deadman
Device Error 348 Reset On Blackberry 8830
I'm getting " Device ERROR 348 Reset " when i reset, it's keeps coming. Unable to understand exact problem for that error. If anyone knows please help.
[using Reliance CDMA on BB8830.]
Turn your DATA OFF and try.
if not help wipe your device with JL commander or bbsak and load a OS ver 4.5.
If both not helped, your radio have problem (Qualcomm Chip)
better to repair it or replace the phone.
by the way you are a deadman why u want a phone ? :rofl_200:
Edited by ::Hitesh::
I have tried wipe option. Will try Data Off.
why i want phone? to call dead people ;)
Edited by deadman
:previous:
Also try if downgrading OS of BB .. it might help . Because even i had also faced same issue earlier .... :)
:previous:
For now after "Turning Data Off" it's working properly! Thanks Hitesh :)
finally i think Hitesh has solutions for all our problems :)
thanks Hitesh !!
Maska mat maro, tumhara kaam kal rat ko kar dunga,
Little busy now a days.
Really u have solutions for all blackberry problems !!
Stll getting same Device ERROR 348 Reset
Now i will follow chintan1 " Also try if downgrading OS of BB .. it might help . Because even i had also faced same issue earlier .."
:previous:
Please give me verion information of the Old version which you are pointing for 8830 World Edition....Also link to download will be great help for me.
Lowest version available for BB8830 is Ver 4.2.2.123
Link:- https://www.blackber...040FB621889B9A2
Just fill the form, no registration req, it will take you to download page.
Thanks a lot Hitesh
I have Installed it but after selecting 4.2, Application Loader Give ERROR 'A Software Update could not be found" and giving instruction to download latest software. any help on that
Edited by deadman
^^ u need to wipe it and then install new OS,
you will require following software to wipe and install
1) BBSAK (GUI ver of JL commander)
2) Blackberry desktop manager (Ver 4.2 or 4.5)
3) BB OS (link given by me)
Now follow these steps
Remove the battery of BB8830
Open Blackberry Desktop Manager
Insert the battery in 8830 and let it boot fully.
then Connect your 8830 to PC via its USB cable.
Your Blackberry desktop manager will connect to 8830 and will show its PIN at the bottom
Leave the BB DM open (require for com port to be active)
Then open BBSAK (you required a live net connection to run it)
It will ask for a device password (if you have set the password
BBSAK will connect to your BB and it will also show your PIN and black color bb8830 on the software.
You will see 4 buttons on BBSAK backup / restore tab.
you have to click wipe device.
it will ask you "Are you sure? This is low level wipe" Yes or No.
Click Yes and wait for 30sec.
It will show one window, just click OK,
Your 8830 will restart and will show "Error 507"
Now close BB DM and open again.
It will show device not connected.
Now Delete the vendor.xml file located in c:\program files\common files\research in motion\apploader
Start application loader from DM.
Just follow the instruction on screen most of them are next next.
It will start loading apps to your blackberry, it will load JVM etc etc.
It will reboot two time.
On 2nd boot it will take more time (5-20min).
After that you are done !
If this did not help, you need to nuke your BB with MFI !
Thanks hitesh for posting details.. I have done it in some other way...Here is the details: (may help for newbie )
1] Wipe :
Downloaded JL_Cmder v1.9.1 [Thanks to google]
Option 4 Wipe
Downloaded CrackUtil (found zip file google)
wipe the apps and the file system
2] Downgrading BB8830 is Ver 4.2.2.123
As i got error as i said earlier. I followed this method.
Delete the vendor.xml file located in c:\program files\common files\research in motion\apploader.
1. Disconnect the device from the PC
2. Download and install Desktop Manager and the Handheld OS to the PC (if they have not already been installed):
Desktop Manager and Handheld OS List
3. Start a Command Prompt in DOS from the PC (Start >> All Programs >> Accessories >> Command Prompt)
4. Change the directory to: C:\Program Files\Common Files\Research In Motion\AppLoader
a) From C:\ prompt type:
cd Program Files
cd Common Files
cd Research In Motion
cd AppLoader
5. Make sure Desktop Manager is not running
6. Connect BlackBerry to the PC
7. Enter the following command in the Command Prompt window:
loader.exe /nojvm
8. The Application Loader Wizard window will open
9. Click on Next
10. You will get a drop down list with the COM ports and one USB port entry
11. Select the one which says USB:UNKNOWN
a) If you do not see USB:UNKNOWN or USB:BBPIN, then follow instructions listed in a1-a5:
a1) Disconnect the device from the PC.
a2) Keep the Application Loader Wizard window open
a3) Remove the battery and put it back
a4) While the red led is on, reconnect the device to the PC. The led will only stay on for a few seconds
a5) When USB:UNKNOWN appears in the drop down list, you need to immediately select Next
12. The loader should now connect to your device and you will be able to reinstall the OS
Done. I hope i will not get the Device Error 348 again.
After Downgrade, new problem started. whenever i get call or make call, BB restarts. finding solution...If you know please share..( not received Device Error 348 yet)
u dont need to wipe the os to downgrade
there is a much easier way to downgrade any os
dont use blackberry desktop manager
just install the 4.2 os
after that use app loader
connect ur bb
and load os through app loader
DONOT USE BLACKBERRY DESKTOP MANAGER
this is what i follow to downgrade 8830 from 4.5 to 4.2 and other bbs as well
all have been successfully downgraded till now without need to wipe/delete os
do a battery pull and try again
Done that also.. same this new problem continues. anyone else.
nuke your BB and load OS again !
I don't know what nuke means...however,
Just to update: I have done wipe again and reinstalled 4.5.0.175 Right now it's working fine since last 24 hours. Waiting for error :Confuso:
the error wont come on 4.5
some versions of 4.2 are very laggy
nuke means wiping os completely off device
Error still not came....worked perfectly.. today evening i kept inside my pocket and taken out for a while...after some time when i checked it. what i see is BB keeps restarting.. any solution for that. (I'm tierd and sick of this BB. if anyone want i will sell it :NOTriste: )
how to nuke, any software for that?
Edited by deadman
i prefer mfi tool for nuking
but i can do same with JL_commander
MFI always better, only it is 700+mb
