topgnat
Incredible Wakeup Using Trackpad
After searching since I bought Incredible I had been missing this functionality on Inc.
Finally I got this file elsewhere and this gets me love my Inc even more.
Hope there are others who would like it as well.
Just download the file, Unzip and put the file in the tools folder of SDK.
while phone is powered on plug it in and then do
Code:
adb reboot recovery
Once in recovery:
Code:
adb shell
mount -a
(it will give error saying it couldnt mount curtain things. This is OK)
now run
Code:
df
(It will output some data and percentage figures)
Now run
Code:
cd /system/usr/keylayout
cp qwerty.kl qwerty.kl.old
(do this so we have a backup incase we need to go back)
Now run
Code:
adb push qwerty.kl /system/usr/keylayout
adb reboot
Wola... once booted, you would be able to power on the screen with the optical trackpad.
qwerty.zip
Edited by topgnat
:thumb:
:thumb:
Can you tell me in detail how and where to put those codes?
I am a begineer when it comes to programming. So can you please elaborate the procedure?
first root
OOh! I'll have to root the device to enjoy the above mentioned trick?
Isn't there any other way to bring a similar functionality on non-rooted incredible?
