgentService_J( 145): +handle msg:2 01-31 03:09:30.016 V/AgentService_J( 145): arraySize:2 01-31 03:09:30.016 V/AgentService_J( 145): -handle msg:2 01-31 03:09:30.026 V/AgentService_J( 145): toAgent.length:2 01-31 03:09:30.026 V/AgentService_J( 145): smsHexBody:2:4A69 01-31 03:09:30.026 V/AgentService_J( 145): toAgent:2:4A69 01-31 03:09:30.026 V/AgentService_J( 145): 2 01-31 03:09:30.026 V/AgentService_J( 145): +checkSMS:-1 01-31 03:09:30.026 W/dalvikvm( 145): JNI WARNING: DeleteLocalRef(0x43491c50) failed to find entry (valid=1) 01-31 03:09:30.026 D/CDMA ( 1109): Send SMS to CIQ : ComponentInfo{com.htc.android.iqagent/com.htc.android.iqagent.AgentService} 01-31 03:09:30.026 D/HtcCdmaSmsDispatcher( 1109): dispatchSmsPdus << 01-31 03:09:30.036 V/AgentService_J( 145): -checkSMS:0 01-31 03:09:30.056 V/AgentService_J( 145): sendBroadcast(throwIntent, android.permission.RECEIVE_SMS) 01-31 03:09:30.056 V/AgentService_J( 145): toAgent:2 was sent to SMS 01-31 03:09:30.056 V/AgentService_J( 145): -dSmsNotify:2 01-31 03:09:30.156 D/com.telenav.app.android.CommuteAlertTrigger( 1079): SMS Message received, check if it is a commute alert. 01-31 03:09:30.166 D/com.telenav.app.android.CommuteAlertTrigger( 1079): Not commute alert, ignor it. 01-31 03:09:30.316 D/SmsReceiver( 1124): ReceiveSmsTask 01-31 03:09:30.366 D/SmsProvider( 1109): insert url=content://sms/inbox, match=2 01-31 03:09:30.426 D/MmsSmsProvider( 1109): ids: 12 01-31 03:09:30.426 D/MmsSmsProvider( 1109): address: �9215888��� 01-31 03:09:30.426 D/MmsSmsProvider( 1109): recipientIds: 12 01-31 03:09:30.426 D/MmsSmsProvider( 1109): recipientAddress: �9215888��� 01-31 03:09:30.686 E/DatabaseUtils( 143): Writing exception to parcel 01-31 03:09:30.686 E/DatabaseUtils( 143): android.database.sqlite.SQLiteException: unrecognized token: "'": , while compiling: SELECT type, notes, last_time_contacted, name, times_contacted, primary_organization, send_to_voicemail, GET_PHONETICALLY_SORTABLE_STRING(CASE WHEN (phonetic_name IS NOT NULL AND phonetic_name != '') THEN phonetic_name ELSE (CASE WHEN (name is NOT NULL AND name != '')THEN name ELSE (CASE WHEN primary_email IS NOT NULL THEN (SELECT data FROM contact_methods WHERE contact_methods._id = primary_email) ELSE (CASE WHEN primary_phone IS NOT NULL THEN (SELECT number FROM phones WHERE phones._id = primary_phone) ELSE null END) END) END) END) AS sort_string, number, primary_email, default_action, primary_phone, number_key, extra_group, label, (CASE WHEN (name IS NOT NULL AND name != '') THEN name ELSE (CASE WHEN primary_organization is NOT NULL THEN (SELECT company FROM organizations WHERE organizations._id = primary_organization) ELSE (CASE WHEN primary_phone IS NOT NULL THEN (SELECT number FROM phones WHERE phones._id = primary_phone) ELSE (CASE WHEN primary_email IS NOT NULL THEN (SELECT data FROM contact_methods WHERE contact_methods._id = primary_email) ELSE null END) END) END) END) AS display_name, phonetic_name, isprimary, picasaUrl, lastName, pureNumber, last_update_time, custom_ringtone, starred, phones._id AS _id, firstName, phones.person AS person FROM people, phones WHERE (phones.person=people._id AND PHONE_NUMBERS_EQUAL(phones.number, '�9215888���')) ORDER BY name ASC 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteProgram.native_compile(Native Method) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteProgram.compile(SQLiteProgram.java:110) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteProgram.<init>(SQLiteProgram.java:59) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteQuery.<init>(SQLiteQuery.java:49) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteDirectCursorDriver.query(SQLiteDirectCursorDriver.java:49) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteDatabase.rawQueryWithFactory(SQLiteDatabase.java:1118) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteQueryBuilder.query(SQLiteQueryBuilder.java:312) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteQueryBuilder.query(SQLiteQueryBuilder.java:262) 01-31 03:09:30.686 E/DatabaseUtils( 143): at com.android.providers.contacts.ContactsProvider.queryInternal(ContactsProvider.java:4789) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.content.AbstractSyncableContentProvider.query(AbstractSyncableContentProvider.java:359) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.content.ContentProvider$Transport.bulkQuery(ContentProvider.java:112) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.content.ContentProviderNative.onTransact(ContentProviderNative.java:97) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.os.Binder.execTransact(Binder.java:287) 01-31 03:09:30.686 E/DatabaseUtils( 143): at dalvik.system.NativeStart.run(Native Method) 01-31 03:09:30.686 E/DatabaseUtils( 143): Writing exception to parcel 01-31 03:09:30.686 E/DatabaseUtils( 143): android.database.sqlite.SQLiteException: unrecognized token: "'": , while compiling: SELECT phones.person AS person FROM people, phones WHERE (phones.person=people._id AND PHONE_NUMBERS_EQUAL(phones.number, '�9215888���')) ORDER BY name ASC 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteProgram.native_compile(Native Method) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteProgram.compile(SQLiteProgram.java:110) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteProgram.<init>(SQLiteProgram.java:59) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteQuery.<init>(SQLiteQuery.java:49) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteDirectCursorDriver.query(SQLiteDirectCursorDriver.java:49) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteDatabase.rawQueryWithFactory(SQLiteDatabase.java:1118) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteQueryBuilder.query(SQLiteQueryBuilder.java:312) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.database.sqlite.SQLiteQueryBuilder.query(SQLiteQueryBuilder.java:262) 01-31 03:09:30.686 E/DatabaseUtils( 143): at com.android.providers.contacts.ContactsProvider.queryInternal(ContactsProvider.java:4789) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.content.AbstractSyncableContentProvider.query(AbstractSyncableContentProvider.java:359) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.content.ContentProvider$Transport.bulkQuery(ContentProvider.java:112) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.content.ContentProviderNative.onTransact(ContentProviderNative.java:97) 01-31 03:09:30.686 E/DatabaseUtils( 143): at android.os.Binder.execTransact(Binder.java:287) 01-31 03:09:30.686 E/DatabaseUtils( 143): at dalvik.system.NativeStart.run(Native Method) 01-31 03:09:30.686 E/AndroidRuntime( 143): Crash logging skipped, already logging another crash 01-31 03:09:30.746 W/dalvikvm( 1109): threadid=39: thread exiting with uncaught exception (group=0x40013140) 01-31 03:09:30.746 E/AndroidRuntime( 1109): Uncaught handler: thread Thread-24 exiting due to uncaught exception 01-31 03:09:30.796 E/DatabaseUtils( 1109): Writing exception to parcel 01-31 03:09:30.796 E/DatabaseUtils( 1109): android.database.sqlite.SQLiteException: unrecognized token: "'": , while compiling: SELECT phones.person AS person FROM people, phones WHERE (phones.person=people._id AND PHONE_NUMBERS_EQUAL(phones.number, '�9215888���')) ORDER BY name ASC 01-31 03:09:30.796 E/DatabaseUtils( 1109): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:143) 01-31 03:09:30.796 E/DatabaseUtils( 1109): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:111) 01-31 03:09:30.796 E/DatabaseUtils( 1109): at android.content.ContentProviderProxy.bulkQuery(ContentProviderNative.java:279) 01-31 03:09:30.796 E/DatabaseUtils( 1109): at android.content.ContentProviderProxy.query(ContentProviderNative.java:298) 01-31 03:09:30.796 E/DatabaseUtils( 1109): at android.content.ContentResolver.query(ContentResolver.java:149) 01-31 03:09:30.796 E/DatabaseUtils( 1109): at com.android.providers.telephony.SmsProvider.insert(SmsProvider.java:481) 01-31 03:09:30.796 E/DatabaseUtils( 1109): at android.content.ContentProvider$Transport.insert(ContentProvider.java:140) 01-31 03:09:30.796 E/DatabaseUtils( 1109): at android.content.ContentProviderNative.onTransact(ContentProviderNative.java:125) 01-31 03:09:30.796 E/DatabaseUtils( 1109): at android.os.Binder.execTransact(Binder.java:287) 01-31 03:09:30.796 E/DatabaseUtils( 1109): at dalvik.system.NativeStart.run(Native Method) 01-31 03:09:30.846 E/AndroidRuntime( 1109): android.database.sqlite.SQLiteException: unrecognized token: "'": , while compiling: SELECT type, notes, last_time_contacted, name, times_contacted, primary_organization, send_to_voicemail, GET_PHONETICALLY_SORTABLE_STRING(CASE WHEN (phonetic_name IS NOT NULL AND phonetic_name != '') THEN phonetic_name ELSE (CASE WHEN (name is NOT NULL AND name != '')THEN name ELSE (CASE WHEN primary_email IS NOT NULL THEN (SELECT data FROM contact_methods WHERE contact_methods._id = primary_email) ELSE (CASE WHEN primary_phone IS NOT NULL THEN (SELECT number FROM phones WHERE phones._id = primary_phone) ELSE null END) END) END) END) AS sort_string, number, primary_email, default_action, primary_phone, number_key, extra_group, label, (CASE WHEN (name IS NOT NULL AND name != '') THEN name ELSE (CASE WHEN primary_organization is NOT NULL THEN (SELECT company FROM organizations WHERE organizations._id = primary_organization) ELSE (CASE WHEN primary_phone IS NOT NULL THEN (SELECT number FROM phones WHERE phones._id = primary_phone) ELSE (CASE WHEN primary_email IS NOT NULL THEN (SELECT data FROM contact_methods WHERE contact_methods._id = primary_email) ELSE null END) END) END) END) AS display_name, phonetic_name, isprimary, picasaUrl, lastName, pureNumber, last_update_time, custom_ringtone, starred, phones._id AS _id, firstName, phones.person AS person FROM people, phones WHERE (phones.person=people._id AND PHONE_NUMBERS_EQUAL(phones.number, '�9215888���')) ORDER BY name ASC 01-31 03:09:30.846 E/AndroidRuntime( 1109): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:143) 01-31 03:09:30.846 E/AndroidRuntime( 1109): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:111) 01-31 03:09:30.846 E/AndroidRuntime( 1109): at android.content.ContentProviderProxy.bulkQuery(ContentProviderNative.java:279) 01-31 03:09:30.846 E/AndroidRuntime( 1109): at android.content.ContentProviderProxy.query(ContentProviderNative.java:298) 01-31 03:09:30.846 E/AndroidRuntime( 1109): at android.content.ContentResolver.query(ContentResolver.java:149) 01-31 03:09:30.846 E/AndroidRuntime( 1109): at com.android.internal.telephony.CallerInfo.getCallerInfo(CallerInfo.java:415) 01-31 03:09:30.846 E/AndroidRuntime( 1109): at com.android.internal.telephony.CallerInfo.getCallerInfo(CallerInfo.java:494) 01-31 03:09:30.846 E/AndroidRuntime( 1109): at com.android.internal.telephony.CallerInfo.getCallerId(CallerInfo.java:536) 01-31 03:09:30.846 E/AndroidRuntime( 1109): at android.provider.Telephony$Mms.getDisplayAddress(Telephony.java:1659) 01-31 03:09:30.846 E/AndroidRuntime( 1109): at com.android.providers.telephony.SmsProvider$1.run(SmsProvider.java:456) 01-31 03:09:30.846 E/AndroidRuntime( 1109): at java.lang.Thread.run(Thread.java:1058) 01-31 03:09:30.856 I/Process ( 103): Sending signal. PID: 1109 SIG: 3 01-31 03:09:30.856 I/dalvikvm( 1109): threadid=7: reacting to signal 3 01-31 03:09:30.856 D/CIQ ( 103): throwUI03 01-31 03:09:30.866 D/CIQ ( 103): processName com.android.phone 01-31 03:09:31.346 I/AlertDialog( 103): [onCreate] auto launch SIP. 01-31 03:09:31.396 I/WindowManager( 103): Screen status=false, current orientation=1, SensorEnabled=false 01-31 03:09:31.436 D/SurfaceFlinger( 103): About to give-up screen, flinger = 0x1afcd0 01-31 03:09:31.436 D/CIQ ( 103): throwUI02 01-31 03:09:31.436 D/CIQ ( 103): UI02 01-31 03:09:31.446 D/PhoneWindow( 103): DebugMonitor class=com.android.server.am.AppErrorDialog focus=true 01-31 03:09:31.476 D/Widget ( 151): onNotifyWidgetPause for class com.htc.WeatherClockWidget.WeatherClockWidgetView, diff = 1 01-31 03:09:31.536 D/KeyguardViewMediator( 103): screen is locked 01-31 03:09:31.546 D/PhoneWindow( 151): DebugMonitor class=com.htc.launcher.Launcher focus=false 01-31 03:09:31.626 E/SqliteWrapper( 1124): Catch a SQLiteException when insert: 01-31 03:09:31.626 E/SqliteWrapper( 1124): android.database.sqlite.SQLiteException: unrecognized token: "'": , while compiling: SELECT phones.person AS person FROM people, phones WHERE (phones.person=people._id AND PHONE_NUMBERS_EQUAL(phones.number, '�9215888���')) ORDER BY name ASC 01-31 03:09:31.626 E/SqliteWrapper( 1124): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:143) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:111) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at android.content.ContentProviderProxy.insert(ContentProviderNative.java:340) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at android.content.ContentResolver.insert(ContentResolver.java:476) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at com.google.android.mms.util.SqliteWrapper.insert(SqliteWrapper.java:141) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at com.android.mms.transaction.SmsReceiverService.storeMessage(SmsReceiverService.java:858) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at com.android.mms.transaction.SmsReceiverService.insertMessage(SmsReceiverService.java:743) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at com.android.mms.transaction.SmsReceiverService.handleSmsReceived(SmsReceiverService.java:670) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at com.android.mms.transaction.SmsReceiverService.access$200(SmsReceiverService.java:92) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at com.android.mms.transaction.SmsReceiverService$ServiceHandler.handleMessage(SmsReceiverService.java:245) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at android.os.Handler.dispatchMessage(Handler.java:99) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at android.os.Looper.loop(Looper.java:123) 01-31 03:09:31.626 E/SqliteWrapper( 1124): at android.os.HandlerThread.run(HandlerThread.java:60) 01-31 03:09:31.636 I/DumpStateReceiver( 103): Added state dump to 3 crashes 01-31 03:09:31.676 W/dalvikvm( 1124): threadid=21: thread exiting with uncaught exception (group=0x40013140) 01-31 03:09:31.676 E/AndroidRuntime( 1124): Uncaught handler: thread SmsReceiverService exiting due to uncaught exception 01-31 03:09:31.676 E/AndroidRuntime( 1124): android.database.sqlite.SQLiteException: unrecognized token: "'": , while compiling: SELECT phones.person AS person FROM people, phones WHERE (phones.person=people._id AND PHONE_NUMBERS_EQUAL(phones.number, '�9215888���')) ORDER BY name ASC 01-31 03:09:31.676 E/AndroidRuntime( 1124): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:143) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:111) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at android.content.ContentProviderProxy.insert(ContentProviderNative.java:340) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at android.content.ContentResolver.insert(ContentResolver.java:476) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at com.google.android.mms.util.SqliteWrapper.insert(SqliteWrapper.java:141) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at com.android.mms.transaction.SmsReceiverService.storeMessage(SmsReceiverService.java:858) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at com.android.mms.transaction.SmsReceiverService.insertMessage(SmsReceiverService.java:743) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at com.android.mms.transaction.SmsReceiverService.handleSmsReceived(SmsReceiverService.java:670) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at com.android.mms.transaction.SmsReceiverService.access$200(SmsReceiverService.java:92) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at com.android.mms.transaction.SmsReceiverService$ServiceHandler.handleMessage(SmsReceiverService.java:245) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at android.os.Handler.dispatchMessage(Handler.java:99) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at android.os.Looper.loop(Looper.java:123) 01-31 03:09:31.676 E/AndroidRuntime( 1124): at android.os.HandlerThread.run(HandlerThread.java:60) 01-31 03:09:31.726 I/Process ( 103): Sending signal. PID: 1124 SIG: 3 01-31 03:09:31.726 I/dalvikvm( 1124): threadid=7: reacting to signal 3 01-31 03:09:31.816 D/CIQ ( 103): throwUI03 01-31 03:09:31.856 D/CIQ ( 103): processName com.android.mms 01-31 03:09:32.486 D/HtcLockScreen( 103): onScreenRestart 01-31 03:09:32.496 I/HtcLockScreen( 103): HtcLockScreen:onResume 01-31 03:09:32.506 D/HtcLockScreen( 103): onScreenRestart-load wallpaper 01-31 03:09:32.506 I/HtcLockScreen( 103): loadWallpaper 01-31 03:09:32.516 D/LockPatternView( 103): heightSpecSize 455 widthSpecSize 320 01-31 03:09:32.536 I/WindowManager( 103): Screen status=false, current orientation=5, SensorEnabled=false 01-31 03:09:32.677 I/HtcLockScreen( 103): loadImage -/data/misc/lockscreen/D_lock_screen_port,realpath -/system/etc/lockscreen/port/htc_wallpaper_01_lockscreen.jpg 01-31 03:09:32.677 I/HtcLockScreen( 103): loadWallpaper = result=1 01-31 03:09:32.926 D/KeyguardViewMediator( 103): wakeWhenReadyLocked(6) 01-31 03:09:32.926 D/KeyguardViewMediator( 103): handleWakeWhenReady(6) 01-31 03:09:32.926 D/KeyguardViewMediator( 103): pokeWakelock(15000) 01-31 03:09:32.956 I/WindowManager( 103): Screen status=true, current orientation=5, SensorEnabled=false 01-31 03:09:32.956 I/WindowManager( 103): needSensorRunningLp, mCurrentAppOrientation =5 01-31 03:09:32.956 I/WindowManager( 103): needSensorRunningLp, SCREEN_ORIENTATION_NOSENSOR 01-31 03:09:32.956 I/HtcLockScreen( 103): HtcLockScreen:onResume 01-31 03:09:32.956 D/KeyInputQueue( 103): DebugMonitor keycode=6 value=1 01-31 03:09:32.966 D/Rosie ( 151): onResume() [onRestoreInstanceState] : diff - 0 01-31 03:09:32.996 D/CIQ ( 103): throwUI02 01-31 03:09:32.996 D/CIQ ( 103): UI02 01-31 03:09:33.046 D/KeyInputQueue( 103): DebugMonitor keycode=6 value=0 01-31 03:09:33.126 I/DumpStateReceiver( 103): Added state dump to 2 crashes 01-31 03:09:33.136 I/AlertDialog( 103): [onCreate] auto launch SIP. 01-31 03:09:33.216 D/PhoneWindow( 103): DebugMonitor class=com.android.server.am.AppErrorDialog focus=false 01-31 03:09:33.236 D/HardwareService( 103): setScreenAuto,on=true 01-31 03:09:33.236 D/SETTING_AUTO_BACKLIGHT( 103): +setting_autobacklight_item: 1 01-31 03:09:33.326 D/CDMA ( 1109): update CDMA location information 01-31 03:09:33.336 D/SurfaceFlinger( 103): Screen about to return, flinger = 0x1afcd0 01-31 03:09:33.436 D/HtcCdmaDataControl( 1109): Carrier=3 01-31 03:09:33.436 D/HtcCdmaDataControl( 1109): ERI value=1 01-31 03:09:33.436 D/HtcCdmaDataControl( 1109): ERI data guard=0 01-31 03:09:33.496 D/HtcCdmaDataControl( 1109): PriCtrl=false, PriResult=false, for type=ALLOW_SETUP, ERIid=1->1, ERIguard=0->0, UsrRoamAllow=true, UsrGuard=0, UsrAccept=false, conntd=false 01-31 03:09:33.516 D/CDMA ( 1109): send cell location intent 01-31 03:09:33.526 D/HtcCdmaDataControl( 1109): Update conntd=false 01-31 03:09:33.536 D/HtcCdmaDataControl( 1109): Disabled by connMgr 01-31 03:09:33.556 D/LocationManagerService( 103): CDMA Cell latitude: 28.89847222222222 longitude: 76.59645833333333 01-31 03:09:33.999 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:09:34.006 D/KeyguardViewMediator( 103): pokeWakelock(15000) 01-31 03:09:34.166 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:09:34.166 D/WeatherClockWidget( 151): MSG_REFETCH_CACHEDATA 01-31 03:09:34.176 D/WeatherClockWidget( 151): Query Weather data by Latitude: 28.895950, Longitude: 76.612297 01-31 03:09:34.176 W/WeatherUtil( 151): schedule DCS task, mixed quest code 01-31 03:09:34.176 D/WeatherUtil( 151): DCS service connected, schedule task mixed quest code of AccuWeather and Geocode together 01-31 03:09:34.176 D/WeatherUtil( 151): Download weather data under ROAMING 01-31 03:09:34.196 D/KeyguardViewMediator( 103): pokeWakelock(15000) 01-31 03:09:34.196 I/HtcLockScreen( 103): MotionEvent.UP:mStartUnlockY=377,mRealStartY=377,start=415,endY=479 01-31 03:09:34.196 D/HtcLockScreen( 103): unlock animationn done 01-31 03:09:34.196 I/DCS ( 183): [DCS] Schedule, key[android.app.ApplicationContext10078] componentCode[DCSWeatherService] period[10800000] cache[10800000] params[1] roaming[1] 01-31 03:09:34.296 V/DCS ( 183): [DCS] bind component DCSWeatherService for android.app.ApplicationContext10078, system result: true 01-31 03:09:34.356 I/HtcLockScreen( 103): Drag down to unlock screen 01-31 03:09:34.366 D/KeyguardViewMediator( 103): screen is unlocked. 01-31 03:09:34.366 I/ActivityManager( 103): Stopping service: com.htc.dcs.service.weather/.WeatherService 01-31 03:09:34.376 I/HtcLockScreen( 103): HtcLockScreen:onPause 01-31 03:09:34.386 D/HtcLockScreen( 103): onScreenPause 01-31 03:09:34.396 D/Widget ( 151): onNotifyWidgetPause for class com.htc.WeatherClockWidget.WeatherClockWidgetView, diff = 0 01-31 03:09:34.416 I/WindowManager( 103): Screen status=true, current orientation=1, SensorEnabled=false 01-31 03:09:34.416 I/WindowManager( 103): needSensorRunningLp, mCurrentAppOrientation =1 01-31 03:09:34.416 I/WindowManager( 103): needSensorRunningLp, SCREEN_ORIENTATION_PORTRAIT 01-31 03:09:34.416 D/PhoneWindow( 103): DebugMonitor class=com.android.server.am.AppErrorDialog focus=true 01-31 03:09:34.436 V/DCS ( 183): [DCS] unbind component DCSWeatherService for android.app.ApplicationContext10078 01-31 03:09:34.436 I/DCS ( 183): [Fetcher_DCSWeatherService_android.app.ApplicationContext10078_1129389504] Execute client callback-function: android.app.ApplicationContext10078 01-31 03:09:34.536 D/WeatherUtil( 151): receive DCS service callback result 01-31 03:09:35.038 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:09:35.246 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:09:35.706 D/WeatherClockWidget( 151): MSG_REFETCH_CACHEDATA 01-31 03:09:35.706 D/WeatherClockWidget( 151): Query Weather data by Latitude: 28.895950, Longitude: 76.612297 01-31 03:09:35.706 W/WeatherUtil( 151): schedule DCS task, mixed quest code 01-31 03:09:35.706 D/WeatherUtil( 151): DCS service connected, schedule task mixed quest code of AccuWeather and Geocode together 01-31 03:09:35.706 D/WeatherUtil( 151): Download weather data under ROAMING 01-31 03:09:35.716 I/DCS ( 183): [DCS] Schedule, key[android.app.ApplicationContext10078] componentCode[DCSWeatherService] period[10800000] cache[10800000] params[1] roaming[1] 01-31 03:09:35.716 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:09:35.898 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:09:35.926 I/Process ( 1124): Sending signal. PID: 1124 SIG: 9 01-31 03:09:35.936 D/CIQ ( 103): throwUI05 com.android.mms 01-31 03:09:35.936 D/CIQ ( 103): processName com.android.mms 01-31 03:09:35.966 I/ActivityManager( 103): Process com.android.mms (pid 1124) has died. 01-31 03:09:35.966 W/ActivityManager( 103): Scheduling restart of crashed service com.android.mms/.transaction.SmsReceiverService in 5000ms 01-31 03:09:36.026 D/PhoneWindow( 103): DebugMonitor class=com.android.server.am.AppErrorDialog focus=true 01-31 03:09:36.526 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:09:36.666 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:09:36.666 I/Process ( 1109): Sending signal. PID: 1109 SIG: 9 01-31 03:09:36.696 D/CIQ ( 103): throwUI05 com.android.phone 01-31 03:09:36.696 D/CIQ ( 103): processName com.android.phone 01-31 03:09:36.706 D/PhoneWindow( 151): DebugMonitor class=com.htc.launcher.Launcher focus=true 01-31 03:09:36.716 I/ServiceManager( 72): service 'simphonebook' died 01-31 03:09:36.726 I/ServiceManager( 72): service 'isms' died 01-31 03:09:36.726 I/ServiceManager( 72): service 'iphonesubinfo' died 01-31 03:09:36.726 I/ServiceManager( 72): service 'phone' died 01-31 03:09:36.726 I/ActivityManager( 103): Process com.android.phone (pid 1109) has died. 01-31 03:09:36.746 W/InputManagerService( 103): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@43892460 01-31 03:09:36.786 D/BluetoothHeadset( 103): Proxy object disconnected 01-31 03:09:36.886 W/ActivityManager( 103): Service crashed 2 times, stopping: ServiceRecord{4392eec0 com.android.dmportread/.DMCommandService} 01-31 03:09:36.886 W/ActivityManager( 103): Service crashed 2 times, stopping: ServiceRecord{437e5720 com.htc.android.iqrd/.IqService} 01-31 03:09:36.886 W/ActivityManager( 103): Service crashed 2 times, stopping: ServiceRecord{43723010 com.htc.memory/.MemMonitorService} 01-31 03:09:36.886 W/ActivityManager( 103): Service crashed 2 times, stopping: ServiceRecord{43712158 com.android.phone/.NetworkQueryService} 01-31 03:09:36.886 W/ActivityManager( 103): Service crashed 2 times, stopping: ServiceRecord{43684e88 com.android.phone/.BluetoothHeadsetService} 01-31 03:09:37.016 I/ActivityManager( 103): Start proc com.android.phone for restart com.android.phone: pid=1494 uid=1001 gids={3002, 3001, 3003} 01-31 03:09:37.016 D/CIQ ( 103): throwUI04 com.android.phone 01-31 03:09:37.016 D/CIQ ( 103): processName com.android.phone 01-31 03:09:37.166 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:09:37.346 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:09:37.446 D/Widget ( 151): onNotifyWidgetPause for class com.htc.WeatherClockWidget.WeatherClockWidgetView, diff = 0 01-31 03:09:38.246 I/ActivityThread( 1494): Publishing provider qtext: com.android.providers.telephony.QTextProvider 01-31 03:09:38.336 I/ActivityThread( 1494): Publishing provider search: com.android.providers.telephony.SearchdbProvider 01-31 03:09:38.336 I/ActivityThread( 1494): Publishing provider mms: com.android.providers.telephony.MmsProvider 01-31 03:09:38.366 I/ActivityThread( 1494): Publishing provider sms: com.android.providers.telephony.SmsProvider 01-31 03:09:38.396 I/ActivityThread( 1494): Publishing provider cbchannels: com.android.providers.telephony.CBProvider 01-31 03:09:38.426 I/ActivityThread( 1494): Publishing provider telephony: com.android.providers.telephony.TelephonyProvider 01-31 03:09:38.456 I/ActivityThread( 1494): Publishing provider sim: com.android.phone.SimProvider 01-31 03:09:38.496 I/ActivityThread( 1494): Publishing provider mms-sms: com.android.providers.telephony.MmsSmsProvider 01-31 03:09:39.126 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:09:39.306 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:09:39.716 D/HtcCdmaDataControl( 1494): Pri timeout=120000 01-31 03:09:40.266 D/dalvikvm( 103): GC freed 13497 objects / 836392 bytes in 519ms 01-31 03:09:40.266 I/ActivityManager( 103): Starting activity: Intent { action=android.intent.action.MAIN categories={android.intent.category.LAUNCHER} flags=0x10200000 comp={com.xtralogic.android.logcollector/com.xtralogic.android.logcollector.SendLogActivity} } 01-31 03:09:40.446 D/HtcCdmaDataControl( 1494): Initialized 01-31 03:09:40.456 W/CDMA ( 1494): install exit emergency cmd observer 01-31 03:09:40.476 I/ActivityManager( 103): Start proc com.xtralogic.android.logcollector for activity com.xtralogic.android.logcollector/.SendLogActivity: pid=1505 uid=10063 gids={1007} 01-31 03:09:40.476 D/CIQ ( 103): throwUI04 com.xtralogic.android.logcollector 01-31 03:09:40.476 D/CIQ ( 103): processName com.xtralogic.android.logcollector 01-31 03:09:40.826 D/PhoneWindow( 151): DebugMonitor class=com.htc.launcher.Launcher focus=false 01-31 03:09:41.416 W/Rosie ( 151): mAddHtcWidgetByOtherActivity = false, mIsOpenSlideWhenLeaveLaunch = true 01-31 03:09:41.666 I/ActivityManager( 103): Start proc com.android.mms for service com.android.mms/.transaction.SmsReceiverService: pid=1516 uid=10029 gids={3003} 01-31 03:09:41.666 D/CIQ ( 103): throwUI04 com.android.mms 01-31 03:09:41.666 D/CIQ ( 103): processName com.android.mms 01-31 03:09:41.776 V/DCS ( 183): [DCS] bind component DCSWeatherService for android.app.ApplicationContext10078, system result: true 01-31 03:09:41.846 D/dalvikvm( 1494): GC freed 2550 objects / 163224 bytes in 399ms 01-31 03:09:41.886 E/BluetoothHandsfree.java( 1494): updatePhoneState() 01-31 03:09:41.916 E/BluetoothHandsfree.java( 1494): Registering Handsfree AT commands 01-31 03:09:42.056 I/AlertDialog( 1505): [onCreate] auto launch SIP. 01-31 03:09:42.676 D/SensorManager( 1494): found sensor: BMA150 3-axis Accelerometer, handle=0 01-31 03:09:42.676 D/SensorManager( 1494): found sensor: AK8973 3-axis Magnetic field sensor, handle=1 01-31 03:09:42.676 D/SensorManager( 1494): found sensor: AK8973 Orientation sensor, handle=2 01-31 03:09:42.676 D/SensorManager( 1494): found sensor: AK8973 Temperature sensor, handle=3 01-31 03:09:42.726 W/ActivityManager( 103): Unable to start service Intent { action=com.android.ussd.IExtendedNetworkService }: not found 01-31 03:09:42.806 D/PhoneApp( 1494): Resetting audio state/mode: IDLE 01-31 03:09:42.866 W/dalvikvm( 1516): Refusing to reopen boot DEX '/system/framework/com.htc.android.pimlib.jar' 01-31 03:09:43.186 D/PhoneWindow( 1505): DebugMonitor class=android.app.AlertDialog focus=true 01-31 03:09:43.926 D/dalvikvm( 1494): GC freed 1286 objects / 101376 bytes in 349ms 01-31 03:09:45.226 D/dalvikvm( 1494): GC freed 351 objects / 29696 bytes in 241ms 01-31 03:09:45.476 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=1 01-31 03:09:45.646 D/KeyInputQueue( 103): DebugMonitor keycode=0 value=0 01-31 03:09:45.936 V/MmsProvider( 1494): Delete uri=content://mms/drm, match=17 01-31 03:09:46.506 I/ActivityManager( 103): Stopping service: com.htc.dcs.service.weather/.WeatherService 01-31 03:09:46.756 V/DCS ( 183): [DCS] unbind component DCSWeatherService for android.app.ApplicationContext10078 01-31 03:09:46.756 I/DCS ( 183): [Fetcher_DCSWeatherService_android.app.ApplicationContext10078_1129228672] Execute client callback-function: android.app.ApplicationContext10078 01-31 03:09:47.156 D/WeatherUtil( 151): receive DCS service callback result 01-31 03:09:47.626 D/dalvikvm( 103): GC freed 6306 objects / 294064 bytes in 475ms 01-31 03:09:47.726 I/AlertDialog( 1505): [onCreate] auto launch SIP. 01-31 03:09:47.776 D/HtcCdmaPhoneApp( 1494): call_feature_setting=2130968576 01-31 03:09:47.776 D/HtcCdmaPhoneApp( 1494): call_feature_setting_desirec=2130968577 01-31 03:09:47.776 D/HtcCdmaPhoneApp( 1494): call_feature_setting_hero=2130968578 01-31 03:09:47.776 D/HtcCdmaPhoneApp( 1494): call_feature_setting_heroc=2130968579 01-31 03:09:47.776 D/HtcCdmaPhoneApp( 1494): carrier_select=2130968580 01-31 03:09:47.776 D/HtcCdmaPhoneApp( 1494): cell_broadcast_setting=2130968581 01-31 03:09:47.776 D/HtcCdmaPhoneApp( 1494): fdn_setting=2130968582 01-31 03:09:47.776 D/HtcCdmaPhoneApp( 1494): manual_carrier_select=2130968583 01-31 03:09:47.776 D/HtcCdmaPhoneApp( 1494): mip_error=2130968584 01-31 03:09:47.946 D/HtcCdmaModifier( 1494): Runtime Get data service type=2 01-31 03:09:48.106 D/LocationManagerService( 103): Unavailable 01-31 03:09:48.136 D/PhoneWindow( 1505): DebugMonitor class=android.app.ProgressDialog focus=true 01-31 03:09:48.386 D/CDMA ( 1494): Not in service! Can't update location! 01-31 03:09:48.426 D/MobileDataStateTracker( 103): Received android.intent.action.ANY_DATA_STATE broadcast - state = DISCONNECTED, unavailable = true, reason = networkTypeChangedapn=null, capability=null 01-31 03:09:48.426 D/GpsLocationProvider( 103): state: DISCONNECTED apnName: null reason: networkTypeChanged 01-31 03:09:48.426 D/libgps ( 103): qct_gps_set_apn: 01-31 03:09:48.456 D/MobileDataStateTracker( 103): Received android.intent.action.ANY_DATA_STATE broadcast - state = DISCONNECTED, unavailable = true, reason = gprsDetachedapn=null, capability=null 01-31 03:09:48.456 D/GpsLocationProvider( 103): state: DISCONNECTED apnName: null reason: gprsDetached 01-31 03:09:48.456 D/libgps ( 103): qct_gps_set_apn: 01-31 03:09:48.526 I/ActivityManager( 103): Displayed activity com.xtralogic.android.logcollector/.SendLogActivity: 8265 ms 01-31 03:09:48.596 D/HtcCdmaDataControl( 1494): user data guard=0 01-31 03:09:48.616 D/HtcCdmaDataControl( 1494): emergency=false 01-31 03:09:48.676 D/HtcCdmaDataControl( 1494): data guard user response=-1 01-31 03:09:48.686 D/HtcCdmaDataControl( 1494): testing no network=false 01-31 03:09:48.716 D/SIMStateChangeReceiver( 143): hasSetupWizRun = 1 01-31 03:09:48.746 D/HtcCdmaDataControl( 1494): provision=1 01-31 03:09:48.746 V/AutoSettingReceiver( 143): AutoSettingReceiver onReceive() : android.intent.action.SIM_STATE_CHANGED 01-31 03:09:48.756 D/CDMA ( 1494): exit emergency cmd=false 01-31 03:09:48.776 D/HtcCdmaPowerSave( 1494): exit power save=false 01-31 03:09:48.786 D/HtcCdmaModifier( 1494): AutoPrepend Setting=1 01-31 03:09:48.786 D/HtcCdmaModifier( 1494): data service type=2 01-31 03:09:48.806 I/GETMDN ( 1494): EVENT_RADIO_STATE_CHANGED 01-31 03:09:48.806 I/GETMDN ( 1494): GetCDMAPhoneInfo 01-31 03:09:48.806 I/GETMDN ( 1494): Thread create to get MEID and MDN 01-31 03:09:48.946 V/android_bluetooth_AG.cpp( 1494): classInitNative 01-31 03:09:48.946 V/android_bluetooth_AG.cpp( 1494): initializeNativeDataNative 01-31 03:09:49.046 I/global ( 1505): Default buffer size used in BufferedReader constructor. It would be better to be explicit if an 8k-char buffer is required. 01-31 03:09:49.136 E/android_bluetooth_AG.cpp( 1494): AG initial success 01-31 03:09:49.266 E/BluetoothHeadsetService( 1494): Starting BluetoothHeadsetService 01-31 03:09:49.276 D/CallNotifier( 1494): onMwiChanged(): 0 01-31 03:09:49.286 D/PhoneApp( 1494): ACTION_SIM_STATE_CHANGED:LOADED 01-31 03:09:49.296 D/HtcCdmaPhoneApp( 1494): voice privacy setting=1 01-31 03:09:49.306 D/HtcCdmaPhoneApp( 1494): voice privacy status=-1 01-31 03:09:49.306 D/HtcCdmaPhoneApp( 1494): emergency=false 01-31 03:09:49.306 D/HtcCdmaPhoneApp( 1494): eri roaming ring=0 01-31 03:09:49.316 D/HtcCdmaPhoneApp( 1494): setting roaming ring=1 01-31 03:09:49.316 D/HtcCdmaPhoneApp( 1494): Try connect CIQ 2479 01-31 03:09:49.416 I/HtcCdmaPhoneApp( 1494): listen CIQ 01-31 03:09:49.496 D/HtcCdmaPhoneApp( 1494): loopback mode=false 01-31 03:09:49.506 D/HtcCdmaPhoneApp( 1494): data roam guard=0 01-31 03:09:49.506 D/HtcCdmaPhoneApp( 1494): ota=0 01-31 03:09:49.506 D/HtcCdmaPhoneApp( 1494): DR= 01-31 03:09:49.536 D/HtcCdmaPhoneApp( 1494): NetBusy=-1 01-31 03:09:49.556 D/HtcCdmaPhoneApp( 1494): Intercept=-1 01-31 03:09:49.556 D/HtcCdmaPhoneApp( 1494): Reorder=-1 01-31 03:09:49.556 D/HtcCdmaPhoneApp( 1494): CdmaTone=-1 01-31 03:09:49.566 D/HtcCdmaPhoneApp( 1494): MIP cause code=-1 01-31 03:09:49.566 D/HtcCdmaPhoneApp( 1494): SignalFad=-1 01-31 03:09:49.566 V/MmsProvider( 1494): Delete uri=content://mms/9223372036854775807/part, match=11 01-31 03:09:49.576 D/HtcCdmaPhoneApp( 1494): RoamIcon=1 01-31 03:09:49.616 D/CDMA ( 1494): Not in service! Can't update location! 01-31 03:09:49.616 I/GETMDN ( 1494): EVENT_RADIO_STATE_CHANGED 01-31 03:09:49.616 I/GETMDN ( 1494): GetCDMAPhoneInfo 01-31 03:09:49.616 I/GETMDN ( 1494): Thread create to get MEID and MDN 01-31 03:09:49.696 D/CDMA ( 1494): Not in service! Can't update location! 01-31 03:09:49.696 D/HtcCdmaPhoneApp( 1494): RoamAlert=0 01-31 03:09:49.976 D/CDMA ( 1494): Not in service! Can't update location! 01-31 03:09:49.976 I/GETMDN ( 1494): EVENT_RADIO_STATE_CHANGED 01-31 03:09:49.976 I/GETMDN ( 1494): GetCDMAPhoneInfo 01-31 03:09:49.976 I/GETMDN ( 1494): Thread create to get MEID and MDN 01-31 03:09:50.126 D/CDMA ( 1494): Not in service! Can't update location! 01-31 03:09:50.166 D/SIMStateChangeReceiver( 143): hasSetupWizRun = 1 01-31 03:09:50.206 V/AutoSettingReceiver( 143): AutoSettingReceiver onReceive() : android.intent.action.SIM_STATE_CHANGED 01-31 03:09:50.306 D/PhoneApp( 1494): ACTION_SIM_STATE_CHANGED:NOT_READY 01-31 03:09:50.366 D/CDMA ( 1494): Not in service! Can't update location! 01-31 03:09:50.426 D/PhoneApp( 1494): connection created, binding local service. 01-31 03:09:50.426 D/HtcCdmaPhoneApp( 1494): Roaming alert : false -> false 01-31 03:09:50.426 I/PhoneApp( 1494): EVENT_RADIO_ON IN 01-31 03:09:50.426 I/PhoneApp( 1494): getCDMATTYValue IN 01-31 03:09:50.446 D/HtcCdmaPhoneApp( 1494): Roaming alert : false -> false 01-31 03:09:50.516 D/CDMA ( 1494): Not in service! Can't update location! 01-31 03:09:50.566 D/CDMA ( 1494): Not in service! Can't update location! 01-31 03:09:50.576 D/HtcCdmaDataControl( 1494): Carrier=3 01-31 03:09:50.576 D/HtcCdmaDataControl( 1494): ERI value=1 01-31 03:09:50.576 D/HtcCdmaDataControl( 1494): ERI data guard=0 01-31 03:09:50.616 D/HtcCdmaDataControl( 1494): PriCtrl=false, PriResult=false, for type=ALLOW_SETUP, ERIid=1->1, ERIguard=0->0, UsrRoamAllow=true, UsrGuard=0, UsrAccept=false, conntd=false 01-31 03:09:50.666 D/CDMA ( 1494): Not in service! Can't update location! 01-31 03:09:50.686 D/dalvikvm( 1505): GC freed 1812 objects / 226928 bytes in 629ms 01-31 03:09:50.696 D/HtcCdmaDataControl( 1494): Carrier=3 01-31 03:09:50.696 D/HtcCdmaDataControl( 1494): ERI value=1 01-31 03:09:50.696 D/HtcCdmaDataControl( 1494): ERI data guard=0 01-31 03:09:50.726 D/HtcCdmaDataControl( 1494): PriCtrl=false, PriResult=false, for type=ALLOW_SETUP, ERIid=1->1, ERIguard=0->0, UsrRoamAllow=true, UsrGuard=0, UsrAccept=false, conntd=false 01-31 03:09:50.736 D/PhoneApp( 1494): ACTION_SIM_STATE_CHANGED:READY 01-31 03:09:50.736 D/CallNotifier( 1494): onMwiChanged(): 0 01-31 03:09:50.816 D/SIMStateChangeReceiver( 143): hasSetupWizRun = 1 01-31 03:09:50.826 V/AutoSettingReceiver( 143): AutoSettingReceiver onReceive() : android.intent.action.SIM_STATE_CHANGED 01-31 03:09:50.936 D/HtcCdmaDataControl( 1494): Carrier=3 01-31 03:09:50.936 D/HtcCdmaDataControl( 1494): ERI value=1 01-31 03:09:50.936 D/HtcCdmaDataControl( 1494): ERI data guard=0 01-31 03:09:50.956 D/HtcCdmaDataControl( 1494): PriCtrl=false, PriResult=false, for type=ALLOW_SETUP, ERIid=1->1, ERIguard=0->0, UsrRoamAllow=true, UsrGuard=0, UsrAccept=false, conntd=false 01-31 03:09:50.986 D/PhoenApp( 1494): QUERY_MT_INFO_TOKEN 01-31 03:09:51.076 D/HtcCdmaDataControl( 1494): Carrier=3 01-31 03:09:51.076 D/HtcCdmaDataControl( 1494): ERI value=1 01-31 03:09:51.076 D/HtcCdmaDataControl( 1494): ERI data guard=0 01-31 03:09:51.116 D/IQSystem( 87): CIQ-106(1112): SendTimesync[65535]: orig:00412CF0CC 01-31 03:09:51.116 D/HtcCdmaDataControl( 1494): PriCtrl=false, PriResult=false, for type=ALLOW_SETUP, ERIid=1->1, ERIguard=0->0, UsrRoamAllow=true, UsrGuard=0, UsrAccept=false, conntd=false 01-31 03:09:51.126 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[65535]: remote:00006FDAF6 01-31 03:09:51.126 D/IQSystem( 87): CIQ-106(1112): SendTimesync[00]: orig:00412CF0D8 01-31 03:09:51.136 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[00]: remote:00006FDB01 01-31 03:09:51.136 D/IQSystem( 87): CIQ-106(1112): SendTimesync[01]: orig:00412CF0E1 01-31 03:09:51.136 D/HtcCdmaDataControl( 1494): Carrier=3 01-31 03:09:51.136 D/HtcCdmaDataControl( 1494): ERI value=1 01-31 03:09:51.136 D/HtcCdmaDataControl( 1494): ERI data guard=0 01-31 03:09:51.146 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[01]: remote:00006FDB0A 01-31 03:09:51.146 D/IQSystem( 87): CIQ-106(1112): SendTimesync[02]: orig:00412CF0EB 01-31 03:09:51.156 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[02]: remote:00006FDB14 01-31 03:09:51.156 D/IQSystem( 87): CIQ-106(1112): SendTimesync[03]: orig:00412CF0F5 01-31 03:09:51.166 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[03]: remote:00006FDB1E 01-31 03:09:51.166 D/IQSystem( 87): CIQ-106(1112): SendTimesync[04]: orig:00412CF0FF 01-31 03:09:51.166 D/HtcCdmaDataControl( 1494): PriCtrl=false, PriResult=false, for type=ALLOW_SETUP, ERIid=1->1, ERIguard=0->0, UsrRoamAllow=true, UsrGuard=0, UsrAccept=false, conntd=false 01-31 03:09:51.176 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[04]: remote:00006FDB28 01-31 03:09:51.176 D/IQSystem( 87): CIQ-106(1112): SendTimesync[05]: orig:00412CF109 01-31 03:09:51.176 D/HtcCdmaDataControl( 1494): Update conntd=false 01-31 03:09:51.186 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[05]: remote:00006FDB32 01-31 03:09:51.186 D/IQSystem( 87): CIQ-106(1112): SendTimesync[06]: orig:00412CF113 01-31 03:09:51.186 D/HtcCdmaDataControl( 1494): Skip due to service state 3 01-31 03:09:51.196 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[06]: remote:00006FDB3C 01-31 03:09:51.196 D/IQSystem( 87): CIQ-106(1112): SendTimesync[07]: orig:00412CF11D 01-31 03:09:51.206 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[07]: remote:00006FDB46 01-31 03:09:51.206 D/IQSystem( 87): CIQ-106(1112): SendTimesync[08]: orig:00412CF127 01-31 03:09:51.216 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[08]: remote:00006FDB50 01-31 03:09:51.216 D/IQSystem( 87): CIQ-106(1112): SendTimesync[09]: orig:00412CF131 01-31 03:09:51.226 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[09]: remote:00006FDB5A 01-31 03:09:51.226 D/IQSystem( 87): CIQ-106(1112): SendTimesync[10]: orig:00412CF13B 01-31 03:09:51.226 D/HtcCdmaDataControl( 1494): Carrier=3 01-31 03:09:51.226 D/HtcCdmaDataControl( 1494): ERI value=1 01-31 03:09:51.226 D/HtcCdmaDataControl( 1494): ERI data guard=0 01-31 03:09:51.236 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[10]: remote:00006FDB64 01-31 03:09:51.236 D/IQSystem( 87): CIQ-106(1112): SendTimesync[11]: orig:00412CF145 01-31 03:09:51.246 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[11]: remote:00006FDB6E 01-31 03:09:51.246 D/IQSystem( 87): CIQ-106(1112): SendTimesync[12]: orig:00412CF14F 01-31 03:09:51.246 D/HtcCdmaDataControl( 1494): PriCtrl=false, PriResult=false, for type=ALLOW_SETUP, ERIid=1->1, ERIguard=0->0, UsrRoamAllow=true, UsrGuard=0, UsrAccept=false, conntd=false 01-31 03:09:51.256 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[12]: remote:00006FDB78 01-31 03:09:51.256 D/IQSystem( 87): CIQ-106(1112): SendTimesync[13]: orig:00412CF159 01-31 03:09:51.266 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[13]: remote:00006FDB82 01-31 03:09:51.266 D/IQSystem( 87): CIQ-106(1112): SendTimesync[14]: orig:00412CF163 01-31 03:09:51.276 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[14]: remote:00006FDB8C 01-31 03:09:51.276 D/IQSystem( 87): CIQ-106(1112): SendTimesync[15]: orig:00412CF16D 01-31 03:09:51.286 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[15]: remote:00006FDB96 01-31 03:09:51.286 D/IQSystem( 87): CIQ-106(1112): SendTimesync[16]: orig:00412CF177 01-31 03:09:51.286 D/HtcCdmaPowerSave( 1494): get creg_increment: 9 01-31 03:09:51.286 D/HtcCdmaPowerSave( 1494): set creg_increment: 10 01-31 03:09:51.286 D/HtcCdmaPowerSave( 1494): set creg_state: 1 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1196): ReceiveTimesync[16]: remote:00006FDBA0 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[00]: orig:00412CF0D8, remote:00006FDB0A after:00412CF0E1 delta:-1086133723 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[01]: orig:00412CF0E1, remote:00006FDB14 after:00412CF0EB delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[02]: orig:00412CF0EB, remote:00006FDB1E after:00412CF0F5 delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[03]: orig:00412CF0F5, remote:00006FDB28 after:00412CF0FF delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[04]: orig:00412CF0FF, remote:00006FDB32 after:00412CF109 delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[05]: orig:00412CF109, remote:00006FDB3C after:00412CF113 delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[06]: orig:00412CF113, remote:00006FDB46 after:00412CF11D delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[07]: orig:00412CF11D, remote:00006FDB50 after:00412CF127 delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[08]: orig:00412CF127, remote:00006FDB5A after:00412CF131 delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[09]: orig:00412CF131, remote:00006FDB64 after:00412CF13B delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[10]: orig:00412CF13B, remote:00006FDB6E after:00412CF145 delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[11]: orig:00412CF145, remote:00006FDB78 after:00412CF14F delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[12]: orig:00412CF14F, remote:00006FDB82 after:00412CF159 delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[13]: orig:00412CF159, remote:00006FDB8C after:00412CF163 delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[14]: orig:00412CF163, remote:00006FDB96 after:00412CF16D delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1164): Timesync[15]: orig:00412CF16D, remote:00006FDBA0 after:00412CF177 delta:-1086133724 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1183): Final ticks offset = 0xFFFFFFFFBF42EA24 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1059): SendTimeCorrelation using actual correlation: 000000DC|AF078968 01-31 03:09:51.296 D/IQSystem( 87): CIQ-106(1793): Got time correlation: 00000000|00000000 Hope this helps in identifing the issue! Share this post Link to post Share on other sites
Sadikk 301 Report post Posted January 30, 2010 Have u installed SMS Pop Up from market?? If not.. try it once.. if its Databse issue.. sms popup shud fetch it for u... lmk.. Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted January 30, 2010 Have u installed SMS Pop Up from market?? If not.. try it once.. if its Databse issue.. sms popup shud fetch it for u... lmk.. Used SMS Popup V 1.0.7 by Adam K. Still no good! Share this post Link to post Share on other sites
Sadikk 301 Report post Posted January 30, 2010 got one friend using it on tata too.. will check with him tomorrow for ya.. Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted February 1, 2010 got one friend using it on tata too.. will check with him tomorrow for ya.. Got Some Info Boss? Share this post Link to post Share on other sites
kshah 452 Report post Posted February 1, 2010 (edited) you may have tried but why dont you check international dial prefix policy settings -> call setting ->plus code dialing -> Check north american dialing and set code to 00 in international dialing. Going to copy paste same at http://www.rimweb.in...55entry173955 Also seems that you are composing MMS not SMS. Edited February 1, 2010 by kshah Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted February 1, 2010 you may have tried but why dont you check international dial prefix policy settings -> call setting ->plus code dialing -> Check north american dialing and set code to 00 in international dialing. Going to copy paste same at http://www.rimweb.in...55entry173955 Also seems that you are composing MMS not SMS. Sir I am composing SMS only... And I am having issues in receiving and not sending. And Will check the Settings again for sure.. Share this post Link to post Share on other sites
