pklingam 0 Report post Posted January 13, 2005 Hi, I could not install Modem modem in laptop which has only usb ports & has a converter for that, which is working & mapped to Com4. I have Rconnect Serial cable. While Installing it is not detecting . Tried by selecting both the options ie usb & serial. Any Help Pls!!! Share this post Link to post Share on other sites
ankit 0 Report post Posted January 14, 2005 Hi,I could not install Modem modem in laptop which has only usb ports & has a converter for that, which is working & mapped to Com4. I have Rconnect Serial cable. While Installing it is not detecting . Tried by selecting both the options ie usb & serial. Any Help Pls!!! 24159[/snapback] Which phone you are using??? Share this post Link to post Share on other sites
pklingam 0 Report post Posted January 14, 2005 Hi,I could not install Modem modem in laptop which has only usb ports & has a converter for that, which is working & mapped to Com4. I have Rconnect Serial cable. While Installing it is not detecting . Tried by selecting both the options ie usb & serial. Any Help Pls!!! 24159[/snapback] Which phone you are using??? 24225[/snapback] LG RD7130 & the OS is windows XP. Share this post Link to post Share on other sites
hardknow 0 Report post Posted January 23, 2005 hi all i need urgently for lg usb serial port(usb-serial converter)driver for r connect .i have dowenloaded r connect software for rd6130 from relianceinfo.com.but it showing error.i have only usb interface data cable. help me plzzzzz. thanks Share this post Link to post Share on other sites
petar 15 Report post Posted January 28, 2005 get prolific 2303 driver. should work Share this post Link to post Share on other sites
AKS 0 Report post Posted January 28, 2005 I have tried same thing with LG RD 2130. Its just didnt work. i have wasted many hours just trying that. There is problem with USB ports. Works very well with serial port only. Share this post Link to post Share on other sites
Devesh 0 Report post Posted January 28, 2005 I have tried same thing with LG RD 2130. Its just didnt work. i have wasted many hours just trying that. There is problem with USB ports. Works very well with serial port only. 25472[/snapback] Our suggestion is to buy a usb cable with a built in serial convertor. Do not use a usb to serial convertor cable with a serial port cable. I have been using USB data cables for LG 2030, LG FWP and now for LG 6000 for last 2 years almost and they work very well. I am using the USB cable for FWP as I am typing this message. I also sell the same cables on baazee.com and rediff.com. However I would not like to use this forum to peddle my goods and hence would not like to give you any links to source the products. You may search for these products on Baazee.com and select a seller who has good ratings. Share this post Link to post Share on other sites
Puneet 0 Report post Posted January 28, 2005 However I would not like to use this forum to peddle my goods and hence would not like to give you any links to source the products. 25473[/snapback] Nice thinking buddy. I am sure RIMweb community will apprecaite this gesture of yours to keep the forum clean. Share this post Link to post Share on other sites
