simv
Htc Touch Pro - Keypad Not Working
I have been using HTC Touch Pro CDMA with Mighty ROM for Tata since some 8 mons without any major issues. Now suddenly the slideout keypad has stopped working. I can type only using the onscreen touch keypad. I restored the settings back to original settings using 'SK Tools' restore option. But the problem still persists.
Could it be a hardware issue? Who will be able to fix it?
Thank You.
Welcome to HTC Quality, friend. Scoop out a local repair centre or if you have an HTC service centre in your area, try your luck there first.
if HTC repairs then its fine. i doubt it.. otherwise give it to trusted repairwala and if possible, ask him repair in your presence. TP is bit complicated and not all know how disassemble, forget about reassembling.
This could be problem of belt,
I am facing same problem on my mogul,
you are in mumbai, go to any good repair center they will do it.
also opening the phone is little complicated but easy, there are lots of videos on youtube for same, even watching them you can change the flat cable of keyboard your self.
Hi ! I guess there is some hardware issues and 99% its of the Flex Cable...
If you are in mumbai i can help you with the same.
Edited by gauravjc
I was reluctant in suggesting him your name ... but you came to mind first thing!
Hello Gaurav..pming you.
