deVil81 0 Report post Posted January 19, 2005 (edited) this is for Saurav and others who have not been able to use the pc Sync software because it hanges at around 20%. Well after some research I found out that the software requires USB 2.0 and if you use it on 1.1 or earlier, it behaves that way. Just buy a USB 2.0 card (PCI slot). It will be around Rs. 250. and it works perfectly Edited January 19, 2005 by deVil81 Share this post Link to post Share on other sites
