phonegeek
Problem In Connecting Qxdm To Sprint Hero
Hi Guys,
I am facing this problem :
For the first time when I connected the hero to PC, and dialed ##3424#, it asked for the Diag driver which I successfully installed. At that time, I was also able to use QXDM.
Now whenever I try to connect Hero and use QXDM, it never connects, though in ports, I can see one port as "HTC diagnostic".
I have uninstalled driver also, but all in vain.
I am using Win XP SP 3. QXDM : above 3 version.
Looking forward for your valuable suggestions !
when u connect ur hero to pc
u have to start htc sync everytime for pc to detect ur hero in diag mode
so dial ##3424# connect to pc , from notification bar press on htc sync
Thanks Dr !
I will try this tonight and will report the outcome. I hope this is helpful to some other members also as they are also struggling to connect it to PC.
Dr, done steps according to you but still its not connecting to QXDM. I am able to see HTC Diagnostic Interface(COM12), but no port is coming in the QXDM as target port.
Please help
did u configure the port in qpst configuration
unless u do that qxdm wont show
if ur com port 12 is showing diag interface
then go to qpst configuration
add port
and add com port 12
Also you can try changing the port number (in device manager) from 12 to 1 or 2. or to your old port number
then try to connect to QXDM
Edited by hitesh123
add port
and add com port 12
This worked ! I didnt knew that QPST configuration is required for QXDM. Thanks
One more thing, can I use UniCDMA to take the memory of Hero ?
Edited by saurabh159
qpst is always needed to configure com ports
for taking dumps i had already told u one more trick as well for ur bb , use that
Thanks !
