StaticElectricity
Bluetooth Stereo Headset Problem In 8830 We ?
Dear all,
I recently purchased a samsung sbh-650 bluetooth stereo headset for use with my verizon 8830 we.
The headset works perfectly with other nokia/samsung phones, but with the blackberry , the songs (while playing in media player) get stuck in between every 5-10 seconds.
Can someone please confirm this behaviour ?
I'm on verizon 4.5 firmware.
Dear all,
Yes. My sprint 4.5 firmware 8830 WE do the same with my Motorola S705 Stereo bluetooth unit..
till date i havent got a solution..
but u can try .. going to bluetooth> options and try switching either one Headset or Handsfree and go back to device profile refresh services and it might work if not then restart and repair.. this should work with either of the one "Headset" or "Handsfree"
if not then check with doc about how to update only bluetooth module in bb88830we..
Edited by coolminilife
Update:
Seems like a bluetooth synch or frequency drift problem.
anyways, the glitch is less and infrequent when ONLY the A2DP profile is active and nothing else.
As soon as i connect the handsfree profile with the A2DP, it starts glitching left right and center.
i have a solution for this problem.....
just rip the mp3 files @ 44,100 khz and try...
it worked for my friend !
Why would changing the freq. to 44.1k make any difference?
They play all well on the other phones.
Seems to me like a bluetooth radio driver issue on the 8830 WE.
Still i'll try that and check what works.
cause frequency higher than 44.1k requires more resources
higher the frequency more frequently it will get stuck....
my friend uses it this way only.....
i am sorry....
i am a little confused...
either the songs should be ripped at 44k or 48k
sorry for the confusion... but either will work for sure....
Motorola S9 working on BB8830 !
Dell Blue tooth Stereo is also working ...tested with my BB 8830 . :)
