ashwani_0501 0 Report post Posted May 4, 2010 Hi, I was trying to connect my office given reliance handset (LG RD3510) for using it as a modem with my laptop. As this is my first time of using reliance mobile as modem I don't know the Dial-up settings. Seniors Please provide me the settings for Reliance Postpaid for Delhi Circle. Thanks in advance Share this post Link to post Share on other sites
Arun 795 Report post Posted May 4, 2010 username: your mobile number password: your mobile number number to dial: #777 Hope you have already installed the required driver Share this post Link to post Share on other sites
konquerror 21 Report post Posted May 4, 2010 Well i don't think you can't use LG RD3510 as modem...i tried with 3500 but everytime it gives error... Share this post Link to post Share on other sites
shripalkawdia 12 Report post Posted May 4, 2010 http://lgmobiles.com/index_cdma.php http://www.rcom.co.in/RNetconnect/RNC/dataCableSearch.jsp CHK HERE Share this post Link to post Share on other sites
konquerror 21 Report post Posted May 4, 2010 In specs too..it says Modem: No http://www.lgmobiles.com/specs/Product%20Note_RD3510.pdf Share this post Link to post Share on other sites
supernova 47 Report post Posted May 4, 2010 i also think it cannot be used as modem Share this post Link to post Share on other sites
ashwani_0501 0 Report post Posted May 5, 2010 @ Arun: Thanks a lot for the settings, I have already installed the drivers, Will going to check & update the results here Share this post Link to post Share on other sites
ashwani_0501 0 Report post Posted May 6, 2010 Hi @konquerror: u were right It doesn't have modem I had tried a lot but failed. thanks to all.. Share this post Link to post Share on other sites
natjay 5 Report post Posted May 8, 2010 I have the same model phone but there's no modem in there. I remember the time when most LG phones used to have modems for net access. I think the LG6600 phone has in-built modem. it could be used for Netconnect. Share this post Link to post Share on other sites
hA1d3R 0 Report post Posted July 6, 2010 (edited) i cant understand why tethering is not possible on new LG handsets like RD3600 . LG provides USBmodem driver Edited July 7, 2010 by hA1d3R Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted July 7, 2010 LG Provides Modem but dose not provide modem settings. as modem is not responding for dial up. Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted July 7, 2010 few years back i was successfull in running LG low end fones with greenish yellow light in screen as modems one of them i remember is LG2530 model.... Actually this was possible with a special type of data cable available in market that time.. this cable was unique kind of as it worked as usb to serial port converter, this cable got detected as a hardware whenever i inserted usb into laptop/pc that too without connecting to fone at other end of cable, also one need to install cable drivers instead of fone drivers, it used fone as connected to serial port and also old rconnect software was used to connect fone as modem successfully, i m talking abt that rocnnect software which connected as serial port and asked to dial *412 for activation of rconnect. i hope u guys remeber that ....if currently this type of cable is available in market then it may be possible to connect low end lg fones to be connected as modem successfully .... Share this post Link to post Share on other sites
