dipeshsp
Need A Reliance PRL For Blackberry 9630 Tour
Can anyone direct me where can i find a Reliance PRL for Blackberry 9630 Tour handset. Have tried looking for it without luck
U are using imported 9630 kya
Yes. Sprint BB Tour. Could not load the prl though (trying to get the SPC code)
you can buy spc code from ebay
these spc codes are generated through a calculator using ur meid
after u get spc code , u can load prl
I finally have the SPC code with me .. can anyone guide me how to load a prl using QPST?
When i try writing the prl file i get this error "NV_READONLY_S"
do following
use qpst 2.7 build 323
use model as surf 7600-7600
then once u open qpst send your spc , make sure spc is correct
then press read , if it read properly means spc is correct
then write prl
also use bb 9630 os 4.7.140 if still u cant load
  On 7/16/2010 at 3:12 PM, Mufaddal said:
do following
then write prl
Tired to downgrade my OS to 4.7.140, but still i face this error while writing the IMSI_S .. "NV_READONLY_S"
I am desperate to start reliance CDMA service on this handset
ignore that error; it is writing to your phone....prl has to be written in system/roaming tab
Edited by dkaile
imported tour 9630 can work on reliance kya.
Well .. i am trying to .. I managed to make *222 call from the BB tour handset (which was registered with Sprint).. So I am presuming that it will function.
I think the next step for me would be to transfer number from my existing handset to BB handset (the handset change card will not work as *228 does not work .. it gives some music and disconnects)? Any thoughts people whether I am on the right track?
Yes .. realised this later .. also .. the CDMA workshop demo version was capable to do so without any error.
The Mobile network still shows "Sprint PCS" (however I managed to make a *222 call with the handset) .. any thoughts on that?
Edited by dipeshsp
Not Yet !!
Will changing the ESN and MIN do the trick of transferring the number from one handset to another? Any adverse effect of doing this?
you cannot activate 9630 on reliance , as of now
Guest
