ramtech 47 Report post Posted June 30, 2010 Dear friends I am getting speeds of 2.5kBps(20kbps) on Reliance and 1.5 KBps(12kbps) on Tatadocomo with 75% signal strength and EDGE enabled Nokia 2630 handset(when connected to PC).Actual speed should be 236kbps but customer care is telling speed will be 40kbps but I am not getting even 10%. Is the speed I am getting is normal .any one using above services getting more speed. Is there any software to increase speed. I tried download accelerator and internet download manager softwares.but browsing speed didnot increase.downloading speed increased to some extent. I am using gprs for the first time .I used RCDMA 1X which gave 15-17kBps speed. Can anyone using help me to increase the speed. Share this post Link to post Share on other sites
ramtech 47 Report post Posted July 11, 2010 Dear friends and experts pls give your feedback.based on your feed back i will decide wether to used gprs of should go for other broadband services. Can you tell me in reality CDMA 1X(153kbps) gives more speed or GPRS EDGE(236kbps) gives more speed Thanks in advance Share this post Link to post Share on other sites
Arun 795 Report post Posted July 11, 2010 Isn't Reliance EVDO or MTS MBlaze or TATA Photon+ coverage available in your area? Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted July 11, 2010 buddy you can try Reliance net booster from here http://www.reliancenetconnect.co.in/others/RCZip/vsetup_reliance_finalversion.zip and also try Indian Steel Katora/bowl to keep ur phone/modem into it and ur speed may increase dramatically Share this post Link to post Share on other sites
kalpeshaparmar 66 Report post Posted July 11, 2010 buddy you can try Reliance net booster from here http://www.reliancen...inalversion.zip and also try Indian Steel Katora/bowl to keep ur phone/modem into it and ur speed may increase dramatically I installed the software but i wanted the deatils how does it work... And for what is it used........ Share this post Link to post Share on other sites
Maulik.Parekh 34 Report post Posted July 17, 2010 Well I do get speeds of 28 KB/sec with docomo .. since signal intensity at my place is only 2 bars .. i have brought a long USB cable& have put the phone near my window & then i get good speed !! Share this post Link to post Share on other sites
krishin.rajani 3 Report post Posted July 17, 2010 and also try Indian Steel Katora/bowl to keep ur phone/modem into it and ur speed may increase dramatically :Riendo: does it really make any difference? Share this post Link to post Share on other sites
drali 6 Report post Posted July 17, 2010 ya its a effective signal booster but remember to keep the Katora near window. Share this post Link to post Share on other sites
ramtech 47 Report post Posted July 19, 2010 Well I do get speeds of 28 KB/sec with docomo .. since signal intensity at my place is only 2 bars .. i have brought a long USB cable& have put the phone near my window & then i get good speed !! in area despite ful signal i am getting 1.5KBPS( 12kbps) with tata docomo and 2.5KBPS (20kbps) with RGSM. I didnot try KATORA METHOD. because katora is used to increase the signal strenght.but in my area signal are already full. Share this post Link to post Share on other sites
rajeshkatiyar 3 Report post Posted July 19, 2010 Well I do get speeds of 28 KB/sec with docomo .. since signal intensity at my place is only 2 bars .. i have brought a long USB cable& have put the phone near my window & then i get good speed !! in area despite ful signal i am getting 1.5KBPS( 12kbps) with tata docomo and 2.5KBPS (20kbps) with RGSM. I didnot try KATORA METHOD. because katora is used to increase the signal strenght.but in my area signal are already full. Dear friend In my area DOCOMO gives the speed of 3.5 to 5 KBps .Tata CDMA is providing about 10 to 14 KBPs. I am connecting through Nokia 2323 by blue tooth 2323 is GPRS Class 10 if i am right. DOCOMO is not stable I tried AT Commands also . Please give me any suggestion Share this post Link to post Share on other sites
ramtech 47 Report post Posted August 3, 2010 ya its a effective signal booster but remember to keep the Katora near window. How much speed does katora increases successful Users of KATORA Pls provide specifications Metal of katora(SS or aluminium or any other material) Position of mobile phone in katora(Flat or vertical position or slant position) Should mobile touch the katora or space to be maintained. Feed back from users sought Thanks in advance Share this post Link to post Share on other sites
ami1 237 Report post Posted August 3, 2010 ^^ I tried 2 different types of katoras with various combinations ie usb data card in horiz/vert positions touching not touching katora etc. but found that in certain locations on my computer (PC) table the speed was markedly high/low compared to other locations irrespective of katora ! So finally i settled on putting my modem in the CD Rack which is built on top of the PC table on one side. Speed here, as compared to speed in the modem's usual location of front USB port of the PC, is double ie 1.5 mbps vs 0.75 mbps upload speed Offcourse, there are so many variables in signal reception that everyone's mileage may vary depending on location/distance of tower, position inside your home/office walls etc. various wires and usb extension cable etc etc So the only advise is to try it out 10-20 different things for half an hour and measure speed for every permutation and settle for the best that you get. Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted August 3, 2010 waise dost ek baat bolta hun , jo peeche se aani haina us sey ziada nai mil sakti Share this post Link to post Share on other sites
@mitJ@in 256 Report post Posted August 3, 2010 For Sale ka ek thread open karna padega. To sell KATORAS Demand is increasing fot KATORAs.. Share this post Link to post Share on other sites
me_saket 73 Report post Posted August 4, 2010 hehehehe..... Aur katore pe bid karna chaiya, jyada speed jyada dememnd and then jigher bid. Share this post Link to post Share on other sites
rajeshkatiyar 3 Report post Posted August 4, 2010 Like Titanium Katora Alumunium Katora Silicon katora Share this post Link to post Share on other sites
rajeshkatiyar 3 Report post Posted August 4, 2010 Dear friends I am using unlocked Idea netsetter 3G modem purchased at 2200. I am using DOCOMO Sim in it and getting 8 to 14 KBPS downloading speed constantly marked improvement unlimited in Rs 95 Share this post Link to post Share on other sites
me_saket 73 Report post Posted August 4, 2010 lets make this official, send 1 copy to ANIL bhai too Share this post Link to post Share on other sites
Greatest 55 Report post Posted August 5, 2010 @vikas, thats awesome imagination man... Share this post Link to post Share on other sites
drali 6 Report post Posted August 5, 2010 Vikas, thats funniest ad..lol:clap: Share this post Link to post Share on other sites
HetalDP 947 Report post Posted August 5, 2010 Ab Biwi ne dekha ki ham Katora use karte hai to Bolengi " Tumhari yehi harkato se hame Katora leke Coverage ki BHIKH mangni pad rahi hai... " Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted August 5, 2010  , @Vikas Nice work Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted August 5, 2010 I wish if someone could writes Some Gud / funny features of this R Katora Share this post Link to post Share on other sites
me_saket 73 Report post Posted August 5, 2010 R KATORA Kar lo speed mutthi me Share this post Link to post Share on other sites
