kesav
Wireless Technology Speed Difference
There's an opinion in online world about the speed which we get through wireless technologies.
With all parameters(signal strength, protocol, processor) reamining same, the following is the speed equation on computers.
In-built wireless Modem > USB Modem > Tethered Mobile
Is the above equation a myth or reality?
Experts opinion awaited.....
I have used
USB modem and mobile
I found that speed in mobile was higher than USB modem
:previous:
I'm not talking about internet in mobile but about Internet through mobile (mobile tethering) in Desktop/Laptop
After bit of google...
It depends on which technology/Standard you are comparing....
for USB...if USB 3.0 is considered...which can go upto 5Gbps, off course we need to have modem to support that speed
http://arstechnica.com/old/content/2007/09/intel-announces-demonstrates-usb-3-0.ars
where as for Wifi modem if u take 802.11n which can go upto 600Mbps
http://www.wirevolution.com/2007/09/07/how-does-80211n-get-to-600mbps/
:previous:
Tethering techonology doesn't matter as we always know tethering technology speed(either WiFi/Bluetooth/USB) is much much greater than cellular speed even if you consider latest WiMAX/LTE on the signal side.
Just consider speed of the standard on the Desktop/Laptop side is much greater than Cellular side for this discussion and then think whether that equation is true.
