ashishbabu 1 Report post Posted January 15, 2005 hello i am new to this forum. I am ashish from MP. I have LG RD5130 color mobile i want some wallpaper for it, can any body help me and tell me that how can i create wallpaper for my mobile. thanks in advance. Share this post Link to post Share on other sites
adwait 0 Report post Posted January 15, 2005 hello i am new to this forum.I am ashish from MP. I have LG RD5130 color mobile i want some wallpaper for it, can any body help me and tell me that how can i create wallpaper for my mobile. thanks in advance. 24344[/snapback] Check out this link: http://www.rimweb.com/forums/index.php?showtopic=2030 Detailed information on sending ringtones and wallpapers to your phone is available. If you want to know how to create a wallpaper, you can download any from the site and chjange it to bitmap format and make its size 108 X 97 using any software like Imaging in windows. Share this post Link to post Share on other sites
gladson 0 Report post Posted January 17, 2005 Dear Adwait, In http://www.rimweb.com/forums/index.php?showtopic=2030, it says for 5130, images are to be of size 128x97, but u mentioned 108x97. Kindly let me know, which is the right one? Share this post Link to post Share on other sites
gladson 0 Report post Posted January 18, 2005 I worked a pic of 128 x 97, but the top and bottom portions are empty. I think the height's more than 97 for 5130. Anyway, it worked great. Thank you, All, who helped me Share this post Link to post Share on other sites
raharsha 0 Report post Posted January 18, 2005 gladson, can you please give some details on what you did that made it work? What was the size of the pic finally? Which software did you use and what was the format of the pic? Share this post Link to post Share on other sites
ashishbabu 1 Report post Posted January 18, 2005 as you all say that wallpaper format of lg rd5130 mobile in bmp. When i change the format the quality of it decreases, but wallpaper in rworld are very clear and good. please tell me how can i make very good picture. please send me some good wallpaper my mob. no. is || 09302920259 || Share this post Link to post Share on other sites
nilesh_ku 0 Report post Posted January 19, 2005 I am able to sent wall paper to my LG 5130, but am unable to save it as Wallpaper. The wallaper description is as follow: 128 X 97 and 6.8 kb. Can anyone help me out. Thanks Nilesh Share this post Link to post Share on other sites
k_lilawala 0 Report post Posted January 19, 2005 Hey For LG 5130 correct size is 128x128 (Height x Width) Format : BMP File size : not greater thans 200Kb Max file name : 10 Characters only. Share this post Link to post Share on other sites
nilesh_ku 0 Report post Posted January 19, 2005 HeyFor LG 5130 correct size is 128x128 (Height x Width) Format : BMP File size : not greater thans 200Kb Max file name : 10 Characters only. 24642[/snapback] Thanks Lilawala, Now I am able to save as Wallpaper. Regards Nilesh Share this post Link to post Share on other sites
Bhargav 0 Report post Posted January 19, 2005 (edited) Thanks Lilawala,Now I am able to save as Wallpaper. 24646[/snapback] dear nilesh pl. tell me which softeare are u using for convert any image to bmp.. i am using photoshop elements. and 256 bmp format. pixal size 128/128 and 128/97 i recived image from mms but its not show in viewer and not save as wallpaper.. pl..help me for that.. regards bhargav Edited January 19, 2005 by Chirag Share this post Link to post Share on other sites
nilesh_ku 0 Report post Posted January 19, 2005 (edited) dear nilesh pl. tell me which softeare are u using for convert any image to bmp.. bhargav 24649[/snapback] Dear Bhargav, Please Open the file into Window Paint and save it as .bmp format. Regards Nilesh Edited January 19, 2005 by Chirag Share this post Link to post Share on other sites
Bhargav 0 Report post Posted January 19, 2005 (edited) Please Open the file into Window Paint and save it as .bmp format. 24657[/snapback] Dear Nilesh, I try same as u write.. but attechment not supported....giveing message in mms.. and i try to save as wallpaper but message is no image found... also i am attech that file hear which i want as wallpaper..so if possible pl..send me s mms.. also cheak that file..it is ok. or rong..file size pixal... Regards, Bhargav 4.bmp Edited January 19, 2005 by Chirag Share this post Link to post Share on other sites
nilesh_ku 0 Report post Posted January 19, 2005 Please Open the file into Window Paint and save it as .bmp format. 24657[/snapback] Dear Nilesh, I try same as u write.. but attechment not supported....giveing message in mms.. and i try to save as wallpaper but message is no image found... also i am attech that file hear which i want as wallpaper..so if possible pl..send me s mms.. also cheak that file..it is ok. or rong..file size pixal... Regards, Bhargav 24662[/snapback] Hello Bhargav, I had send your file by mms, please confirm whether u got it and are able to save it as wall paper. regards nilesh Share this post Link to post Share on other sites
Bhargav 0 Report post Posted January 20, 2005 Hello Bhargav,I had send your file by mms, please confirm whether u got it and are able to save it as wall paper. regards nilesh 24709[/snapback] Thanks!nilesh i recived mms and done to save as wallpaper.. now tell me what is procedure for save image in 256 bmp..i have windows xp prof.. Regards, Bhargav Share this post Link to post Share on other sites
