mjchandaria 0 Report post Posted December 11, 2010 how to copy phone book from nokia 6275 to PC? Share this post Link to post Share on other sites
cavarun 13 Report post Posted December 11, 2010 first step: install pc sync from nokia site to ur pc. second step: sync ur phone using pc suite . all ur contact will be saved in outlook thats it. ps: u can also customise the sync settings according to ur requirement. Share this post Link to post Share on other sites
MohammadSameer 0 Report post Posted June 16, 2011 my nokia 6275 is not supporting pc suit??????? plz help thx... . . . . Share this post Link to post Share on other sites
sgiitk 32 Report post Posted June 16, 2011 Most probably you have a driver problem. Uninstall & Remove all traces of Nokia from your PC. Reboot, and then try a fresh install. I never faced this with my Nokia 6275! Share this post Link to post Share on other sites
tarun_kabra 204 Report post Posted June 16, 2011 (edited) Yes, this may solve your problem. Uninstall & Remove all traces of Nokia from your PC And use Nokia PC Suite Cleaner for that, as simple un-install may not remove all the traces Also check that you have downloaded the correct version of Nokia PC Suite for 6275. Though I think that all the PC Suite v7.1 are same, but their website is giving different links for different phones. Edited June 16, 2011 by tarun_kabra Share this post Link to post Share on other sites
sgiitk 32 Report post Posted June 17, 2011 (edited) I downloaded for the 5230 and worked on the 6275 as well. For a total clean up either use a probrirtary software like AML Free, or run RegEdit, seacrh for Nokia and remove all manually. RegEdit can be dangerous in non-expert hands to be careful. Edited June 17, 2011 by sgiitk Share this post Link to post Share on other sites
