hiteshkkk1 327 Report post Posted January 23, 2011 Hi friends... I have 2 gateways in my network viz ADSL & VSAT. For adsl, i have wifi router. Now, I want to use both the gateways simultaneously. For that, I have done below things. My VSAT gateway ip is 177.177.3.209/255.255.255.248 Accordingly, i had changed my router's lan ip to 177.177.3.210/255.255.255.248 PCs are from 177.177.3.211 to 214 / 255.255.255.248 & default gateway is 177.177.3.210 (adsl) Now, internet works flawlessly. Also, my applications that run on vsat access just 3-4 different ips. For that, i had made batch file in following format route add 162.50.50.2 177.177.3.209 where 162.50.50.2 is ip to be accessed thru vsat Till now, everything was working fine. I can use internet as well as my vsat based application both at the same time. Coming to problem, I have now increased no. of PCs in my office to 10 & also some IP devices like wifi camera n etc. But, I am unable to assign them IP address since as far as i have read, subnet 255.255.255.248 allows only 6 series of ip address. Now, I cant change my subnet as it has been assigned by my vsat provider HCL comnet. So, what other options are available to me??? I have 2 ideas in my mind but not sure how to do it n if it is possible or not. Idea 1. Set my adsl router as 192.168.1.1 / 255.255.255.0 n all PCs in range 192.168.1.2 n so on. Now, is there any setting in router which can route requests for 167.50.50.2 thru vsat as 2nd gateway??? I have read abt static route can do it but not sure how to do it... Idea 2. Set my adsl router as 192.168.1.1 / 255.255.255.0 n all PCs in range 192.168.1.2 n so on. Also, there are only 4 pcs which access thru VSAT. So put secondary IP in those pcs as 177.177.3.210 to 213 / 255.255.255.248. Even here, I am not sure how to proceed. Hope i have been able to explain the problem correctly n awaiting foolproof solutions. Thanks in advance.. Share this post Link to post Share on other sites
