ani_meher 42 Report post Posted September 15, 2005 I am not able to send MMS to my 6130.Can u give me how to configure outlook for 1st SMTP.MMS portal asking for user id and PW wat is it? 40973[/snapback] Use the search feature. Code's tutorial is in the Technical Forum. But I don't know whether it still works or not (it worked last for me on Sat, 10 Sept). If anyone has tried it now, do let us know. Share this post Link to post Share on other sites
kesav 127 Report post Posted November 10, 2005 Is sending MMS through portal charged? I beleive its charged. Somebody kindly confirm it. Share this post Link to post Share on other sites
ashishbabu 1 Report post Posted November 11, 2005 yes it is charged service now. 3 rs per message. Share this post Link to post Share on other sites
vandith 0 Report post Posted November 15, 2005 hi i am getting the mms but when i open it it says no mms forud.... what is it with it... Share this post Link to post Share on other sites
Arun 795 Report post Posted November 16, 2005 That happens at times, probably due to problems at Reliance's server side. Try again later ! Share this post Link to post Share on other sites
Hunt3r 0 Report post Posted November 19, 2005 Friends, I am using LG-2130 since few days.. and Im not able to receive MMS from others or from portal. When MMS comes.. it shows me an sms with a link, I can open that link in portal but my handset doesnt run the MMS. Any comments? p.s. earlier I had 2130 in which MMS were coming well.. Regards, Share this post Link to post Share on other sites
shan 0 Report post Posted January 12, 2006 MMS portal will be available to all Reliance users with the following handsets: LG RD 6130, 6000 Nokia 6255, 6235, 3155, 3205, 6585 you will be charged Rs. 3/- per message per recipient. Also, forward messages feature will be charged Rs. 3/- per message forwarded. Share this post Link to post Share on other sites
coffeebee.3k3 0 Report post Posted January 28, 2006 Friends,I am using LG-2130 since few days.. and Im not able to receive MMS from others or from portal. When MMS comes.. it shows me an sms with a link, I can open that link in portal but my handset doesnt run the MMS. Any comments? p.s. earlier I had 2130 in which MMS were coming well.. Regards, Have you complained to CC ? ping them continously that its not working ... only then can u get a resolution i had the same case .. now resolved after rounds of calls to CC. Share this post Link to post Share on other sites
vandith 0 Report post Posted February 7, 2006 hi anything new in the mms sector its a long time since i have sent MMs of any new crack such as that outlook stuff pls reply... Share this post Link to post Share on other sites
