nellorian
How to activate EVDO on TATA Indicom Prepaid?
I would like to know how to activate Evdo on Tata Prepaid. I have omh sim and it is not showing evdo signal.
Thanks in advance.
Babulu
once you insert omh sim it shows EV signals contact cc
which handset are you having?
just complint them u r not able to connect internet,
When call back come from technical side, confirm from them that ur EVDO service is active.
There are some places where EV signal is not available.
Sir ji, which phone you are using ?
as per your profile you have nokia 6275 and in this nokia you cant get EVDO .
Sir
I am using Samsung Corby F339 and it is not showing any evdo signal. My sim is OMH sir
Please guide me
Thanks and regards
Babulu
first check EV coverage area also confirm same from tata hub near you.
than ask them to activate EVDO on your handset. or call CC .
