kesav 127 Report post Posted March 13, 2010 Not Correct If you just compare only the tariff leaving out quality and coverage then following is the conclusion. BSNL is the cheapest and you can save huge amount per month in all segment. BSNL is the only operator who has unlimited plan BSNL n/w will be congestion free since BSNL has zero/very little CDMA voice operation MTS is the second best and it beats TATA/VIRGIN/Reliance hands down in any usage level TATA/VIRGIN is cheaper than Reliance in the higher data range (> 5GB) VIRGIN has special 5GB(night) plans which none other operator has Share this post Link to post Share on other sites
npanda 2 Report post Posted March 13, 2010 (edited) What is the cost of BSNL prepaid EVDO ??? Not Correct If you just compare only the tariff leaving out quality and coverage then following is the conclusion. BSNL is the cheapest and you can save huge amount per month in all segment. BSNL is the only operator who has unlimited plan BSNL n/w will be congestion free since BSNL has zero/very little CDMA voice operation MTS is the second best and it beats TATA/VIRGIN/Reliance hands down in any usage level TATA/VIRGIN is cheaper than Reliance in the higher data range (> 5GB) VIRGIN has special 5GB(night) plans which none other operator has Edited March 13, 2010 by npanda Share this post Link to post Share on other sites
suvirajshetty 4 Report post Posted March 14, 2010 in Feb or March End Reliance will have a reach of 70+ Cities Sources : Management Talks !! Your information must be right. Because today i have seen download speed of 80kbps and showing Hybrid on netconnect software. Which is first time in my place (udupi,karnataka) do you get hsd coverage in udupi or any other area near by? Share this post Link to post Share on other sites
