gaurangbhartia 19 Report post Posted September 9, 2010 Hello Every1, I had a lot of problems lately (mostly due to lack of knowlege) generating Akey... There is not much on the web... So from whatever I knowlegde I have gained in the past few weeks, I am posting it on the Forum for other members to use. Akey Generation (Points to Remember) : - Akey should be 20 digit Decimal (0-9) - Akey should not start with 0 (preferable first 4 digits should not be 0) [ this is because HLR converts Decimal Akey to Hex and then back to Decimal. In case the digits have preceeding 0, there may be a conflict as the HLR adds zeros to the end rathar than starting. This happens in case of Some ISPs. However this may not be true for all ISPs] - First 2 digits of the Akey has to be less than 18 [Actually it has to be less than 184xxxxxxx, but generate something lower just to be safe ] - Checksum Can be generated using CDMA WS by entering pE$n/E$n - Checksum is only required to feed the akey in the handset, the ISP does not need it. Furthermore, I have noticed that for better compatibility, It is better to get the Akey generated by the ISP through HLR and then feed it in the handset. [Though everyone may not be lucky enough for this.] I will update this thread with any new info I get... Last but not the least I would like to thank Muffy Bhai and Hitesh Bhai for the help and co-operation they have extended to me. (Specially to Muffy bhai who has kept up with the 100000000s of questions I have asked him and that I continue asking him everyday ! ) Hope the other members find this information usefull. -Gaurang [PS: DO NOT CHANGE AKEY OF YOUR HANDSET If it is able to make outgoing calls. ] Share this post Link to post Share on other sites
situ1962 21 Report post Posted September 9, 2010 Good info.Thanks. Techies please explain a bit for laymen like me about A key and it's use and significance. Share this post Link to post Share on other sites
rajanmehta 4,056 Report post Posted September 10, 2010 On 9/9/2010 at 9:01 AM, gaurangbhartia said: Hello Every1, I had a lot of problems lately (mostly due to lack of knowlege) generating Akey... There is not much on the web... So from whatever I knowlegde I have gained in the past few weeks, I am posting it on the Forum for other members to use. Akey Generation (Points to Remember) : - Akey should be 20 digit Decimal (0-9) - Akey should not start with 0 (preferable first 4 digits should not be 0) [ this is because HLR converts Decimal Akey to Hex and then back to Decimal. In case the digits have preceeding 0, there may be a conflict as the HLR adds zeros to the end rathar than starting. This happens in case of Some ISPs. However this may not be true for all ISPs] - First 2 digits of the Akey has to be less than 18 [Actually it has to be less than 184xxxxxxx, but generate something lower just to be safe ] - Checksum Can be generated using CDMA WS by entering pE$n/E$n - Checksum is only required to feed the akey in the handset, the ISP does not need it. Furthermore, I have noticed that for better compatibility, It is better to get the Akey generated by the ISP through HLR and then feed it in the handset. [Though everyone may not be lucky enough for this.] I will update this thread with any new info I get... Last but not the least I would like to thank Muffy Bhai and Hitesh Bhai for the help and co-operation they have extended to me. (Specially to Muffy bhai who has kept up with the 100000000s of questions I have asked him and that I continue asking him everyday ! ) Hope the other members find this information usefull. -Gaurang [PS: DO NOT CHANGE AKEY OF YOUR HANDSET If it is able to make outgoing calls. ] Ellaborate with Simple English Please for the benefit of wider community and technically challenged!! Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted September 10, 2010 ^^^ rajan you need not worry i am there to help u , when need arises Share this post Link to post Share on other sites
rajanmehta 4,056 Report post Posted September 10, 2010 On 9/10/2010 at 7:09 PM, Mufaddal said: ^^^ rajan you need not worry i am there to help u , when need arises :hi2: Share this post Link to post Share on other sites
HetalDP 947 Report post Posted September 10, 2010 Soon baby soon......... AKEY Generating an AKEY Writting software will be released but its not needed. So dont discuss and confuse and Reliance will do OTAFED AKEY Soon no need to make it, Genrate it, Feed it, Share this post Link to post Share on other sites
parin 857 Report post Posted September 11, 2010 Till date I did't find any need of A key in any handsets When A key is req??? Share this post Link to post Share on other sites
ami1 237 Report post Posted September 11, 2010 On 9/11/2010 at 2:08 AM, parin said: Till date I did't find any need of A key in any handsets When A key is req??? EVDO ? Share this post Link to post Share on other sites
gaurangbhartia 19 Report post Posted September 11, 2010 (edited) Ok... Here is a bit more in simple english... Akey is required to be generated if you purchase(or sum1 gifts u.. )a foreign CDMA handset AND it has MEID AND you want to activate it with Tata ( i dunno whether other ISPs like Reliance, MTS etc use akey or not) without putting it to the e$n mode. If above is the case, then you need to generate an akey, feed it in the handset and give the SAME akey that you generated for registration with Tata Indicom to make the calls work. If your phone is already activated and you are able to make calls, then no need to bother seeing this section. OR If you have purchased you phone from Rimweb community members (Like Saddik, Muffy, Dkaile, HetalDP, Hitesh, and others) .. then no need to worry... they would have already done the needful before your phone reaches you. @ hetal bhai - My intention is not to confuse people. It is to help anyone who needs some info for akey, since this is not available anywhere on the web. I have specifically posted this on the technical/programming section for the same reason. Furthermore, I had assumed/hoped that people who read this thread will already know about the Akey (since you need to know about Akey before knowing how to generate it)... thats why the title is "Akey Generation - Points to remember.. " not just Akey... Btw, feel free to close the thread if you think that this thread is inappropriate.... @Evrey1else- Akey is used only to activate/make outgoing calls(Voice). I think Muffy bhai told me Akey is not related to EVDO. PS: PUTTING WRONG AKEY WILL BLOCK YOUR PHONE. So Please be careful while doing anything related to it. Edited September 11, 2010 by gaurangbhartia Share this post Link to post Share on other sites
hiteshkkk1 327 Report post Posted September 11, 2010 ^^^^ Latest update.... tata has made akey compulsory even for e$n... my 8830 not getting programmed on tata. Have given the akey to be updated Let's see on Monday .... Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted September 11, 2010 yes this akey discussion is needed forget reliance Reliance will push it OTA soon akey is big menace in TATA , and its good to discuss it forum has tata users too Share this post Link to post Share on other sites
tushar_163 63 Report post Posted September 11, 2010 (edited) On 9/11/2010 at 2:51 PM, hiteshkkk1 said: ^^^^ Latest update.... tata has made akey compulsory even for e$n... my 8830 not getting programmed on tata. Have given the akey to be updated Let's see on Monday .... Yes, now a days TATA is not accepting most of the foreign esn which earlier they were accepting without any issues. The error that is shown in their system is "this esn is not present in a_key database" or something like that. Edited September 11, 2010 by tushar_163 Share this post Link to post Share on other sites
SumitVerma 187 Report post Posted September 11, 2010 Give me an esn to be programmed. Will give it a try or at least will try to find a solution. Share this post Link to post Share on other sites
tushar_163 63 Report post Posted September 12, 2010 On 9/11/2010 at 8:32 PM, SumitVerma said: Give me an esn to be programmed. Will give it a try or at least will try to find a solution. check your PM . Has anyone else also faced the same issue of Tata not accepting esn recently ? Thanks in advance Share this post Link to post Share on other sites
hiteshkkk1 327 Report post Posted September 12, 2010 Yes... My 8830 is not getting activated since a week... Sumit... are u hearing???? Now its your turn to help :-) Share this post Link to post Share on other sites
KanagaDeepan 1,084 Report post Posted September 13, 2010 Quote Yes, now a days TATA is not accepting most of the foreign esn which earlier they were accepting without any issues.The error that is shown in their system is "this esn is not present in a_key database" or something like that. Very TRUE... This happened for my BB8830 from Verizon too... After few tricks, it was made activated... Seems programming Tata number in foreign handsets nowadays is like pain in where u know.. Share this post Link to post Share on other sites
gaurangbhartia 19 Report post Posted September 14, 2010 (edited) On 9/12/2010 at 9:52 AM, hiteshkkk1 said: Yes... My 8830 is not getting activated since a week... Sumit... are u hearing???? Now its your turn to help :-) Doesn't 8830 accept ruim card ? you can get an OMH sim for tata, transfer your number to it and insert it in 8830 to use it .... PS: I am assuming that you have the world edition of 8830 and that omh sims work in 8830 (my reliance ruim works)... Its worth a try... One more thing...don't activate the omh sim using this phone...use any tata ruim enabled phone to transfer your number to the omh sim and once the new sim is activated, insert it in your 8830.... Do lemme know.... I'll try my best to help you in whatever way i can.. Edited September 14, 2010 by gaurangbhartia Share this post Link to post Share on other sites
harpreetsingh.pune 0 Report post Posted October 4, 2010 On 9/14/2010 at 6:44 PM, gaurangbhartia said: On 9/12/2010 at 9:52 AM, hiteshkkk1 said: Yes... My 8830 is not getting activated since a week... Sumit... are u hearing???? Now its your turn to help :-) Doesn't 8830 accept ruim card ? you can get an OMH sim for tata, transfer your number to it and insert it in 8830 to use it .... PS: I am assuming that you have the world edition of 8830 and that omh sims work in 8830 (my reliance ruim works)... Its worth a try... One more thing...don't activate the omh sim using this phone...use any tata ruim enabled phone to transfer your number to the omh sim and once the new sim is activated, insert it in your 8830.... Do lemme know.... I'll try my best to help you in whatever way i can.. Did anyone finally manage akey on tata? How does it work? Whom do we have to give the akey to? I tried everything including a nodal escalation at Tata Indicom but doesnt seem to work. EVen gave them an Akey. Share this post Link to post Share on other sites
gaurangbhartia 19 Report post Posted October 16, 2010 (edited) ^^ You have to give them an Akey with your MEID/ESN. You also have to feed the same Akey on your handset. Once this is done, you will have to activate the handset by dialing *228. I suggest you get in touch with technical support and/or the Tat Hub. (Btw, U can even ask Sadik Bhai, Muffy Bhai etc... they might be able to help you better for registration) If you have already escalated it to nodal, ask them to generate an Akey and you feed it in your handset. With tata that is always the better option. It also depends on whether you are using prepaid or postpaid. You first have to get your phone registered with prepaid department before getting it activated on postpaid. If you are directly trying to activate on postpaid, it will not work. Edited October 16, 2010 by gaurangbhartia Share this post Link to post Share on other sites
sasuboor 0 Report post Posted March 28, 2011 Hi Guys I finally flashed my Verizon to a Tata PRL and went to the Tata hub to get it activated on a prepaid number. They were initially reluctant to even try the loading of my new CDMA postpaid as they said *228 wont ask for a PIN. I tried and it did ask for the PIN So they started trying. Now i get a 1x signal on the phone instead of Activation Required prior to loading anything. Till here everything was nice and hunky dory Tata said that they are unable to do MIN programming as they dont have the MIN number. A mail to the technical department was responded by "ESN does not exist in the Akey database" which was expected but no worries. Generated an Akey with checksum digits so that I can update my handset with the same and give Tata my ESN along with the ESN but the handset does not accept the Akey. I updated it in the ##000000 menu where the Akey was blank. When I come out of the menu doing a save, it does not save the Akey in its records, tried many times but its just not helping. Can anybody let me know what is it I am doing incorrectly or is there a different crack for this Anyone pls help Share this post Link to post Share on other sites
raysmanindi 4 Report post Posted March 31, 2011 On 3/28/2011 at 7:11 PM, sasuboor said: Hi Guys I finally flashed my Verizon to a Tata PRL and went to the Tata hub to get it activated on a prepaid number. They were initially reluctant to even try the loading of my new CDMA postpaid as they said *228 wont ask for a PIN. I tried and it did ask for the PIN So they started trying. Now i get a 1x signal on the phone instead of Activation Required prior to loading anything. Till here everything was nice and hunky dory Tata said that they are unable to do MIN programming as they dont have the MIN number. A mail to the technical department was responded by "ESN does not exist in the Akey database" which was expected but no worries. Generated an Akey with checksum digits so that I can update my handset with the same and give Tata my ESN along with the ESN but the handset does not accept the Akey. I updated it in the ##000000 menu where the Akey was blank. When I come out of the menu doing a save, it does not save the Akey in its records, tried many times but its just not helping. Can anybody let me know what is it I am doing incorrectly or is there a different crack for this Anyone pls help I had gone through this same process about 8 months back, it doesn't work. Tata people don't know how to activate foreign Meid's.I had couple of friends in Tata technical team , after slogging for 3 days they were in the same delima as you have mentioned. SO i said TA-TA to tata , and i was on Reliance :Contento: :Contento: Share this post Link to post Share on other sites
drmadhu 87 Report post Posted March 31, 2011 ^^ MNP is comming now good by to tata and welcome to Reliance for accepting foreign meid. Share this post Link to post Share on other sites
nishsuxx 193 Report post Posted April 5, 2011 Thanks OP for all the info. Appreciated Share this post Link to post Share on other sites
gaurangbhartia 19 Report post Posted September 15, 2011 Well the Tata guys have to feed the Akey that you have fed in your handset to their back-end servers. When the A-Key fed by you AND the one fed into Tata servers are the same, then you will be able to use your handset. On 3/31/2011 at 1:38 PM, raysmanindi said: On 3/28/2011 at 7:11 PM, sasuboor said: Hi Guys I finally flashed my Verizon to a Tata PRL and went to the Tata hub to get it activated on a prepaid number. They were initially reluctant to even try the loading of my new CDMA postpaid as they said *228 wont ask for a PIN. I tried and it did ask for the PIN So they started trying. Now i get a 1x signal on the phone instead of Activation Required prior to loading anything. Till here everything was nice and hunky dory Tata said that they are unable to do MIN programming as they dont have the MIN number. A mail to the technical department was responded by "ESN does not exist in the Akey database" which was expected but no worries. Generated an Akey with checksum digits so that I can update my handset with the same and give Tata my ESN along with the ESN but the handset does not accept the Akey. I updated it in the ##000000 menu where the Akey was blank. When I come out of the menu doing a save, it does not save the Akey in its records, tried many times but its just not helping. Can anybody let me know what is it I am doing incorrectly or is there a different crack for this Anyone pls help I had gone through this same process about 8 months back, it doesn't work. Tata people don't know how to activate foreign Meid's.I had couple of friends in Tata technical team , after slogging for 3 days they were in the same delima as you have mentioned. SO i said TA-TA to tata , and i was on Reliance :Contento: :Contento: Share this post Link to post Share on other sites
