dheerajthukral
Slow browsing on my laptop with Netconnect Broadband+ - Please Help!
Hello People,
I am Dheeraj here.
I live in New Delhi and im currently using Sattelite A135-S4527 T2010 ~ 1.73 GhZ (Dual Core)
I had encountered a problem and so i had to reformat my laptop.
So i backed up all of my data and reformated using the two recovery disks, So i got all my driver's back and everything back.
Now when i tried to install Reliance Broadband + Netconnect , I entered my Phone Number and Password and connected.
I am getting 5/5 bars (Signal) and it got connected. But it dosent has that much efficency , Whenever i try to go to yahoo.com its not that fast, It takes me 20-25 seconds just to go to yahoo and 10-15 seconds on other websites. Earlier all my websites came in a flash. I think i need to enable/disable something in services.msc because i tried it in my dad's laptop and it works just fine, Really it works awesome in that..
Can anyone please suggest what should i do? So that i get my speed back :(
Here are some list of processes that run while i browse.
http://i40.tinypic.com/1y032d.jpg
Something doesn't look right in the screenshot with the explorer.exe error. Either files are corrupt or your OS is infected with a virus. I would suggest a full/deep scan using an antivirus (like Kaspersky or Norton 360) and an anti-malware software like MalwareBytes.
Also install HijackThis from http://free.antivirus.com/hijackthis/
this software will list all the activity happening during start up,
if your regedit and tas kmanager are blocked by virus you can unlock it .
it will list all the files loading while start up, you can enable or disable files to load at start up,
gr8 diagnostic tool.
