Mufaddal 678 Report post Posted September 1, 2010 This is sort of a partial fix for people using bb 8830 /8130 /8330 now many people have an issue that when you switch the sim cards , or you remove / reinsert battery or many times switch gsm to cdma mode , you loose the anworm service books and inturn loose browser icon and then you have to re do loading service books again well there is a simple solution to this problem people using 8830 and 9530 just need to ---- go to Cdma service menu by dialing ## 6digit spc and press green call key ---- change the BB reg id to home sid , ie 14655 and save and reboot well what happens is , when u set REG ID TO Home SID , that time reliance pushes 4 service books of it Rworld OTA so you dont need to load anwron service books once u set bb reg id to 14655 , you will automatically see browser icon swhoing reliancemobileworld it opens rworld by default But only problem here is that , though after doing this setting u can always use browser in cdma mode , but for 8830/9530 , to use browser in gsm mode you will still need to load service books otherwise if u just use data in cdma , then you dont need to load service books again and again 4 Share this post Link to post Share on other sites
situ1962 21 Report post Posted September 1, 2010 Doctor u rock always. Share this post Link to post Share on other sites
parin 857 Report post Posted September 2, 2010 Nice info Thanks dr U are genius Share this post Link to post Share on other sites
konquerror 21 Report post Posted September 2, 2010 My registration ID was already 14655, that's why I was seeing a browser icon with name Reliance Mobile World...I didn't know it's coming because of registration ID...i thought it's coming because I used Reliance PRL...the browser icon always used to go away whenever I removed and re-inserted the battery...but Reliance Mobile World icon used to stay...so I stopped loading service books again and again...anyways...nice info doc... Share this post Link to post Share on other sites
tushar_jc 0 Report post Posted September 2, 2010 14655 is for reliance any code for TATA ... thank u Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted September 2, 2010 the reliance mobile world browser icon stays because of reg id as 14655 and not coz of prl well many sellers and people use reg id as 2004 and in that case u will not get reliance mobile world browser icon Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted September 2, 2010 ^^^ Yes, you are 100% correct ! Share this post Link to post Share on other sites
ami1 237 Report post Posted September 2, 2010 (edited) +1 Doc. I was having this problem too. EDIT: Have changed BB Reg ID to Home SID ie 14655 (and saved before exiting back from edit menu) but it keeps getting reset back to 2004 once i reboot. Is anyone else having this issue ? Edited September 2, 2010 by ami1 Share this post Link to post Share on other sites
parin 857 Report post Posted September 2, 2010 (edited) Dr i am to able not change the BB Reg ID from 2004 to Home Sid How to do that, not getting any option Edited September 2, 2010 by parin Share this post Link to post Share on other sites
KanagaDeepan 1,084 Report post Posted September 2, 2010 (edited) So that is the reason for the disapperance of Browser in my 8830 after inserting SIM and disabling CDMA and reverting back to CDMA... Interesting.. But still now I am using OperaMini without any issues.. I don't like the BB Browser, so I don't miss it much.. Is it OK, Dr sir??? Or OperaMini may also stop @ some time??? Please tell me.. Also I am using TataIndicom in my Verizon BB8830.. Edited September 2, 2010 by KanagaDeepan Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted September 2, 2010 well you guys must not be saving bb reg id what u should do is save bb reg id first close then in main cdma prgramming screen see if bb reg is is 14655 then press menu and save again now phone will reboot Share this post Link to post Share on other sites
ami1 237 Report post Posted September 2, 2010 ^ Yes, I realized we have to save TWICE. Once in Reg screen and once in the main screen again. Thanks. Now the BB browser says Not Authorized for every website ? Though opera keeps working. Does it matter if i am using sam1 etc or MDN ? Share this post Link to post Share on other sites
ACS 130 Report post Posted September 2, 2010 Same here.. mine too says 'not authorised'. Is V 4.5 the culprit ? Hitesh wasted 1.5 hrs to help me today on the same.. no luck. Looks like we need to fall back on V 4.2 Share this post Link to post Share on other sites
aeroamit 18 Report post Posted September 2, 2010 Fix by Doc on my BB8830 (4.5.0.175) is working fine and am able to see Reliance mobile World. Thanks to Doc for updating us. Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted September 2, 2010 sam1 mdn wont work use UTS username 1 Share this post Link to post Share on other sites
weapon-x 3 Report post Posted September 2, 2010 +1 for u sir ... Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted September 3, 2010 (edited) <P>yes its working but how to remove DNS server info from service book ???</P> Edited September 3, 2010 by vikasmahajanz Share this post Link to post Share on other sites
ACS 130 Report post Posted September 3, 2010 (edited) sam1 mdn wont work use UTS username You Rock Doc ! Its working with UTS username as you mentioned. I had forgotten to change my default browser settings after that, so it kept opening Rworld. (Thanks to Hitesh too for getting back both browsers on TViewer this time) Lets hope it never disappears again. Edited September 3, 2010 by ACS Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted September 3, 2010 but rworld asks to activate Mobile internet plan for third party sites Share this post Link to post Share on other sites
ACS 130 Report post Posted September 3, 2010 ^^^ 2 things as per my experience. Use UTS & Change browser settings (Options - Adv options - browser) of default browser as "browser" from "RWorld browser". Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted September 4, 2010 ^^^ 2 things as per my experience. Use UTS & Change browser settings (Options - Adv options - browser) of default browser as "browser" from "RWorld browser". as already i lost the browser due to sim changing then i didn't put it again but tried this method... Rworld browsewr is there but it ask for MIP(mobile internet plan) There is only one browser option in adv. settings i.e. rworld browser.. Even i have checked service books of reliance that installed by default after changing reg id. they are showing proxy ip's... Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted September 4, 2010 well the reliance service books will give u rworld browser which means it will open up proxy based rworld only for non proxy based u will need to load anworn service books again thats why i said its a partial fix , nahi to complete fix na bolta but for most people it doesnt matter if u use rworld or hacked browser as you wil be charged in both Share this post Link to post Share on other sites
parin 857 Report post Posted September 4, 2010 by doing this i got 2 browsers, i have made anworm as default so i can surf any website Share this post Link to post Share on other sites
gahesh 0 Report post Posted September 12, 2010 Thanks Mufaddal bhai for the information! I am able to see reliane webworld browser & all the service books! Lekin when i try to connect to rworld it says unable to connect! Can use it as a modem though! Share this post Link to post Share on other sites
konquerror 21 Report post Posted September 13, 2010 ^^^ Use UTS username for connection.... Share this post Link to post Share on other sites
