ursmv 13 Report post Posted April 14, 2010 Dear Friends, As we know day by day tariff keeps dropping in telecom and the major advantage is nowadays operators started to offer a fixed amount recharge which gives certain no of free calls to any phone so mostly if you are having an office or in to a businuss were you would be making lots of phone calls mostly we prefer land lines as there is no much signal problem ..no heat generation in the ear..and ultimatly some one can try and just connect the call (i mean an operator in a office) so there are 2 products available now in GSM which will be of great use. If you really want to save your telephone expenses at home or office i would for sure recommend that you check with your exesisting bills what kinda calls is being made how many mobile calls and what tariff so just do a rework if the same made through a mobile sim so you will know the savings. Telular sx6p-300g gsm landline phone. This is an gsm landline phone any gsm sim cards can be used in it. It's a wireless landline with a sim slot so you can use any gsm mobile sim cards. It's a must for people who speaks for hours in phone no more heating of ears and radiation problem. Its clarity and signal strength is also amazing . it's a telular corporation product made in usa. Tri-Band Capability (850/1800/1900 MHz or 900/1800/1900 MHz) Voice Communication GPRS Packet Data (Up to 86.6 Kbps)* Circuit-Switched Data (up to 14.4 Kbps)* PC Fax (up to 14.4 Kbps)* Caller ID, call waiting/call hold, call forwarding* SMS Text Messaging* Speakerphone Backlit keypad and Large LCD display LCD for SMS, caller ID, call timer, dial number, status icons, and status message Dedicated "Hold" and "Mute" buttons – just like wireline phones Flexible power supply and battery backup options to maximize performance Easy to navigate menu via softkeys Automatic end-of-dialing (no SEND key) Easy set up call logs, clock and call timer. 3.6 V rechargeable battery pack with 3 hours of talk time and 120 hours of standby. Nokia 32- Gsm fct. This is nokia gsm fixed cellular terminal it will work with all gsm sim cards and you can connect your mobile sim to your pabx or epabx. An added advantage of this product is you can also connect a fax to this device which means you can have a mobile no as your fax no. There are plenty of use for this product which will save lot of money . You can even connect a parallel phone or use your very old analog instrument to receive the mobile calls. I have given the link were you can download the entire technical manual it self. http://www.westlake....nical_guide.pdf I have posted a thread in buy sell area of the forum those who are intrested kindly check there for price and availablity..the link for the same is given below. http://www.rimweb.in/forums/topic/24440-exiciting-offer-on-all-old-and-new-stocks/ Share this post Link to post Share on other sites
