cyberbhai 0 Report post Posted December 3, 2004 Hi, Any one have self charging data cable for n191 I have normal Data cable with, I can't stay connect to net as the phone discharges... USB port have power wire and if I connect that to charging wire of the phone then it can be good.... So if any one have self charging data cable and can tell me which wire is connected to which pin in mobile socket then it can be great for many users Is that a simple cable or some voltage regulator is present ???? Share this post Link to post Share on other sites
vaibhav 0 Report post Posted December 4, 2004 Hi! I have a self charging cable for sch191. its like a charger where one end is connected to the phone and the other end to an USB port. You can surf the net and it will get charged simantaneously. If u live in delhi you can buy it from NEHRU Place for 50 bucks. No voltage regulator is present in the cable as I m using 1 . It is connected to the phone in the same way as the charger. Share this post Link to post Share on other sites
cyberbhai 0 Report post Posted December 4, 2004 Hi Thank you. I too purchased the cable from my city for 70 buck. I couldn't find the self charging cable ( probably as this is bit old model) I think that there is just one wire that the power wire, is connects to the power input pin.... I will find a cable and see that and will post how to convert.... Share this post Link to post Share on other sites
