lostjournal
Blackberry Curve 8530 on TATA or Reliance or MTS?
Hi Folks,
I am planning to to buy a Blackberry Curve 8530 from the US.
Now the question is when I return to India - can I hook up that phone with any CDMA operator?
If yes, then which operator's blackberry Should I go for, depending upon the ease of unlocking - Verizon, Sprint, Virgin( Sprint backed)?
Thanks.
yes u can use it on any operator .... and it doesn t matter get any CDMA phone from US from any US CDMA carrier , u can use it here ..
but the condition is u should know the prog or u got contacts in Indian CDMA carrier that they register ur esn/meid on their network ..
Hi Folks,
Thanks.
This phone cannot be programed for Reliance as memory is locked,
Also you cannot read SPC from handset, you need to buy it from ebay or from other US forums.
then you can load PRL of Reliance / TATA / MTS
even after that you need contacts to get this working on reliance / TATA / MTS
it may take time , its not a fast food ! its a Birbal ka Khichada !!
Edited by ::Hitesh::
Thanks everyone for contributing.
The thing is - the 3G frequencies of ATT and T-Mobile is not compatible with Asian/ European operators.
And phone without 3G - is a bad idea. So eventually thought to buy a CDMA blackberry.
For the time being, trying a $10 data add on to work on my Nokia E71. Will get to know, tonight -
if it will work or I need to hook onto a costlier data plan for Smartphones :NOTriste: .
