Code
Request A Custom Ringtone/wallpaper For Ur Rim
Read this post carefully before sending a request e-mail:
There are several methods to get a custom ringtone/wallpaper of your choice on your Reliance IndiaMobile phone:
  • Using Bitpim: For most of the reliance mobile models you can upload a ringtone/wallpaper using bitpim or similar software.
    You can read more about it here:
    The biggest Secrets about Reliance phones
  • Self sent Mail to MMS Inbox: If you don't own a datacable or have a model like 2130/5130 with which bitpim doesn't work
    you can send your self an e-mail to recieve it as a MMS containing the ringtone/wallpaper. To know more about it:
    Sending Your Own Ringtones/wallpapers Thru R-world
  • Request Here: Finally some of you might not be familiar with the above or may not have access to a computer to do all that can send an e-mail with the ringtone/wallpaper of your choice attached at:
  • The e-mail should contain:
  • Your phone number (with STD Code if it is not 93 series).
  • Your Name at rimweb.com (to confirm member status).
  • Ringtone or wallpaper as an attachment(Don't zip).
  • Specify if the ringtone or wallpaper is a private content.
  • Ensure that U attach the proper type of ringtone/wallpaper for your phone model*.
  • Maximum of ONE request(upto 3 ringtones) per number. This offer is for a limited time only.
  • Privacy Policy/Disclaimer:
  1. The mails ids(phone number) recieved will be discarded after sending the MMS-Mail and will not be given to other parties etc.
  2. You should explicitly specify if the wallpaper/ringtone is private else it may be shared later for benefit of other rimweb users.
  3. The sender is not responsible for incomplete/distorted/wrong ringtones,MMS not reaching the user or any kind of damage or harm arising out of it or otherwise.
  • * To find out the exact format supported by your phone read this Topic:
Discuss any related issues/information here:
Discuss: Custom Ringones/wallpapers Using MMS
Finally note that this facility CANNOT be used for handsets which donot support R-World or Saving the contents from MMS. e.g Nokia b/w handsets.
Guest
