gauravjc
Urgent Help Required On Droid Eris Radio Not Switching On !
Hi Androids Guru's I need ur help !
I am in Jammu ( Katra ) my phone was working fine past two days and suddenly past two hours when ever I am switching on my phone I am getting this error :
"The process com.android.phone has stopped unexpectedly. Please try Again."
I have tried hard reset still same issue, still same issue !
Please help me out asap to enable my phone calls !
Thanks !!
As an urgent solution (source: http://www.google.com/support/forum/p/Google%20Mobile/thread?tid=53d875e70942e732&hl=en)
The way to solve the problem is (at least in my situation - returning from a holliday in France)
1. Choose SETTINGS - WIRELESS CONTROLS - MOBILE NETWORKS -
2. uncheck everything unnecesary ie. "Data Roaming" and "Enable always-on mobile" -
3. Change setting on "Use only 2G networks", wait 10 seconds, then change it back.
4. Now try NETWORK OPERATORS. Here you will get a network error (Not the "com.android.phone" error)Just continue and you'll get your wanted network.The reason for this behavior is that android uses a new type of network and supports old ones.
Some countries dosen't use this new network.
When your android phone makes a handshake in these countries it'll accept without error, but when it returns to the new type it won't connect.
This must be a bug and you can solve / workaround this by doing the above
Some also suggest a complete factory reset....
Thanks Shubhanyu for ur quick reply !!
I can't get into Mobile Networks menu only as very 2 seconds the menu pops up giving the above error and all I can do is force close !
After a certain tries of force close the fone hangs !
I tried factory reset still same issue ..
have u tried ##RTN#, only u need to reprogram the phone again !
come to mumbai and then see.....
DONOT TRY ##786# RESET
WILL SCREW UR PHONE
What does it mean it will screw phone ? I have done twice. When changing provision para like serials.
I have heard this before as well so curious.
##RTN# makes your phone set to original (meid, esn, prl and almost all)
so only programing is required.
I tried ##786# also but the min I do again the error pops up !!
Any way I am returning back 2mmrow!
Thanks your help guys !!
RTN reset restores the Default NV file which is stored in phones hidden folders
it will restore ur meid , wipe ur MIN no , restore prl
but it does more damage than this on many handsets
specially htc hero , many hero after doing ##786# reset cannot connect to qpst then
I was about to try 786 Reset...Thanks for informing and warning.
donot try 786 reset on hero specially in ur case
coz 90% of hero wont connect to qpst after that
it will tell u roaming list error
and after that it becomes very difficult to provision phone for data
i have got such handsets and i know how tedious it is to set data on them without qpst
I am back to mumbai and to my luck phone started working like normal again ...
Thanks Dr. Muffadal & all others for your kind help & support ....
