MartinL
Sch-S379 Uim/sim Card Required For New Pc Studio To Work?
Hello!
I have a Samsung SCH-S379, but I do not have a UIM/SIM card for it yet. When I try to connect to my Windows XP PC with New PC Studio (NPS), it sees that there is a device connected but it says 'Identifying the device failed. Move to search new device.' I have tried reinstalling NPS and the USB drivers from the samsungcdma website and the samsung India site. They all have the same problem.
Do I have to have a UIM/SIM card in the samsung sch-s379 for NPS to work?
If someone has a samsung sch-s379 and uses NPS can you try removing your UIM/SIM card and testing to see if NPS works with your phone without the UIM/SIM card in it?
Thank you!
i think yes u need to put the UIM if CDMA & SIM if GSM
no use buddy i tried my 379 too but it just doesnt connect.
though it was far more easier to connect my corby cdma :grin:
some of other fellow members had lil sweat in getting corby friendly with nps.
Samsung PC studio software is failure for CDMA phones. Even I have faced the same problem, after number of phone calls to samsung customer care and even once I took my laptop to service center the problem has not been solved by them.
Edited by prabakar
