trupti18181
1X And Evdo In Cdma Curve
I am using Tata CDMA Curve and enabled EVDO on this handset.Is there any option to select between 1x and EVDO manually using some hidden menu??
you dont need that
your voice is happening over 1x
and data occuring over evdo
in absence of evdo it will go to 1x for data
in case you are in area where evdo coverage is bad then only think about it
good to see, second handset after corby supporting EVDO
can i activate evdo on my touch pro2?
u get EVDO on BIS
btw bb browser s**ks anyways , u enjoy evdo u need new handsets which have great browsing capability and apps
@Rim -Gurus, Do we have EVDO support in the official Reliance 8330 curve? if yes, can that be activated. Thanks.
Edited by baskhit
^^^ YES !
^^^^ I think to get EVDO u need to have BIS as already said By Dr. Mufaddal, my cousin having same handset with EVDO active also he is on 299/- BIS plan i think thats why EVDO is active and moreover with tweak to run browser i also applied on official BB8330 and browser started working :) :)
for EVDO on 8330 one has to be very persistent with reliance. First activate BIS plan 299 and threat them to disconnect if EVDO not activated. If not done, go to higher plan and same tactics again. If lucky they will activate. Also contacts can do magic. But afterall no guarantee in reliance
well people at reliance have now understood the vulnerability of giving evdo on 8330 and 8830
and now they have stopped giving it openly
they wont give u unless u have a corporate connection or u have contacts
for evdo they made it very very strict
only on newer bbs and omh
both of which are secured as of now
At the moment when a BB is doing data transfer (evdo,1X,bes,bis) do callers get a busy tone like in our other phones ?
Or is BES/BIS able to do voice/data simultaneously - either on 1x or evdo ?
on 1X phone will be busy while BIS data transfer is ON
Gurus, thanks for your info, what happens if my MDN is already activated for broadband and shifts the handset to blackberry. My query do i still need to talk to them for EVDO activation.
