ravi_patent 28 Report post Posted November 2, 2010 i have a transcend photoframe pf830 whose audio output is ver less. can i connect usb speakers(philips,Total RMS power: 2 watts) to the photoframe's usb port ,wth out overloading the power supply unit of the photoframe, to get high audio output Share this post Link to post Share on other sites
rajanmehta 4,056 Report post Posted November 2, 2010 You can buy a USB Speaker with built in battery but i have a doubt whether your photoframe's USB port will output audio? Most probably it is for data transfer with PC. Does it have a 3.5 mm audio output socket? If yes, then buy a USB Speaker with built in rechargeable battery and connect. Share this post Link to post Share on other sites
ravi_patent 28 Report post Posted November 2, 2010 (edited) thanks rajan. i was also having doubt whether the photoframe will output audio at usb port..i will check with transcend Edited November 2, 2010 by ravi_patent Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted November 2, 2010 USB in photoframe are only for data transfer , not for audio. for audio it may have 3.5mm jack or some audio jack (but not usb one) Share this post Link to post Share on other sites
ravi_patent 28 Report post Posted November 2, 2010 (edited) dear hitesh thanks for the clarification.and there is no 3,5 mm audio out Edited November 3, 2010 by ravi_patent Share this post Link to post Share on other sites
