Saurav
Dialup setting for connecting to Reliance 3G on PC using mobile
Pls provide me the Dial Up setting to access 3G on PC.
Use no *99***1# to dial and APN: rcomnet , Leave the username and password blank and it is done.
If you are using Handset Software, Configure connection thru the same.
or else you can directly make dial up connection. but before that install Phone's modem drivers & go to device manager-> <nokia> usb modem or bluetooth DUN modem . Open advance tab give string
AT+CGDCONT=1,"IP","rcomnet"
then make dialup connection give phone no=*99# and connect with blank username & password
Thank you for the settings. Just bought a GSM SIM and I was able to connect to the net from my notebook using Samsung DUOS W259. (I had not been able to connect earlier from my CDMA SIM).
