Mohan 0 Report post Posted December 5, 2004 One of my LG RD2030 is not detected by my computer. When i try to connect thro RConnect the dial up says the modem is not responding. when i am using bitpim also there is no transaction. but i have two more rd2030 set and all these work fine for bitpim and rconnect what can i do pls help me!!!! Share this post Link to post Share on other sites
Devesh 0 Report post Posted December 5, 2004 but i have two more rd2030 set and all these work fine for bitpim and rconnect 21272[/snapback] What is bitpim? Share this post Link to post Share on other sites
Code 0 Report post Posted December 5, 2004 Check the Data settings & speed on Ur handset. It shud be 11500 kbps. If that's OK then.. Did U try restarting the phone ? Switch off the phone. Remove the battery. Short the battery contacts on the phone (Don't short the battery else battery may explode!!!). Put back the battery. Restart. Try connecting. If all esle fails - check if the cable socket on phone appears to be damaged/visit a LG ASC. What is bitpim?21277[/snapback] Bitpim is a Open source PIM manager that allows uploading of ringtones wallpapers of Ur choice etc to Ur Brew Enabled phone (unless it is specifically restricted - as in newer models like 2130/2230/5130/6130 etc). Read this this topic carefully: THE BIGGEST SECRETS ABOUT RELIANCE PHONES Share this post Link to post Share on other sites
rim001 0 Report post Posted December 13, 2004 Check the Data settings & speed on Ur handset.It shud be 11500 kbps. If that's OK then.. Did U try restarting the phone ? Switch off the phone. Remove the battery. Short the battery contacts on the phone (Don't short the battery else battery may explode!!!). Put back the battery. Restart. Try connecting. If all esle fails - check if the cable socket on phone appears to be damaged/visit a LG ASC. What is bitpim?21277[/snapback] Bitpim is a Open source PIM manager that allows uploading of ringtones wallpapers of Ur choice etc to Ur Brew Enabled phone (unless it is specifically restricted - as in newer models like 2130/2230/5130/6130 etc). Read this this topic carefully: THE BIGGEST SECRETS ABOUT RELIANCE PHONES 21281[/snapback] Hi i 've RD 2030 and usb data cable and LG PC syn soft installed on xp. I m not able to connect phone for sync yet able to connect Rconnect . can any one help.. please...... Share this post Link to post Share on other sites
Arun 795 Report post Posted December 13, 2004 What is the error shown when you try to do the sync ? Share this post Link to post Share on other sites
imvikky 0 Report post Posted February 2, 2005 Check the Data settings & speed on Ur handset.It shud be 11500 kbps. If that's OK then.. Did U try restarting the phone ? Switch off the phone. Remove the battery. Short the battery contacts on the phone (Don't short the battery else battery may explode!!!). Put back the battery. Restart. Try connecting. If all esle fails - check if the cable socket on phone appears to be damaged/visit a LG ASC. What is bitpim?21277[/snapback] Bitpim is a Open source PIM manager that allows uploading of ringtones wallpapers of Ur choice etc to Ur Brew Enabled phone (unless it is specifically restricted - as in newer models like 2130/2230/5130/6130 etc). Read this this topic carefully: THE BIGGEST SECRETS ABOUT RELIANCE PHONES 21281[/snapback] Hi i 've RD 2030 and usb data cable and LG PC syn soft installed on xp. I m not able to connect phone for sync yet able to connect Rconnect . can any one help.. please...... 21833[/snapback] Check you device manager settings for usb connection if not then just try connecting on the other usb port... try uninstalling everything and reloading... Mail back the results I presently use serial cable I'll get other cable and try... on ur responce Share this post Link to post Share on other sites
dacodecz 0 Report post Posted February 2, 2005 Hi i 've RD 2030 and usb data cable and LG PC syn soft installed on xp. I m not able to connect phone for sync yet able to connect Rconnect . can any one help.. please...... 21833[/snapback] Dear rim001, You can run your pc-sync software in 2 mode, one is continuous polling mode and one is user selecetable mode, well in continuous polling mode sometimes software get confused about the com port and report error after a long try, I will suggest you to change the continuous poll to manual one, you can change it by right clicking it's icon in system tray, and choosing the appropriate option, this suggestion will only work if you already have selected the right com port in your configuration. Cheers ........... Share this post Link to post Share on other sites
