SumitVerma
MTS prl settings
Dear Mods: I Tried to search but found no results. Please Merge if topic already Exists or if I started in wrong place.
I need PRL settings of MTS to use it in my Hero!
Either the File or Individual settings anything will do.
After googling a bit, i found two prl files which are attached in this post. Test and see if it works...also after writing prl file plz change Country code, that is MCC = 405 & MNC = 89
MTS PRL.zip
Thanks alot for the file!
Will surely update you it works or not!
AFAIK country code is 404?
Edited by SumitVerma
Extremely sorry! I'll be needing the NAM settings.
I dont know where my brains is taking me.
Sorry again.
Yes in some part of India country code is 405 !!
MTS.rar
Edited by ::Hitesh::
@ hitsh ji i tried to use 8330m on MTS i uploaded the given PRL but the issue is i can't receive calls on it but i can receive SMS on it , when i try to send SMS it show send and delivered but i don't receive then on other end ,,,, please advice me ..
that means your phone is not activated fully , MTS activation is not same as reliance.
i am able to get calls & make calls
Also able to send sms
but not able to receive sms
what can be the reason
