Saiesh 12 Report post Posted September 20, 2010 Hi all, I have recently purchased Idea netsetter 3g modem which is unocked to all operators, and i am using BSNL 3g sim card in it, The download speed of BSNL 3g is 0.29mbps if the same is tested on speedtest.net is it due to modem or fault of BSNL??? I am from Goa, has any one tested the speed of Bsnl 3g in their area, if yes kinldy update the speed and the device used Share this post Link to post Share on other sites
srk006 21 Report post Posted September 21, 2010 AFAIK, Idea netsetter doesn't support UMTS. Hence you get only EGPRS speeds. Share this post Link to post Share on other sites
srk006 21 Report post Posted September 21, 2010 oh.. i am wrong they do support speeds upto 3.6Mbps 3G NetSetter support speed of up to 3.6Mbps on HSDPA network and is backward compatible on our current EDGE/GPRS Network. On the current 2G environment subscribers will continue to experience EDGE speeds of up to 236.8 Kbps. Please check whether 3G is enabled on your BSNL sim Share this post Link to post Share on other sites
Saiesh 12 Report post Posted September 21, 2010 i have purchased a data card which is 3G enabled, it connect to High Speed internet but speed is low Share this post Link to post Share on other sites
viper_in_blood 4 Report post Posted September 24, 2010 anyone using 3g services of bsnl in small towns like belgaun etc ..plz post there speedtest results here...... :'( :'( :'( Share this post Link to post Share on other sites
xuketo 7 Report post Posted September 25, 2010 Try it on a 3G mobile to double check if you indeed have 3G coverage in your area. Share this post Link to post Share on other sites
Saiesh 12 Report post Posted October 2, 2010 guys i dont know some how the speed has increased just 2 days back its almost 1MBPS, enjoy Share this post Link to post Share on other sites
Saiesh 12 Report post Posted October 12, 2010 guys check out the speed of BSNL3G in Goa Share this post Link to post Share on other sites
hiteshkkk1 327 Report post Posted December 18, 2010 My speedtest result in Jalgaon for BSNL 3G using Samsung Galaxy Spica... Share this post Link to post Share on other sites
Dushie 30 Report post Posted December 20, 2010 Here are my BSNL 3G speeds in the first week, of getting my connection : - Share this post Link to post Share on other sites
Karthik R 246 Report post Posted December 21, 2010 5Mbps! unbelievable speed! Is it 3G itself? And where you from? Share this post Link to post Share on other sites
Dushie 30 Report post Posted December 21, 2010 From bangalore, there are few other users from kerela & cochin who are getting even higher speeds than mine. Share this post Link to post Share on other sites
