indias_no1 0 Report post Posted July 1, 2010 Can some one suggest , where can I buy body for this phone , Just dropped it and broken, very fragile. Or there is any similar phone in which it can be housed. Share this post Link to post Share on other sites
Genius 817 Report post Posted July 1, 2010 ^^ my dear friend u need to by another one and use its housing i suppose. 1 Share this post Link to post Share on other sites
parin 857 Report post Posted July 1, 2010 Parts of chines brands hard to find even if u get it wont be cheap so buy a new one Share this post Link to post Share on other sites
aalok 442 Report post Posted July 1, 2010 Its best to sell off your broken phone to any mobile repairing shop & get yourself a new one, as this broken phone can be used for spares.. 1 Share this post Link to post Share on other sites
KumaarShah 143 Report post Posted July 1, 2010 Try with the ASC of Lephone in your city.... You may be lucky enough to get it there... Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted July 1, 2010 you have to be a real luck person to find a ASC for this phone ! Share this post Link to post Share on other sites
KumaarShah 143 Report post Posted July 1, 2010 One does not have to be lucky in today's world. Only one needs to search properly and get success. All the Chinese Crap mobiles are nowadays having tie-ups with local service shops. check with your local dealers for ASCs in your city and you will definitely get one.. @ sanjay Try the following link, it may help you out. You will have to check it out locally. Here 1 Share this post Link to post Share on other sites
