mittu1810 0 Report post Posted March 15, 2010 Hi friends... i just want to know which is the cheap CDMA mobile set which support net connection ( using for laptop connection....???) Share this post Link to post Share on other sites
Venkatagiri 53 Report post Posted March 15, 2010 Hi friends... i just want to know which is the cheap CDMA mobile set which support net connection ( using for laptop connection....???) If you are looking for used set go for Nokia 2112 or 2280 and pay whatever the user asks for. The phones are worth the money. Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted March 15, 2010 does lg 3540 have modem? Share this post Link to post Share on other sites
kshah 452 Report post Posted March 15, 2010 Even Samsung SCH 191 is worth. It had solid data connectivity. Share this post Link to post Share on other sites
raccoon 53 Report post Posted March 15, 2010 (edited) Why not the veteran RD 2030? One of the most reliable phones ever. Edited March 15, 2010 by raccoon Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted March 15, 2010 nokia 2112 is a ****ty phone it has network issues , and in places of less coverage it will give u zero network not only myself but everyone i know who had 2112 faced this issue. Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted March 15, 2010 Yes, I found out that LG 3540 has a modem and works just brilliantly on net connect at 1100 bucks... what more do we want?? Share this post Link to post Share on other sites
konquerror 21 Report post Posted March 15, 2010 ^^^Can LG 3500 be used as modem? If yes, can you tell the settings etc...would be very helpful Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted March 15, 2010 its the same series; may hv the same board; u cud give it a try; i used the micro usb cable of nokia (ca-101); then lg drivers or windows 7 cud download them automatically also; it shud detect it as a modem too; use generic dialer in w7 #777, mdn(username), mdn(password) use the Detected MOdem via Control Panel - Phones and Mode and u r good to go... Share this post Link to post Share on other sites
konquerror 21 Report post Posted March 15, 2010 ^^^Well i tried....it gives error 692...says some problem with hardware... Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted March 15, 2010 i m using spice c810 nearly 24x7. it works like charm !!! set does not heat up also.. but works with data cable only, no bluetooth connectivity as modem !! Share this post Link to post Share on other sites
Hejmady 37 Report post Posted March 16, 2010 I have LG 3540 handset and my PC is on <Windows XP Professional SP3>. my queries: 1. how should i go about setting up "Netconnect" on my PC? 2. What Data Cable to use, price please? 3. Where can i find modem drivers? thanks Share this post Link to post Share on other sites
me_saket 73 Report post Posted March 16, 2010 Yes, I found out that LG 3540 has a modem and works just brilliantly on net connect at 1100 bucks... what more do we want?? new handset @1100??? Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted March 16, 2010 Yes, I found out that LG 3540 has a modem and works just brilliantly on net connect at 1100 bucks... what more do we want?? Kya it works yaar !!! Great !!! But why LG RD 3600 not works, i have tried it says hardware failure like errors when i try to connect it... Share this post Link to post Share on other sites
Hejmady 37 Report post Posted March 17, 2010 As per attached Product-Note of <LG RD3540> there is no modem in this handset. I wonder how Netconnect works! thanks Product Note_RD3540 (Oct\'09).pdf Share this post Link to post Share on other sites
vvinayakpai 26 Report post Posted March 17, 2010 (edited) This phone supports netconnect? But according to the product catalogue it specifically mentions that this phone does not support Netconnect. I have attached the product catalogue for reference. Handset cost in Bangalore is Rs. 1049/= RD3540 Product Note.pdf Edited March 17, 2010 by vvinayakpai Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted March 17, 2010 I have LG 3540 handset and my PC is on <Windows XP Professional SP3>. my queries: 1. how should i go about setting up "Netconnect" on my PC? 2. What Data Cable to use, price please? 3. Where can i find modem drivers? thanks 1) Netconnect setup is like creating any general dial-up connection with Reliance number as user name and password. 2) for LG 3540 use Nokia CA101 or any micro usb cable, cost from Rs 50 to 150 in local market. 3) google it ! Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted March 17, 2010 Hmmm... Well, I was trying to use this phone (LG3540) for some other purpose (finding meid/min of ruim) when I saw that it got detected as a USB Modem also when I installed the drivers. So I presumed it has some sort of hardware for modem on board. It is also showing as LG USB Modem in Device Manager. So it definitely has a modem. Now when I tried to confirm that it is working as modem or not, I could NOT connect to it; Maybe its blocked, or needs some extra initialisation string settings... more research needed... Share this post Link to post Share on other sites
aalok 442 Report post Posted March 17, 2010 the lowest priced handset with Modem (R-Netconnect) enabled is LG RD6200 priced at Rs. 3415.00.. Products specs : http://www.lgmobiles.com/specs/Product%20Note_RD6200%20%20Sep'09.pdf Share this post Link to post Share on other sites
ani_meher 42 Report post Posted March 17, 2010 (edited) Buy the virgin mobile c5000 for about 1.6-2k, and unlock it. Very easy to unlock, just a 5-10 mins affair. Then use whatever card u want for net access! I am using Tata data RUIM in it for past many months. No hiccups whatsoever. Just keep in mind that these are not for heavy downloading, so keeping it on for full night will be harmful for the mobile. You can easily use it for day browsing. nokia 2112 is a ****ty phone it has network issues , and in places of less coverage it will give u zero network not only myself but everyone i know who had 2112 faced this issue. I hear this a lot. But Nokia ruined 2112 quality in later years. My mom uses her 3-4 years 2112 daily, and it is still rock solid, with great coverage. Only battery is changed a month ago. Nokia really screwed up the quality of handsets later on. Edited March 17, 2010 by ani_meher Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted March 17, 2010 Friends I m using Spice C810 on 1x 24x& nearly, it works fine... Otherwise you may go for a net connect modem (USB DATA CARD) for any cdma here : http://cgi.ebay.in/UNLOCK-USB-RUIM-CDMA-EVDO-REVA-WIRELESS-BROADBAND-MODEM_W0QQitemZ250597498827QQihZ015QQcategoryZ8060QQssPageNameZWDVWQQrdZ1QQcmdZViewItem http://cgi.ebay.in/USB-RUIM-UNLOCKED-CDMA-1X-MODEM_W0QQitemZ250596931975QQihZ015QQcategoryZ8060QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Share this post Link to post Share on other sites
me_saket 73 Report post Posted March 17, 2010 As per attached Product-Note of <LG RD3540> there is no modem in this handset. I wonder how Netconnect works! thanks i too wonder, that's why i asked price Buy the virgin mobile c5000 for about 1.6-2k, and unlock it. Very easy to unlock, just a 5-10 mins affair. Then use whatever card u want for net access! I am using Tata data RUIM in it for past many months. No hiccups whatsoever. Just keep in mind that these are not for heavy downloading, so keeping it on for full night will be harmful for the mobile. You can easily use it for day browsing. nokia 2112 is a ****ty phone it has network issues , and in places of less coverage it will give u zero network not only myself but everyone i know who had 2112 faced this issue. I hear this a lot. But Nokia ruined 2112 quality in later years. My mom uses her 3-4 years 2112 daily, and it is still rock solid, with great coverage. Only battery is changed a month ago. Nokia really screwed up the quality of handsets later on. c5000 is i thibk hier, does data cable avbl? Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted March 17, 2010 Guyz guyz , Just checked On corby !!!! Sam1 works like charm with evdo, was getting download speed between 160-200 kbps. Also used simple sim of my dapo , 1x works fine. I m Happy, planning to shift my Dapo on OMH Share this post Link to post Share on other sites
kshah 452 Report post Posted March 18, 2010 Guyz guyz , Just checked On corby !!!! Sam1 works like charm with evdo, was getting download speed between 160-200 kbps. Also used simple sim of my dapo , 1x works fine. I m Happy, planning to shift my Dapo on OMH If your budget permits use hero with daop it will be fun Share this post Link to post Share on other sites
me_saket 73 Report post Posted March 18, 2010 Guyz guyz , Just checked On corby !!!! Sam1 works like charm with evdo, was getting download speed between 160-200 kbps. Also used simple sim of my dapo , 1x works fine. I m Happy, planning to shift my Dapo on OMH I already reported that non OMH sim is working in corby for netconnect/ and won't work for RWORLD. R u getting EVDO speed with sam1 user name??? but even MDN username will also connect to internet, I am confused. Share this post Link to post Share on other sites
