ajesh83
LG RD 6300 - Sync Agent Not Recognising USB Port
Dear all,
Request help on this. I bought a LG6300 CDMA handset yesterday and have been able to sync my outlook contacts ever sine.
The configuration agent is not recognising any USB port, though I've tried all available USB ports in the PC.
Pls advice.
I am successfully used my lg6300 with sync,
Can u install softaware CD properly provided with mobile?
have you installed modem drivers for LG ?
the same problem I had...
I used this driver and then I connect the phone.. and its working..
You can download it from here
file name : LGUSBModemDriver_WHQL_ML_Ver_4.9.7_All_Win7
http://www.4shared.com/dir/w3FsRoMQ/sharing.html
reply me after successful installation .
good luck
regards
Milan
