Manju 0 Report post Posted November 19, 2004 (edited) Hi Do any one know where the Data Cable for LG RD6130 (USB) would be available and its cost/if not suggest the other compatible datacable. Can we install a mobile software on our Cell Phone? Can we send MP3's to our Cell Phones thro Data cable? Thanks. Regards, Manju. Edited November 19, 2004 by Manju Share this post Link to post Share on other sites
Sanay 0 Report post Posted November 20, 2004 Hi Manju, Welcome to RIMWEB. For ur querry, datacab for 6130 is the same that is used for 2230/5130. Its official cost is 1399-.You can get that from WW or LG service centre. I do not think its cheaper versions are available at present in the market. Share this post Link to post Share on other sites
Manju 0 Report post Posted November 20, 2004 Thanks Sanay Connecting with those 2230/5130 datacables to 6130 does it make any problems either to the PC or to the Cell Phone? Share this post Link to post Share on other sites
raccoon 53 Report post Posted November 20, 2004 I belive I saw a non OEM data cable for the LG 5130 on Baazee, yesterday. Obviously, it was priced much less... Check out the stuff there before paying almost 1.5 K for a @&$#! data cable to Reliance. Share this post Link to post Share on other sites
Shabz 8 Report post Posted November 20, 2004 Someone somewhere in this forum had told that the cable for 7130 7230 and 5130 is the same and that person had confirmed it with the LG service centre and maybe it will work with the 6130 also Has anybody tried this well Manju if any of ur friends have these phones u can surely try this and inform us Share this post Link to post Share on other sites
hyper 0 Report post Posted November 21, 2004 i have not tried it with the 6130...but i personally have the 7230 cable & have tries it with the 7130 & 5130..it works with it. i'm guessing that the data cable will work on the 6130 as well as the 6000 Share this post Link to post Share on other sites
verma6uc 0 Report post Posted January 3, 2005 Yes, I have tried it and it works But i have another problem the connection @ my home is very unstable the Rconnect dialer hangs I have tried both 2k and XP But in my office when i try it works fine any help?? Shabz said: Someone somewhere in this forum had told that the cable for 7130 7230 and 5130 is the same and that person had confirmed it with the LG service centre and maybe it will work with the 6130 also Has anybody tried this well Manju if any of ur friends have these phones u can surely try this and inform us 19593[/snapback] Share this post Link to post Share on other sites
Saurav 22 Report post Posted January 4, 2005 even 2030 data cable works. heard from ww not tested. Share this post Link to post Share on other sites
Devesh 0 Report post Posted January 4, 2005 hyper said: i have not tried it with the 6130...but i personally have the 7230 cable & have tries it with the 7130 & 5130..it works with it.i'm guessing that the data cable will work on the 6130 as well as the 6000 19652[/snapback] 5130 and 6000 cables are different. Share this post Link to post Share on other sites
madhumnair 0 Report post Posted February 8, 2005 Are there cheap / duplicate data cables for 6130 available . if so where can I purchase it Share this post Link to post Share on other sites
Azhaga 0 Report post Posted February 14, 2005 It is available with Our shopping area. Check our RIMWEB Shopping @ http://shopping.rimweb.com Share this post Link to post Share on other sites
darth_vader 0 Report post Posted February 15, 2005 6130 connectors are the same as 5130 and the 7150. 2030 connectors are diff.. the cables are avail on baxee for abt 300 bucks + deliv charges Share this post Link to post Share on other sites
