amarjot 0 Report post Posted April 25, 2010 Hi, I just got my Used Palm Pre unlocked for reliance. Already in love with it. Its just amazingly smooth. Having a problem please help if anyone knows. I have the web OS ver 1.3.5.1 I had the 755p it got burnt out. long story. I do not want to use the web to transfer my data from my PALM DESTOP to my PRE. My Wifi is workng fine, checked by watching a video on youtube. There is a software called CompanionLink for webOS USB, which i have downloaded on my desktop... but i am to download the same on my phone from APP CATALOG. Without wifi i am able to open the APP CATALOG ( guess the previous owner must have accessed it). I am unable to open the application nor am able to open the APP CATALOG or even the UPDATE using wifi. Update just does not open, and APP CATALOG gives an error " THE ACTION COULD NOT BE COMPLETED.Try again later. " Please help if anyone is Familiar. 2. If i update or anything or if i do a partial reset will i lose all the setting ie will it continue to work with Reliance or will i have to re-unlock it. Will the EVO connection work. Thanks. Share this post Link to post Share on other sites
