mitian
My Phone Not Getting Detected
When trying to install the USB controller n the modem
the hardware installation wizard is failing to initialize.. :clap:
So many times i tried plugging in and out my usb cable
no use
it worked sometime ago
but not now
pls help
Mitian
the hardware installation wizard is failing to initialize.. :blink:
no use
but not now
pls help
Mitian
18980[/snapback]
mr.mitian,
i think u need to consult a " hardware engg." any how u can try this for the problem ur discribing:Please follow the procedures for Mobile Phone (USB Cable)
1. DO NOT plug in the cable.
2. Run the Setup file (USB Cable Driver\Setup.exe).
3. Restart the computer after the driver is installed.
4. Plug in the cable.
if this doesn't work probably may me a driver clash in ur windows.so, format the operating system.remove the usb cable from the port and reinstall windows(win98se recommended) or win98se with winxp dual booting. in windows plug back the usb cable.windows will immediately detect usb cable,locate the driver and click next. then run " relianceinstall.exe" in the cd and not the "reliancewizard.exe" just follow user friendly instructions click next.. next and finally it is done.it must solve ur problem if not and ur getting usb cable detecting "unknown cable" it is problem in ur usb cable change it.no need to buy reliance original 1200/- one, get Akasaki usb cable it comes for 250/- and works fine better than the original one :D:clap: c how it is easy
Mitian, please indicate what handset you are using and which OS.i will tell u a procedure to get this done :clap:
just off the phone and on again (reboot ur phone)
now check
