::Hitesh::
Yahoo Invisible Buddy Detectors
If you are annoyed by your yahoo buddies who play hide and seek sometimes then here are few Yahoo Invisible scanners and detectors which will enable you to scan which of your buddy is pretending to be invisible but is actually online.
Use any of the websites below to detect invisible buddies of yahoo.
http://www.yahootracer.com
http://detectinvisible.com
http://www.imvisible.info
http://www.ydetector.com
http://www.invisible-scanner.com
http://www.invisible.ir
http://www.statusdetect.com
http://www.yahdetect...le-scanner.html
http://www.faceboo.im suggested by aurelian marius for multiple ID,
Edited by hitesh123
thnx a lot.. :signthankspin:
any solution for orkut too... i wanna know orkut invisible users.. :Sorprendido:
Orkut is an google service, till date only Gtalk invisible detectors TRICK is known.
look in to this LINK
i use Faceboo! scans multiple ID-s in the same time, hi5 profile also displayed! unfortunately no solution for Orkut user till now!
regards!
Thanks for new addition !
