anuragz 4 Report post Posted August 24, 2010 Hi, I wanna know which mobile operator is giving cheapest call rates for calling UK (mobile phones). Are there any special packs for ISD to UK. Thanks Share this post Link to post Share on other sites
tanveer 59 Report post Posted August 24, 2010 Dont know about others but Reliance charges 9rs or so. Share this post Link to post Share on other sites
raccoon 53 Report post Posted August 24, 2010 (edited) 9 bucks/min?? I belive Docomo has a pack where tariffs to US, Canada, Singapore for 2p/sec. Can't recall if thats only to landlines or mobiles.Not sure if that is the cheapest in the market as of now.... but it probably is. Edited August 24, 2010 by raccoon Share this post Link to post Share on other sites
KanagaDeepan 1,084 Report post Posted August 24, 2010 (edited) No sir.. RCom charges Rs9.19/min for calls to RestOfEurope (other than UK, imho) only in home as well as roaming.. The call charge to UK (especially UK LandLines are cheaper) are slightly cheaper imho, but NOT sure as I have not called any UK number.. Most operators charge UK_Landlines same as that of calls to US/Canada.. Even TataIndicom, which is LEAST favorable in ISD calls charges calls to UK @ just Rs7.2/min... Anurag Ji... First check out the MTNL charges.. MTNL has heavily reduced ISD call charges few weeks back... Edited August 24, 2010 by KanagaDeepan Share this post Link to post Share on other sites
manishashar 6 Report post Posted August 25, 2010 MTNL has aggressive offer till September end. Re.1 per minute. Thats a peanut. Buy a prepaid SIM and use it for a while. See if the offer is extended. I had some calls for US and I obtained one and used it well. Share this post Link to post Share on other sites
anuragz 4 Report post Posted August 28, 2010 On 8/25/2010 at 3:41 PM, manishashar said: MTNL has aggressive offer till September end. Re.1 per minute. Thats a peanut. Buy a prepaid SIM and use it for a while. See if the offer is extended. I had some calls for US and I obtained one and used it well. I have a Trump connection but MTNL has reduced ISD rates only to few destinations like USA, Canada, Australia etc but UK is not included in it. I'v seen that there r many options to make cheap calls to USA/Canada but UK is quite expensive as compared to other countries. Share this post Link to post Share on other sites
@ksh@T 20 Report post Posted August 31, 2010 i read in punjab 1p/sec on std calls to Canada nad usa . . .only on DoCoMo Share this post Link to post Share on other sites
